Quantcast paint frame other than por 15 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > paint frame other than por 15
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 02-20-2009, 09:52 PM   #1
DeadPhish
1977 CJ7
i am getting ready to paint my frame for my off frame resto. what other frame paints have you used other than por 15. also what undercoatings did you spray?
DeadPhish is offline   Reply With Quote
Old 02-20-2009, 10:06 PM   #2
jatepper
jatepper's Avatar
POR-15 is said to be the best on many accounts. I would stick with that. Check out Imtheant's build thread because IIRC, he used something other then POR-15.
Good luck.
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Torchmate CNC Plasma Table Build / Projects
Handen Fabrication
jatepper is offline   Reply With Quote
Old 02-20-2009, 10:12 PM   #3
scottymac62
SEAL Team VI
scottymac62's Avatar
1977 CJ5
I use the Eastwood stuff.
http://www.eastwoodco.com/jump.jsp?itemID=24048&itemType=PRODUCT&path=1,2,37 2,373,374&KickerID=414&KICKER
scottymac62 is offline   Reply With Quote
Old 02-20-2009, 11:05 PM   #4
AGTORG
1979 CJ7
x2 on eastwood i used the grey epoxy primer first then 2 coats of there new ceramic chassis black. looks perfect and no discoloration or chips yet its a very durable product
AGTORG is offline   Reply With Quote
Old 02-21-2009, 03:02 AM   #5
HeepToJeep
1982 CJ8
I'd use Rustbullet.........until recently it was an industrial-only product and is used by the military to rustproof ship hulls. Anything that holds up to saltwater 24/7 has my vote!
Wm
HeepToJeep is offline   Reply With Quote
Old 02-21-2009, 08:47 AM   #6
khamill
1972 CJ5
I used an extremely hard urethane automotive paint over and etch primer.
I'll click on anything. Just post it.
72 CJ5
56 Willys P.U.
48CJ2A
khamill is offline   Reply With Quote
Old 02-21-2009, 08:53 AM   #7
danheit
1979 CJ7
I used Rustoleum hammered finish in several coats, along with a good clean frame and a metal etching primer. I have always used this on ALL of my resto's and have had terrific luck. I haven't every had anything fail, rust, or peel off. Grant it, that is just me, but I like it.
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7 Blue Jeep
danheit is offline   Reply With Quote
Old 02-21-2009, 08:56 AM   #8
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I have used Zero Rust on 3 frames... no issues yet.
cb
CertifiableJeep website
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
ORANGE JEEP CLUB #41
certifiablejeep is offline   Reply With Quote
Old 02-21-2009, 10:13 AM   #9
Bubba Ray
Rustoleum's Hammered finish paint comes in can or spray. Two coat min. and allow days to dry. Very durable on my rockrails.
Bubba Ray is offline   Reply With Quote
Old 02-21-2009, 10:16 AM   #10
Bakunin
Bakunin's Avatar
frame
if you've got it down to a bare frame I'd do some price checking on powder coating it.
Time flies like an arrow; fruit flies like a banana.
Bakunin is offline   Reply With Quote
Old 02-21-2009, 11:37 PM   #11
DeadPhish
1977 CJ7
i have some sherwin williams industrial enamel anyone ever used this
Old 02-22-2009, 04:39 AM   #12
nazdackster
I use zero rust. It can do 2000 hours in salt spray. Goes on easy and has a nice OEM look (satin black). Using more tomorrow. My FJ40 frame was done 5 years ago, not a sign of rust anywhere. 6 cans = $48 with free shipping. So good I would not try another. I also treat tough spots with naval jelly as a prep (then scrub off any iron phosphate residue)
zero-rust.com
http://www.shop.mfgsealants.com/category.sc?categoryId=8
Michael's CJ7
nazdackster is offline   Reply With Quote
Old 02-22-2009, 06:37 AM   #13
CajunCJ
I did mine with an industrial 4 coat system from International industrial coatings
3 mils of Interzinc 52
8 mils of Interseal 670 red
8 mils of Interseal 670 buff
3 mils of Interthane 990 black
If I would have had access to some Carbomastic 15 from Carboline paints I would have used that.
Don't use the enamel for the frame. Enamel has no flexibility when it's hard. Rocks hitting it will leave bigger chip marks. It also doesn't have good adhesion to the steel and when you have a spot that starts to rust it can work it's way underneath the enamel surrounding it and spread out.
CajunCJ is offline   Reply With Quote
Old 02-22-2009, 07:48 AM   #14
JavaTee
1979 CJ5
I used KBS coatings 'frame kit'. No complaints here. It's the competition of POR-15. ZeroRust, RustBullet, and there is one other not listed above would get my attention the next go around though.
Later, T.J.
JavaTee is offline   Reply With Quote
Old 02-22-2009, 10:34 AM   #15
grignac79
1979 CJ7
Nothing wrong with POR15. I blasted my frame and then metal etched to clean the grease and stuff off but forgot to clean it off. The paint was flaking off in some areas after I painted it. I tried to sand blast it again and man is that POR15 tough. Would not come of. So i cleaned the bad areas and reapplied the POR15 and it is solid.
The biggest negative is the need to paint over it due to not being sunlight resistant.
grignac79 is offline   Reply With Quote
Glock Forum
