painless wiring harness? - JeepForum.com
post #1 of 19 Old 03-11-2007, 05:57 PM Thread Starter
quader400
im thinking about buying the painless wiring harness. i need to wire a 73 cj5 and the harness i have is pretty mangled and i dont really know where it all goes. if i buy the painless one does have good directions so i can wire it easily? thanks
quader400 is offline
post #2 of 19 Old 03-11-2007, 06:58 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Look into a 12 circuit EZ wire.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 19 Old 03-11-2007, 07:03 PM
kbtriumph
kbtriumph's Avatar
Get the EZ Wiring harness they have better instructions and are a lot less $$$. Look on e-bay there is a guy selling for a good price. I have used both and think that the EZ is better than the Painfull.
I would recommend the regular fuse rather than the mini. I always use the 21 circuit just because it is not that much more money.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #4 of 19 Old 03-11-2007, 07:41 PM
bigvill
I used a Painless, and it wasn't so PAINLESS.
bigvill is offline
post #5 of 19 Old 03-11-2007, 08:00 PM
CJ Chet
If you get the pre-terminated Painless harness, it IS truely painless! This one says '75-'86, but it should go into yours easily!
http://www.painlesswiring.com/webcat...rchField=10110
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #6 of 19 Old 03-11-2007, 08:06 PM
Scuter83
1974 CJ5
Why wouldn't you buy this one for a '73?
http://www.painlesswiring.com/webcat...rchField=10105
Scuter83 is offline
post #7 of 19 Old 03-11-2007, 09:03 PM
supraman1990
supraman1990's Avatar
1980 CJ5
The preterminated painless is great. I am getting ready to put one in my 80. I have inspected it and it truly does look painless.
supraman1990 is offline
post #8 of 19 Old 03-11-2007, 09:17 PM
CJ Chet
Not pre-terminated (plain wire ends with no connectors). The pre-terminated harness has all the connectors already installed. It's pretty much "Plug-and-play"!
I guess it's just a question of how "freindly" you are with wiring. I was a Technician for 35 years, but I still like the idea of plugging it in with minimum down time.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #9 of 19 Old 03-12-2007, 11:37 AM Thread Starter
quader400
do they make the pre terminated harness for the 73. im looking and cant find it please help, trying to order this fast. the 75 and up one comes preterminated but doesnt have the in dash ignition that i need???? how hard would it be to get the 75 harness to work on my 73 engine and ignition. the ignition is a huge part because i really really want the indash ignition. thanks for anyhelp
post #10 of 19 Old 03-12-2007, 12:11 PM
76cjeep
1976 CJ7
I've installed 2 Painless kits now, both in my 76 CJ's. They were pre-terminated and simple.
I'm not familiar with the EZ wiring so I can't give you an opinion on that.
1976 CJ-7---258 MPI, Borla header, flowmaster, NV 4500, Atlas, 35" MTR's, D44's with 4.88's, ARB's, RE springs, SOA, high steer, OBA, Hydroboost brakes,.........
76cjeep is offline
post #11 of 19 Old 03-12-2007, 04:02 PM
nichols077
i have bought a ez wiring harness but am waiting for warm weather to install it. the reason i went for it is becuase of the price.
nichols077 is offline
post #12 of 19 Old 03-12-2007, 04:23 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I have done 3 painless installs and I am getting ready to do another one. Pre-terminated was the way I went and it worked out great.
I have done work with stock harnesses all the way up to the centech one, they are all good if you know how wiring works. If you don't and want a cookie cutter approach to it, I would have to say the painless has the best tech support (as long as you can get ahold of them... they only work during the week).
Here are writeups if you want...
http://www.certifiablejeep.com/wiring1.php
http://www.certifiablejeep.com/hints/hints_wiring.php
http://www.certifiablejeep.com/thirdproject17.php (starts here goes for like 5 pages)
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #13 of 19 Old 03-14-2007, 03:13 AM
dimichele
Get the ez wiring harness 21 circuit and remove the wires that you don't need. You can print the Painless instructions off the web. I am getting ready to install mine as it is warming up. I've read both sets of instructions and both kits are seem pretty similiar.
dimichele is offline
post #14 of 19 Old 03-28-2007, 10:31 AM
Scuter83
1974 CJ5
Bringing this back.
I am going to be purchasing a wiring harness for my '74 with a 258ci in it. I am doing this because I just realised the PO doesn't have a fuse block in it right now for some reason. If I were to purchase the Painless harness without pre-terminated ends, how do I attach to various parts? I guess I am asking how I get new connectors, or do you have to splice into old connectors? Also, can anyone confirm that the '75 and up pre-terminated harness will work on mine, minus the in dash ignition problem?
Thanks,
Scott (<--- wonders why he bought this thing now )
Scuter83 is offline
post #15 of 19 Old 03-28-2007, 10:58 AM
jayhawkclint
1970 CJ5
...I just realised the PO doesn't have a fuse block in it right now for some reason.
That would be because the '74 didn't come with one from the factory. Just buy the EZ kit. You are wasting your money on the older Jeeps buying the expensive kit because there really isn't anything in the Jeep that needs a fancy connector. The '55-'75 truly was "Universal" as it was marketed.
'80 CJ-7 Wiring Harness, Painless... really? pumacat24 Jeep CJ Forum 16 04-19-2014 12:13 PM
Painless Wiring Harness CJ Runner Jeep CJ Forum 3 02-19-2009 07:22 PM
Painless wiring harness CJmadison Jeep CJ Forum 5 04-01-2006 06:43 PM
Painless wiring harness bamakrw Jeep CJ Forum 11 12-04-2004 12:08 PM
Painless wiring harness anyone? qualityhardware Jeep CJ Forum 13 06-02-2003 06:04 AM
