Overhauling Rancho Leaf Springs - Tips Please - JeepForum.com
post #1 of 8 Old 01-29-2011, 06:22 PM Thread Starter
salemjeep
I've picked up a set of used Rancho 2 1/2" lift springs for my 1986 CJ7. The spring have some surface rust from sitting outside and I want to overhaul/clean them before I put them on.
Does anyone have suggestions how best to go about overhauling leaf springs?
What is the best way to deal with opening the clamps?
TIA
Kevin
salemjeep is offline
post #2 of 8 Old 01-30-2011, 12:06 PM
sanddrag
You could blast or wire wheel and paint them, but what I'd do is find or make a large enough tub for them to sit in, and go find a 5-gallon bucket of vinegar and let them sit in that for a couple days. It should eat all the rust away, leaving nice clean metal. Doesn't smell too nice, but it works well (on smaller parts anyhow).
sanddrag is offline
post #3 of 8 Old 01-30-2011, 12:10 PM
gpets
1981 CJ5
I wouldn't open the clamps.
gpets is offline
post #4 of 8 Old 01-30-2011, 12:16 PM
jpywell52
1979 CJ7
neither would I, you'll just wind up weakening them. You can also try the old trick used by cast iron restoration guys. Buy a kiddie pool or similar shallow container. fill it with water and add baking soda, not sure of the quantity. Then hook up a battery charger to a piece of metal and to the pieces you are cleaning. not sure of the polarity so check out this link. i did it with parts for an old plymouth of mine, worked great.
http://www.wag-society.org/Electrolysis/electros_1.php
jpywell52 is offline
post #5 of 8 Old 01-30-2011, 12:19 PM
jeepwhore
I've opened 'em numerous times by heating the bend with a torch but you have to be very careful not to heat the spring. As said, if you don't have to I wouldn't. Heating them and unbending a 90 deg. then heating again and closing it back up makes the clamps brittle and I've seen more than one break when closing them back up.
I'd just wire wheel 'em as best you can and give them the spray bomb treatment. Even if you take them apart the paint will wear off them where they rub anyway the first time you drive it so it's more of an exercise in futility than anything. Even a few mud baths and pressure washes will quickly reverse all your efforts so just go with the KISS approach.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #6 of 8 Old 02-01-2011, 12:05 AM
gpets
1981 CJ5
I concur, I have opened mine twice with a torch and some gentle work, but if you are just cleaning and repainting there is no need to separate the pack. The only time I have opened mine was to tune the suspension and shorten leaves.
gpets is offline
post #7 of 8 Old 02-01-2011, 07:44 AM
CSP
Personally I'd open them up and take the leaf pack apart. Paint the leaves with graphite paint and reassemble. Leave the tabs open on the clamps and drill a hole through them for a bolt to go from one side to the other. You get a bit more flex this way. The local spring company that I use for ubolts sells clamps which use a bolt rather than bending the tabs down.
CSP is offline
post #8 of 8 Old 02-01-2011, 09:15 AM
gojeepin
1983 CJ7
You could clean them with phosphoric acid and a wire brush. The acid both eats away and converts the rust while the wire brush let's you expose the rust.
I keep some in a cheap spray bottle all the time. In the end the phosporic acid cleans it up and puts a coating on them to prevent flash rusting... it's also a good primer.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
assembling leaf springs; are leaf springs identical for left and right side? pazur Jeep CJ Forum 8 07-15-2010 01:08 PM
New Leaf Springs? jeeprookie47 Jeep CJ Forum 10 07-07-2009 08:46 PM
Rancho springs any good? Blthomas Jeep CJ Forum 4 06-29-2007 06:31 AM
leaf springs rmballou Jeep CJ Forum 5 07-06-2006 09:20 AM
What leaf springs should I get? Curt Reinhardt Jeep CJ Forum 23 03-24-2006 04:50 PM
