Quantcast Painting tranny and Tcase - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Painting tranny and Tcase
Old 03-31-2008, 09:44 PM   #1
atom73
1977 CJ5
Hey guys, I just got back from powerwashing the Tranny and T case. It looks really good and I think I want to paint it to protect the surface and keep it looking nice/easy to clean.
1. What type or brand paint should I get, any special considerations?
2. Do I need to prime it?
3. What should I tape and cover (ie what should I not paint)?
4. Any color suggestions?
Mike
PS. This is a copy of my post in my "clutch" thread, but I figured I would get more vis and info if I gave this post its own brief thread.
atom73 is offline   Reply With Quote
Old 03-31-2008, 10:04 PM   #2
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Even after power washing, I'd still scrub it with a brush and either some Marine Clean, Greased Lightning, Purple Stuff, etc.
Any decent paint will do...I don't think you really need any high heat paint....they don't get that hot.
POR 15 makes nice engine/trans/etc paints. The local NAPA here carries some of it, or you can order it online.
Colors....it's a personal preference.
Pacfanweb is offline   Reply With Quote
Old 03-31-2008, 10:17 PM   #3
Fjguercio
1978 CJ7
My bud used POR15 on his jeep and likes it. BUT he did say the POR15 did not stick to the Trans that well for some reason.
X2 on the cleaning with to remove the oil residue, brake cleaner would also work.
I used black Gloss Rustoleum. Gloss is more durable than Flat in most cases.
Fjguercio is offline   Reply With Quote
Old 03-31-2008, 10:24 PM   #4
tsujeeper
I've been using Duplicolor Engine Enamel for all my driveline components. Everything from transfer case to power steering pump. It's very easy to rattle can on, has a really tough 'enamel' finish, and is resistant to grease, fuel, oil, and heat. It also helps me to use the same stuff for everything b/c I know the finish will match.
79CJ7/401/NP435/D300/D44/14BFF in progress! Check out my build thread... http://www.jeepforum.com/forum/f8/project-chaos-523991/
tsujeeper is offline   Reply With Quote
Old 03-31-2008, 10:25 PM   #5
jayhawkclint
1970 CJ5
Just use Rustoleum. They make a line called "Industrial Coating" that works pretty well, slightly harder than the standard white can. Here's my line of reasoning: It really does not matter how much prep or paint you do to a drivetrain; it's underneath the Jeep taking a beating from road debris, salt, mud, stones, stream crossings, and even worse, the Jeeps own lubricants. I've found that it's best just to use a light coat of Rustoleum primer and a light top coat, then touch up from time to time when it wears thin because, no matter what you put on there, it probably isn't going to last very long, anyway. Frame is a different story in that it's thinner steel and you're aim is corrosion prevention. Drivetrain parts are heavy cast iron or cast aluminum, though, so you've got a little more time on your side between touch ups.
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f22/my-jeep-build-thread-359375/
jayhawkclint is offline   Reply With Quote
Old 03-31-2008, 10:30 PM   #6
yellow85cj
yellow85cj's Avatar
I used mineral spirits, then a cleaning with brake cleaner. Primed and painted with the implement paint from Tractor Supply. Took a week or so to really cure, but looks good. May hit it with clear coat over the whole thing including the unpainted aluminum before I finally get it put back in. Used the same paint on my skid plate. It looked good after about 3 months of use and the oil leak from the tranny and t case didn't do a thing to it. Just wiped it off and looks like when I first painted it.
yellow85cj is offline   Reply With Quote
Old 03-31-2008, 10:42 PM   #7
HackFabrication
1976 CJ5
Rustoleum. No need to prime. Just prep the surface and lay on a couple of coats:
If ya paint it black, you won't know were it's leaking from.....
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Old 04-03-2008, 08:29 PM   #8
atom73
1977 CJ5
Well, my paint project is done. Powerwashed at the self serve car wash, painted the tranny/t-case and also the crossmember. It looks sweet, here are some before and after shots, if I was going to tear it all the way down I could have really gotten after it and bead blast it but for the $40 I spent, I am happy.
Thanks for the help,
Mike
Old 04-03-2008, 08:57 PM   #9
GPER
1979 CJ7
Looks like the same color as my spare stuff, I used the Duplicolor
GPER is offline   Reply With Quote
Old 04-03-2008, 09:50 PM   #10
TexasCJ7
Hack how did you prep it? Did you rough up the surface first? How did you do it?
Thanks in advance,
-86 CJ-7
-83 CJ-8
TexasCJ7 is offline   Reply With Quote
Old 04-04-2008, 05:43 AM   #11
St.Patrick
1972 CJ5
Hack where did you get those stands. Hand made?
St.Patrick is offline   Reply With Quote
Old 04-04-2008, 06:59 AM   #12
HackFabrication
1976 CJ5
Sam's Club. They're just regular engine stands, I think they were around $40 a piece when I got them.
Old 04-04-2008, 10:23 AM   #13
badge1236
1978 CJ7
I disassembled mine and then cleaned it with mineral spirits. After that I dried it then primed and painted with engine paint. I used Chevy orange so I can see any oil leaks and things like that. The plan is to do the same to the transmission and then the engine block. I went with the engine paint so that the color would be consistant through all three pieces. Here is a before and after pic of the transfer case. It is a d-300 and I am sorry but I don't have any of it totally reassembled.
Before
With Primer
After the paint
'78 cj-7, 258, twin stick dana 300 transfer case, NV3550 transmission, scout d44 axles with detroit truetrac, 4.09 gears, black diamond 3.5 inch lift. The rest is yet to come.
badge1236 is offline   Reply With Quote
Old 04-04-2008, 10:25 AM   #14
mnCJ7guy
1980 CJ7
I've been thinking of asking the question
when you painted the tranny or xfer case, did you tape anything off or specifically avoid anything?
________________________________________________
1980 CJ7
151 4 Cylinder with a SR4
1990 YJ Islander
4.2L,Auto
mnCJ7guy is offline   Reply With Quote
Old 04-04-2008, 10:35 AM   #15
GPER
1979 CJ7
I didn't prime mine since the engine paint is rated at a hight temperature. I did tape off the holes and then cleaned all the paint off of the mounting surfaces.
Glock Forum
