Painless #10110 install completed! - JeepForum.com
post #1 of 13 Old 07-16-2010, 10:26 AM Thread Starter
esearscj7
1983 CJ7
Just finished installing the Painless wiring kit #10110. Everything works! Whew! Everything went smoothly. The only area in the instructions that were kinda misleading was the sections for hooking up the Solenoid Alternator & Maxi-Fuse. I cobbled together this drawing from the instructions and it seemed to help me wrap my head around the hook up of those wires since they are not labeled according the instructions. This diagram is for Jeeps with HEI and Manual tranny. Maybe this will help someone else. PS- don't assume new parts are good. I had a new starter relay that was bad out of the box. Smoking battery cables are NOT good.
esearscj7 is offline
post #2 of 13 Old 07-16-2010, 10:47 AM
Jim1611
Jim1611's Avatar
Good to know it worked for you. I'm looking into getting one myself and good input on a product is always helpful.
Where at in Missouri?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 13 Old 07-16-2010, 11:29 AM Thread Starter
esearscj7
1983 CJ7
30 minutes east of KC.
post #4 of 13 Old 07-16-2010, 03:14 PM
southshore30
1982 CJ7
Just did mine too, it was actually pretty painless once I figured out my key switch was bad and I always had accessory power even with the key switch off. I cleaned up my other column and put it in and ta da! Very happy with the product. I may be having a issue with the electric choke wire but since I have a HEI I have a few extra B+ leads to work with. Going to chase down the issue with it first before I run a different wire to it. Glad it went well for others and I would recommend it to anyone. It aint cheap, but it saves a lot of headaches with 20+ year old wires.
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #5 of 13 Old 07-16-2010, 03:16 PM
Jim1611
Jim1611's Avatar
I'm a Missourian too. Not far from Hannibal.
My build thread
Jim1611 is offline
post #6 of 13 Old 07-16-2010, 03:31 PM
Newjeep75
Well Congratulations. I did the same on my '75 CJ5 about 5 years ago. I had the same problem with the instructions. But what I did find was that Painless really knows what they are talking about. Their help line is just fantastic. They helped me out a lot to get the project completed.
The truck hasn't stalled out since the new wiring install.
Todd.
Newjeep75 is offline
post #7 of 13 Old 07-18-2010, 11:32 PM
yahwhy
1982 CJ7
painless
yeah i too just finished a painless wiring,don't remember what part number but it was a 12 circuit streetrod kit, alot cheeper than jeep style harness,the only promblem i had was with the headlight switch couldn't figure how to use oe jeep headlight switch with painless kit, i ended up ordering a gm switch/w post, nut and wire connector from hotrod wires,much cheaper than what painless wanted for theirs[55.00],but ended up gettin burned on that, switch was junk/cheapchina, headlights on for more than 5 mins would start to blink, so ended up getting a good switch and headlights everything working great so far. but when i was serchin for the first switch and found hotrod wires i was kickin myself for not doing more research for wire harnesses hotrod wires has 12 circuit kits for like 100.00 cheaper than painless kit but hindsight i'm probally better off with painless, cause i really like there product/service.
yahwhy is offline
post #8 of 13 Old 03-12-2011, 01:27 PM
rclark678
I know this is from last year just got a question, my alt wire group and solenoid alt group have 2 red wires each. Do I use all 4 red wires or just pull the one labeled and the other 2 get rolled back? thanks in advance
rclark678 is offline
post #9 of 13 Old 03-12-2011, 01:38 PM
Patter
1981 CJ5
Going to do this too. Thanks for the heads up. Nice drawing . Not at all cobbled up. Would be nice to see some pics of your wiring, if you can. Need all the help I can get in this area!
Thanks
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #10 of 13 Old 03-13-2011, 08:16 PM Thread Starter
esearscj7
1983 CJ7
Hey rclark678, all four wires are used. The Red 787 wire is actually one wire that loops back into the wire harness . See my drawing. Hope this answers the question. As newjeep75 stated, Painless has a really good help line that you can call.
post #11 of 13 Old 03-13-2011, 08:59 PM
Davidnex
1979 CJ5
The choke wire is activated by an oil pressure switch, (not the oil gauge sender) both in same location review schematic
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #12 of 13 Old 03-13-2011, 09:15 PM
75*CJ
I'm south of KC...Joplin!
75*CJ is offline
post #13 of 13 Old 03-14-2011, 04:19 AM
rclark678
hey thanks, right after I asked I looked at the painless forum and found the answer.
She starts ,,so now I just need to figure out why my gauges aren't working. Hopefully it is just a bad ground...
alternator , battery , fuse , harness , maxi fuse , pain less , painless , painless harness
How Painless is the Painless Wiring Install? budacj7 Jeep CJ Forum 19 10-02-2016 06:56 AM
Painless Wire Harness #10110 hex Jeep CJ Forum 12 05-08-2014 10:18 AM
Anyone install a painless wiring harness? brownrecluse Jeep CJ Forum 26 10-19-2010 05:40 PM
painless install myzoo Jeep CJ Forum 17 03-29-2010 02:06 PM
76 CJ7 and Painless 10110 - backup safety switch maback Jeep CJ Forum 4 03-26-2007 07:02 PM
