Quantcast Painless Wiring Harness, Any advice? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Painless Wiring Harness, Any advice?
Old 01-31-2010, 08:15 AM   #16
ken78cj5
1978 CJ5
No problem. If you follow the instructions you will do fine. One thing to keep in mind is that you will need a battery charger in Step 9 - detailed instructions are included in the installation instructions. This is used to apply low current to the system to check for any issues before trying to start your jeep. No biggie, I like this as a way to check things out before connecting the battery.
http://www.painlessperformance.com/Manuals/10110.pdf
ken78cj5 is offline   Reply With Quote
Old 01-31-2010, 08:40 AM   #17
Viencent
1982 CJ7
glad I saw this tread, looking more and more like I need the 110, thanks for the info and the pics help answer other conserns I had
Viencent is offline   Reply With Quote
Old 01-31-2010, 08:48 AM   #18
Viencent
1982 CJ7
wow, just checked the prices on these, the 10106 is $406 and the 10110 is $576, not sure the 110 is worth the extra $160
Old 01-31-2010, 08:52 AM   #19
mxracer919
1979 CJ7
It is like adding the powerbraid that protects all the wires....the powerbraid retails for over 200. The 10110 is 474 on 4wheelparts.com after you add it to your basket, and then you get the rebate on top of that. so 374 for a harness that retails for alot more....not to bad.
mxracer919 is offline   Reply With Quote
Old 01-31-2010, 09:15 AM   #20
Viencent
1982 CJ7
not bad, more and more Im thinking its worth the price, thanks for that one, hadnt checked there yet for the price.
Old 01-31-2010, 06:22 PM   #21
Boyjeepin
1980 CJ7
Is this a $100 cash back rebate or is it $100 off your next painless performance wiring harness? I'm confused!
"Going to the woods is going home..."
1980 CJ-7: FOR SALE
2000 XJ: Money Pit!
Boyjeepin is offline   Reply With Quote
Old 01-31-2010, 06:47 PM   #22
Viencent
1982 CJ7
$100 cash rebate, go to the painless site and you can read/download the form
Old 01-31-2010, 06:48 PM   #23
mxracer919
1979 CJ7
At first I thought it was off the next purchase, but after reading I am pretty sure it's off the purchase price.
Old 01-31-2010, 07:36 PM   #24
skidplate77
Awww, APPLESAUCE!
skidplate77's Avatar
1977 CJ7
Get the 110, it WILL be worth the price. A pre terminated harness is the way to go. There are other wiring looms outthere on the market. I got the Painless 110, and the instructions were very good.
The only thing I have to say if you have a fiberglass body, like I have, although Painless says the loom is for a "fiberglass body" it really isnt. Make sure (if you have a fiberglass body) you have good grounding "stations" for the engine and dash.
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock..
A new work in progress, and a new lease on life...
skidplate77 is offline   Reply With Quote
Old 01-31-2010, 07:37 PM   #25
skidplate77
Awww, APPLESAUCE!
1977 CJ7
Get the 110, it WILL be worth the price. A pre-terminated harness is the way to go. There are other wiring looms out there on the market. I got the Painless 110, and the instructions were very good.
The only thing I have to say if you have a fiberglass body, like I have, although Painless says the loom is for a "fiberglass body" it really isn't. Make sure (if you have a fiberglass body) you have good grounding "stations" for the engine and dash.
Old 02-01-2010, 01:51 PM   #26
Viencent
1982 CJ7
dont have the glass tub this time around so thats not a worrie, but desided the 110 is the way togo, Thanks for all the great input, will be getting it next week and will post how the install goes
Old 02-07-2010, 12:19 AM   #27
Agar426
1974 CJ6
The description in the catalog shows the 110 as a "replacement" harness, while it calls the 106 an "upgrade" harness.
I know next to nothing about wiring so that explains my confusion, but I guess I assumed the "upgrade" harness was their way of scrapping the stock wiring and replacing it with their version of a full harness, while at the same time I assumed their "replacement" harness was a duplicate of the factory set up. It also says the 110 doesn't support computer controls.
Agar426 is offline   Reply With Quote
Old 02-09-2010, 07:49 AM   #28
ken78cj5
1978 CJ5
What kind of computer controls do you need?
Any aftermarket FI should come with a harness that needs to be used with that fuel injection. This harness will most likely replace most of the wiring in the engine bay.
If the original jeep harness is going to be swapped with the 110, then just don't connect the wires that are not needed. This will be determined by the FI kit/harness that is being swapped in.
I have a Howell Fuel Injection kit waiting to be installed. If you can wait a week or so I can give a more detailed explanation.
Old 02-09-2010, 12:20 PM   #29
maback
I used the 100 harness in my 76CJ7, it was easy. Had it swapped and running in one weekend. Instructions are very good.
maback is offline   Reply With Quote
Old 02-09-2010, 03:13 PM   #30
mtndew1
1976 CJ7
Originally Posted by mxracer919 View Post
So getting the 110 would be like buying the 106 and then adding the 70920 powerbraid from painless to it? If so that sounds like alot better of a deal. Thanks for the tip!
I'm in the middle of putting the 110 now. The 110 does come in loom but it's not powerbraid, it's just the standard black cheap loom. The only complaint I have so far about the harness it’s so generic I won't use about half of the wires since my CJ is a 76 and does not have much for electronics. At least it does not have too few circuits.
I also recommend you find a place that sells the plastic connectors that hold the loom to the sheet metal. I had a hard time finding the sizes I needed at the Local auto parts store. I eventually discovered the auto paint shop sells just about every fastener and grommet you could ever want.
Since we all know a thread is worthless without pics!
1976 Jeep CJ7 - Build in progress
mtndew1 is offline   Reply With Quote
Glock Forum
