Painting Driveshafts? - JeepForum.com
post #1 of 12 Old 01-18-2010, 04:02 PM Thread Starter
Cjwho
1981 CJ7
Can I paint my driveshafts with POR15 / Chassiscoat? I am in the process of painting my axles and small parts and just wanted to double check before I painted the driveshafts. When I am done with this phase I hope to never see a grinder or wire wheel again!
Cjwho is offline
post #2 of 12 Old 01-18-2010, 04:12 PM
Coiz
1979 CJ7
Yes, I did with mine. I know exactly what you mean about grinders and wire wheels.
Mike
Coiz is offline
post #3 of 12 Old 01-18-2010, 04:41 PM
TRex
1979 CJ7
I'm planning on doing mine as well. I spent nearly all day with the wire wheel. Those things can get mean. I can inside to wash my face and found a rogue wire had embeded itself almost 1/4" into my forehead.
I don't mind the larbor so much but it's just so damn time consuming.
1979 Jeep CJ7
Follow My Build Thread: http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/
TRex is offline
post #4 of 12 Old 01-18-2010, 05:00 PM
gmakra
Why not use 80 grit sand paper on a slow turning grinder about 1000 RPM and that will take off all your paint easily.
gmakra is offline
post #5 of 12 Old 01-18-2010, 05:36 PM Thread Starter
Cjwho
1981 CJ7
On a side note, how much should the front driveshaft compress and extend? Mine is missing the zerk fitting and seems to not move very much. Maybe 3 inches.
Cjwho is offline
post #6 of 12 Old 01-18-2010, 05:43 PM
ctm
Take it apart, clean it out, grease it, and put in a new zerk.
ctm is offline
post #7 of 12 Old 01-18-2010, 05:55 PM Thread Starter
Cjwho
1981 CJ7
How do I take it apart?
Cjwho is offline
post #8 of 12 Old 01-18-2010, 06:27 PM
rixcj
rixcj's Avatar
1979 CJ5
3" is about right. To take a driveshaft apart, you have to unbend the 4 tabs on the metal collar, near the slip joint. Then, do what it takes to get them apart.
You may not have to take it apart. If the slip joint moves the 3" freely, why bother?
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #9 of 12 Old 01-18-2010, 07:32 PM Thread Starter
Cjwho
1981 CJ7
I am not sure if I can just screw in a new zerk because there still may be a piece of the old zerk in there. o well i will clean it up, paint it, and keep rolling with my rebuild.
Cjwho is offline
post #10 of 12 Old 01-19-2010, 12:46 AM
pazur
1981 CJ7
IMO on CJ, if you lift your right wheel so it is completely off the ground, your should end up just at the start of the splined part
pazur is offline
post #11 of 12 Old 01-19-2010, 01:34 AM
scottymac62
1979 CJ7
You are lucky that it wasn't embedded in your eyeball! I always wear my welding helmet when using a wire wheel.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #12 of 12 Old 01-19-2010, 08:06 AM
TRex
1979 CJ7
Lucky indeed. I was wearing a respirator, safety glasses, hearing protection and a ball cap. I only had a few wires hit what little of my face was showing but my legs had wires sticking out everywhere. It looked sinister-- kinda like Pinhead from Hellraiser.
1979 Jeep CJ7
TRex is offline
bigger driveshafts?? nickoidl Jeep CJ Forum 2 11-30-2009 09:23 PM
new driveshafts? petey156 Jeep CJ Forum 1 12-21-2007 07:29 AM
Driveshafts Shafe62 Jeep CJ Forum 6 01-21-2007 04:24 PM
cj7 yokes and driveshafts acestony Jeep CJ Forum 3 04-19-2006 06:10 AM
More SOA questions (driveshafts) jeepin cj-5 Jeep CJ Forum 8 06-12-2005 02:32 PM
