Paint for Fiberglass question - JeepForum.com
post #1 of 9 Old 05-09-2013, 10:03 AM Thread Starter
stvincnt
1979 CJ5
I have a 79 cj5 fiberglass tub and am sick of battling oxidation and spending a day buffing it every few months, I would like to paint it and just get it over with. I've already lightly sanded it and would like to know how else to prep it and which kind of paint should i use. My plan is to strip all hardware and accessories and take it to a shop
Thanks in advance
stvincnt is offline
post #2 of 9 Old 05-09-2013, 10:19 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I don't think there's much difference from painting a metal tub.
Scuff the surface, clean it with a wax and grease remover, then spray it with a couple of coats of epoxy primer. Lightly sand the primer, if necessary, then spray your base coat followed by 2-3 coats of clear.
I think standard automotive paint works. Someone correct me, if I'm wrong.
Matt
Matt1981CJ7 is offline
post #3 of 9 Old 05-09-2013, 10:40 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
What are you buffing w/now?
I use this on my boat, but the color is gel-coated a few (22?) mm thick. http://www.ebay.com/itm/Shine-Restor...fffe6e&vxp=mtr
Once every spring keeps the colors sharp all summer long.
I wanted to clear coat it but I was told the colors would fade underneath it. But Corvettes get cleared, so maybe my painter didn't want all that work. Or worse, me HELPING him!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #4 of 9 Old 05-09-2013, 01:27 PM Thread Starter
stvincnt
1979 CJ5
I was using several different brands, I liked 3m's product the best but in this florida sun none of them would truly last more than 3 -4 months.
I've already rough sanded the surface so there is no turning back
stvincnt is offline
post #5 of 9 Old 05-09-2013, 01:41 PM
FishinMagician
Not sure on the paint, but if you check out TCPGlobal.com, I'm sure they can help. They have an excellent helpline you can call with any questions you have.
FishinMagician is offline
post #6 of 9 Old 05-09-2013, 03:21 PM
Nereussailor
I used PPG 2 stage automotive paint. The Florida sun is killing my clear coat too, but it's been on for 14 years and never been in a garage. I think that's a pretty good life for the clearcoat. I will probably spray a couple of extra coats the next time around. I'll use the same paint and clearcoat again. There's probably been a lot of advancements in paint since I did mine.
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #7 of 9 Old 05-09-2013, 06:22 PM
ramjett
1970 CJ5
Check with your local paint dealer. Epoxy isn't made for plastics or Fiberglas . Usually sanding ,the right chemical wipe and sealer ,then paint is the way to go. Some dealer stress a bought warranty on boats especially if its left in the water. The paint needs to breath.
ramjett is offline
post #8 of 9 Old 05-09-2013, 07:20 PM
Skerr
I used a lacquer based high build primer with a single stage satin finish paint, including hardener. Went on very well. Looked wonderful. Been on about a year. You can scrape it off with your fingernail! Don't know whether it was cheap paint (it was...), because no way will I agree I did a poor job of prep! Also a '79 CJ5. As the guys mentioned, you need to use a wax and grease remover before painting. But if you are going to have a shop do the work, I wouldn't worry about it. They will know what to do.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #9 of 9 Old 05-09-2013, 10:30 PM
hutch1200
hutch1200's Avatar
1979 CJ7
sorry
We have 3 months of sun and use. You have it the other way around. Yeah...I get 3-4 months. Should have looked at where you were. My bad.
