Overheating! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Overheating!
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread Yesterday, 05:40 PM   #1
NHcjfan
1977 CJ5
Overheating!
Hello all. First post in this or any Forum, but have read many of your threads and saved countless hours by searching here.
Anyway, having an overheating problem. I just finished replacing intake manifold gasket. The jeep did not overheat prior to this. In fact it ran on the cool side. My question is... is there something I could have done while replacing the intake gasket that is causing it to overheat? Maybe just coincidence?
I am replacing the thermostat tomorrow AM but don't want to start throwing parts at it I don't need. Thanks in advance for the support.
NHcjfan is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:57 PM   #2
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
One step that many overlook (myself included) is burping the cooling system as per the TSM. It may seem like such an inconsequential thing, but absolutely imperative. Of course there are many symptoms and cures for overheating and in my case, I've run the course.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:53 PM   #3
NHcjfan
1977 CJ5
I will make sure I do that when I replace thermo tomorrow. I may need to clean my radiator as well. Just seamed strange I didn't have this problem before I changed the manifold gasket. I didn't see any ports I could have blocked.
Unread Yesterday, 06:55 PM   #4
NHcjfan
1977 CJ5
I will make sure to 'burp' it tomorrow when I do the thermo. Just seemed strange that this problem started only after intake gasket replacement. I didn't see any ports that could have been blocked. I may need to clean my radiator as well.
Unread Today, 03:23 AM   #5
ECJ-7
1976 CJ7
poke a small hole in the t-stat with an ice pick, it wont effect performance and will allow it to bleed itself.
ECJ-7 is offline   Reply With Quote Quick reply to this message
Unread Today, 03:56 AM   #6
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
What temp gauge are you using, and have you confirmed it's accurate?
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Today, 06:21 AM   #7
NHcjfan
1977 CJ5
Stock temp. gauge that I believe is at least somewhat accurate, never went above half way before I changed intake manifold gasket. I have an infared thermometer I can borrow from work later to check. What temp would be overheating? I know my thermostat is 195.
Unread Today, 07:31 AM   #8
turbogus
1978 CJ5
A possible reason this problem didn't rear it's ugly head is that in the manifold replacement you may have dislodged some crud that is now blocking a cooling passage or perhaps gumming up the thermostat. If you have a TSM, just follow the procedures and you'll get on top of it. I've been criticized for the great lengths I went to to get my 360 under control.
Unread Today, 08:39 AM   #9
WindKnot
WindKnot's Avatar
1977 CJ7
Here's a link to the 1976 Jeep TSM. (1977 s the same) http://oljeep.com/edge_76_tsm.html
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote Quick reply to this message
