Quantcast Painless Wiring Harness, Any advice? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Painless Wiring Harness, Any advice?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 01-30-2010, 07:03 PM   #1
mxracer919
1979 CJ7
I have a 1979 cj7 with a 304v8, and I am planning out the future of it. My plans are to tear it completely down and go through it all from the ground up. Figured Might as well do it right and replace all the wiring. When checking on the painless website though it shows that there are two kits that will work, but then on the summit website it only shows one of them will work.
Part #'s
10106
10110
Has anybody done this to there jeep while in the process of a rebuild? Whats the difference between the two? Thanks!
mxracer919 is offline   Reply With Quote
Old 01-30-2010, 07:41 PM   #2
Matt_G
1979 CJ5
i have 10110 installed on my jeep and it was pretty straight forward and simple. not something i would want to do again, but everything was labeled and it came with instructions for all the different types of ignition. the dash seems to be all plug and play while the engine bay was all soldering, so keep your old harness for the connectors.
i picked it and a new windshield frame up locally for $200, practically stole it.
Matt_G is offline   Reply With Quote
Old 01-30-2010, 08:31 PM   #3
mxracer919
1979 CJ7
Wow, I wish I could find a setup like that down here. I did find a painless wiring harness for 74 and earlier on craigslist....I was getting excited, then I realized it wouldnt work...bummer
Old 01-30-2010, 09:01 PM   #4
ken78cj5
1978 CJ5
I have a 78 cj5 and I bought the 10110 harness and it worked great. Be careful and follow the instructions and you'll be fine.
ken78cj5 is offline   Reply With Quote
Old 01-30-2010, 09:06 PM   #5
RetiredSERE
RetiredSERE's Avatar
1980 CJ7
Didn't go with the painless myself. Went instead with the Centech harness. Was cheaper than painless and installed in no time. Also preferred the different style of bulkhead connector. Seems to be more reliable. One thing Centech did was added a constant power wire that goes through a water tight connection so I don't have to worry about a bad connection through the bulk head connector. That was one of the problems I had in conjunction thit the Howel TBI as any drop in voltage when cranking would give me all sorts of headaches.
Shoot, Move, Communicate
Admit to Nothing, Deny Everything, Make Counter Accusations...
I Feel Like a Monkey F***ing a Football..
RetiredSERE is offline   Reply With Quote
Old 01-31-2010, 05:54 AM   #6
Viencent
1982 CJ7
not to hijack this tread but I am about to order a painless for my CJ, have a 86 with a 304 out of a 76, was going to order the 10106 harness, would this be my best bet or should I look at the 10110? also done some searchs on here about others but most i found were older. any other harness I should look at thats easyer to install or about the same for a better price? sofar the best Ive found is $404 with a $100 rebate for the painless, seams Like a good deal. thanks
Viencent is offline   Reply With Quote
Old 01-31-2010, 06:51 AM   #7
mxracer919
1979 CJ7
Yeah, be careful. I saw that harness on 4wheelpart with the 100 rebate. It says that it is for "Chassis, Fuel Injection Harnesses and Perfect Engine Management Systems" So the way it appears you get 100 off your next purchase of one of these items.
Old 01-31-2010, 06:53 AM   #8
mxracer919
1979 CJ7
Thanks for the tip, I will have to check into centech!
Old 01-31-2010, 07:08 AM   #9
Viencent
1982 CJ7
the rebate is tru painless it self and if you go to there site it lists both these harness's as get the rebate, any know what my best option is for a harness?
Old 01-31-2010, 07:18 AM   #10
mxracer919
1979 CJ7
Oops, misread the rebate details. My bad. Where did you find the harness fro $404?
This is what I am trying to figure out too. Cause through different places I have found that the 10110 and 10601 and I cannot find what the difference is........idk
Old 01-31-2010, 07:40 AM   #11
Viencent
1982 CJ7
lol of all places AutoZone, can order it local and get it, for the cj7 it says the 10106 is the one I need
Old 01-31-2010, 07:54 AM   #12
mxracer919
1979 CJ7
Hmm, through the summit website it shows that I need the 10110 Maybe it is because of the column ignition....cause if you remove that from the filter on summit it shows both the 10110 and the 10106 Sucks cause the column ignition one is like $150 more on summit.
Old 01-31-2010, 07:56 AM   #13
ken78cj5
1978 CJ5
I used the 10110 harness and most everything was pre-terminated and encased in wire loom. I believe the 10106 is not preterminated and is not run in loom.
I am an electronics instructor and I can tell you that the 110 is the way to go. It has been a few years since I did mine, but I think the only wires that are not pre-terminated is the fuel sender, coil wire and the tail lights.
Ken
The one on the left is the 106 and the right is the 110.
Old 01-31-2010, 07:57 AM   #14
ken78cj5
1978 CJ5
Correction, the one on the top is the 106, bottom is the 110.
Old 01-31-2010, 08:01 AM   #15
mxracer919
1979 CJ7
So getting the 110 would be like buying the 106 and then adding the 70920 powerbraid from painless to it? If so that sounds like alot better of a deal. Thanks for the tip!
Glock Forum
