pacesetter exhaust CJ5 - Page 2 - JeepForum.com
post #16 of 18 Old 07-17-2003, 05:54 PM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Well I think I notice a couple of things here and maybe this might be my problem.
I notice my shocks are on the inside of the frame and not on the outside like yours.
I took some pics to see about the layout, but I am starting to think I have a 75 frame or something. I know my 76 was built early and it appears to have a 75 gas tank, but the shocks seem to be in the way when I try to put on the exhaust.
See what you think. Let me know if I have something on the wrong side or what.
THEY ARE ONLY LAID OUT RIGHT NOW, NOTHING IS CONNECTED AND IT IS HANGING IN PLACE!!!!!
Thanks,
cb
http://f1.pg.photos.yahoo.com/bc/cb4...c=ph%26.view=t
http://f1.pg.photos.yahoo.com/bc/cb4....jpg%26.src=ph
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #17 of 18 Old 07-18-2003, 02:28 PM
Lightningdon
Lightningdon's Avatar
CB, mine is a '75 frame. Your's must be a '76 frame. One thing I see different in general layout is that your mufflers are way farther back than mine. My mufflers end about 12 inches if front of the rear axle. Looks to me like you'll have clearance issues between the axle and the exhaust. It may help to take a foot out of the pipes in front of the mufflers. That would bring the bends right over your axle, rather than the mufflers. Also, will your gas tank go in with that layout? Where your pipes come over the axle, mine are literally right below the side frame rails to clear the sides of the tank. My tailpipes actually exit between the spring and the frame where your's come all the way out back. I also had problems right off the headers. My pipes would not line up. I needed the initial bend to clear my crossmember. You seem to have a pretty straight shot.
BTW, the rig looks good! I hope to take my body off next Spring. I want to have the frame sandblasted, boxed and painted. I need to replace fuel and brake lines.too.
Don
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #18 of 18 Old 07-18-2003, 02:44 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
I just got done with all new brakes all around. It wasn't easy, but I think it is worth it.
As for the exhaust. I think the right side looks about right. I have a hanger that is supposed to attach to the body. As for the right side, it looks like the rear pipe is not even the correct one.
Oh well.
Anyone else out there put a pacesetter kit from 4wd hardware on a 76-83 CJ-5?
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
Exhaust - Seal between Heat Valve and exhaust pipe Woolys_CJ7 Jeep CJ Forum 1 01-22-2010 07:07 AM
Borla, Hedman or Pacesetter??? ssimko8094 Jeep CJ Forum 21 04-05-2009 06:51 PM
Pacesetter Header help!!! goat24 Jeep CJ Forum 8 03-22-2007 09:36 PM
Exhaust diameter for amc360+pacesetter... vladrulli Jeep CJ Forum 10 02-12-2007 02:21 AM
Are PaceSetter headers any good?? hfjeff Jeep CJ Forum 4 09-09-2005 06:49 AM
