Painting New Shocks Prior to Installing - JeepForum.com
post #1 of 9 Old 01-15-2010, 07:49 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Hi, guys.
I'll be installing new Rancho 9000's soon, and it seems like new shocks start out looking good, but begin looking crappy, pretty soon thereafter.
I'm starting a frame off restoration, for what will be a street driven jeep, and I'd like the shocks' paint job to last. Plus the fact that they're white, and I'd like to change the color.
So, has anyone done this before, and if so, what prep work did you do, and how well did it hold up?
I'm not positive, but it seems like the factory paint job is not too good to begin with, so I don't know how well new paint would last, with just scuffing up the factory paint, and spraying over it. But... maybe it will...
I could bead blast them, but they have a regulator knob on them, and I don't know if the blast media would mess things up.
That's why I'm asking if anyone has done this. Thanks.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2 of 9 Old 01-15-2010, 08:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I have sanded and painted a couple pairs of shocks. Just make sure to completely clean any oil or grease from them before sanding. For new shocks, priming shouldn't be necessary. Epoxy Appliance paint in a spray can holds up better than plain spray paint. Follow the instructions on the can, it is better to apply several light coats of paint rather than one or two thick coats. Allow a few days or more at + 60* for the paint to dry. Brand name spray paints apply better and hold up longer than the cheaper or generic paints.
Sandblasting would only be called for if the shocks were extremely rusted. When sandblasting you can mask anything you don't want damaged using duct tape.
CJ7-Tim is offline
post #3 of 9 Old 01-16-2010, 06:31 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks, Tim!
So, you feel that the factory paint job is a good enough base to sand and paint over?
I wasn't sure if I'd have to remove theirs' completely, then, prime and paint.
I'm not even convinced that they prime, at all...just paint!
Rich
rixcj is offline
post #4 of 9 Old 01-16-2010, 07:55 AM
rishar1
1973 CJ5
They are probably powder coated from the factory which makes a great base coat.
When ever I paint over existing paint I sand them thouroughly (SP?) with 220 grit paper and then go over them with a scotch bright abrasive pad to really smooth it out while still keeping it rough enough for the paint to stick.
And DO NOT blast them the sand, beads, whatever you use can get in side and really screw things up.
And like Tim said a good epoxy paint is the way to go for durablity, I'm not so sure about the appliance epoxy cause they dont have a very wide rrange of colors. And always buy a good name brand paint, you get what you pay for with paint.
Trust me on the paint I own a hardware store and have had way to many people complain that the cheap paint they bought didn't perform like they wanted.
And good luck with the frame off job. I'm in the middle of one and I can tell you this. You will get mad enough to tear your hair out so take it easy and don't get to frustrated.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #5 of 9 Old 01-16-2010, 09:06 AM
Tigger01
I have used Rustolum Professional Spray Paint on a lot of my parts and if sprayed in even coats the Paint comes out looking smooth and great
Sanding is good for the prepping before paint with a 220 sand paper as stated above
Before Painting any of my Parts I will Hang them using Tie Wire and spray all my Parts down with Ether - Starter Fluid and let it dry before I paint this removes any Grease or oil from the Parts then give it alittle time for the Starter Fluid to evaporate Note: I paint all my parts Out Side
Good Luck
Chris-Tigger
Tigger01 is offline
post #6 of 9 Old 01-16-2010, 12:17 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks for the comments, guys!
So, rishar1, can you recommend a good quality paint, that comes in spray cans? I'm leaning towards a gumetal gray color.
I doubt that the shocks are powder coated, due to the fact that the innerds probably can't take the heat required to cure the powder. unless they PC the parts before assembly, but I saw an episode of "How it's Made", and they showed the making of shocks. They were assembled, then painted (if I remember correctly). I'm gettin' old...
If they could, I'd powdercoat them myself (I have the setup).
Thanks, again.
Rich
rixcj is offline
post #7 of 9 Old 01-16-2010, 01:51 PM
CJ7-Tim
CJ7-Tim's Avatar
I really doubt any standard non-rebuildable shock is powder coated. Sanding the shine off the original paint is enough prep, all you really want to do increase the thickness and hardness of the paint to keep out moisture and resist chipping.
CJ7-Tim is offline
post #8 of 9 Old 01-16-2010, 02:12 PM
-AC-
1977 CJ5
Yeah, but as far as I know (not very far), there are some pretty thick stickers on Rancho (and pretty much everybody else's) shocks. So, obviously, you have to peel the sticker or sand it off or whatever...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #9 of 9 Old 01-16-2010, 02:45 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
That sounds good to me. That's what I'm gonna do.
The Rancho RS 9000 stickers come "on the side", meaning you put them on yourself. I'm gonna leave them off, even after painting.
Rich
rixcj is offline
Blocking a hole in the mc2100 prior to install? mmerlina Jeep CJ Forum 4 02-15-2008 02:45 PM
What Shocks/How R Shocks Suppose to Work? CJSAMM Jeep CJ Forum 5 09-25-2007 11:42 PM
$ Painting the CJ $ TX JEEP CJ7 Jeep CJ Forum 18 06-05-2006 09:58 AM
Installing shocks... diggs Jeep CJ Forum 3 08-12-2003 11:40 AM
rebuild prior to mopar mpi bseely Jeep CJ Forum 3 03-31-2003 03:04 PM
