Overhauling 80 CJ-7 with a 4.5BT Cummins - Page 3 - JeepForum.com
post #31 of 61 Old 11-30-2012, 05:30 AM
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
How is this project coming along?
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #32 of 61 Old 11-30-2012, 05:39 AM Thread Starter
Dre40
I just cleaned up my shop and got space to work on her now. I have leaf springs for it but was considering Coils? What do you think stay with leafs or build with coils?
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #33 of 61 Old 11-30-2012, 06:17 AM
youngjeeper11
1987 YJ Wrangler
Haha, do you really want to open that can of worms....?
I am planning on going to coils eventually, mainly because I think they are cooler....that is my soul reasoning haha, and I want to design the full suspension myself.
post #34 of 61 Old 11-30-2012, 02:40 PM Thread Starter
Dre40
LOL well I had thought about it. but I'm going to roll with my leaf springs. lol Hey do you know if a standard Chevy 350 clutch will bolt up to this flywheel? or do I need to order a special one?
Dre40 is offline
post #35 of 61 Old 11-30-2012, 05:58 PM
kappa505
1980 CJ5
Wouldn't a Perkins diesel be an easier swap. They were used in jeeps in the late 70' s.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #36 of 61 Old 11-30-2012, 06:01 PM Thread Starter
Dre40
It's posable but I already have the Cummins. And I'm not sure how the adaptability is with the Perkins.
Dre40 is offline
post #37 of 61 Old 12-01-2012, 07:01 AM
youngjeeper11
1987 YJ Wrangler
For me the best thing about the cummins is the availability of parts, and aftermarket parts, you can make some serious power from a 4BT
What Flywheel do you have again? If it was a chevy setup to begin with, like say with an SM465 I would say a standard chevy clutch would probably work, I think you can get up tp an 11" clutch then.
post #38 of 61 Old 12-01-2012, 07:26 AM Thread Starter
Dre40
Yes it's a P30 Chevy set up using a SM-465 so I think a standard Chevy clutch will work to.
Dre40 is offline
post #39 of 61 Old 12-06-2012, 01:25 PM
twiisted71
Yup reg SBC stuff is all you need. Dre you could always do as I am. Leafs out back, coils (coilovers) up front. I figure it worked beautifully for nearly every car manufacturer out there for decades. Plus you could make me a nice deal on a pair of your leafs!
twiisted71 is offline
post #40 of 61 Old 12-08-2012, 08:02 AM Thread Starter
Dre40
I had thought about that. But not sure what coils to use and weather I want to go through the trouble of setting it all up. Was thinking of going to the U-Pull and looking around for ideas. I need to pick up a steering box anyways.
Dre40 is offline
post #41 of 61 Old 12-13-2012, 08:48 AM
twiisted71
Here is what and who I went with... These things ain't cheap! I'd never given it much thought but I didn't know they were this high until I started shopping
http://www.polyperformance.com/shop/...t-p-30147.html
I am using a '78-9 F150 axle so my geometry is kinda done for me. What front axle you gonna run? I have an early Bronco Dana 44 housing that uses the same mounts (easy set up) for sale. It should match the 5.5 on 5 bolt pattern and width pretty close of the CJ rear It is driver's drop, so you'd need a more modern GM TC.
post #42 of 61 Old 12-13-2012, 08:57 AM
youngjeeper11
1987 YJ Wrangler
http://www.polyperformance.com/shop/...t-p-30147.html.
Do you still need to buy the coils then too?
I was looking at king shocks, I want to do coilovers all four corners eventually.
post #43 of 61 Old 12-13-2012, 07:55 PM Thread Starter
Dre40
well I have a 3/4 ton D44 already with high steer set up. the rear is a AAM 14bolt I think I'm going to stay with leaf springs for now get the rig running wheel it a bit then save the $ and change to a 4 link.
Dre40 is offline
post #44 of 61 Old 12-13-2012, 08:09 PM
twiisted71
Yep that price is just the shock. One thing to remember, if you aren't racing it don't get sucked into the remote reservoir, double billy bad-***, doo-hickey shocks. Those things are for Baja racers, but they look complicated so it must be better for everything, right?
Coils were reasonable, considering. you'll also need bolts and mounting tabs and hoops/towers.
post #45 of 61 Old 12-13-2012, 08:15 PM
twiisted71
[QUOTE=Dre40;14605708]well I have a 3/4 ton D44 already
Thats what I started with and then swapped the outers onto an F150 Dana 44 housing with 1/2" thick tubes like the F250s. I already knew I wanted to stretch the front and didn't want to stretch the frame and have shackles/mounts out there still. So going with the radius arms will simplify everything. Its going to be my DD so I didn't want to go crazy with suspension designed for max travel.
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
4-door Cummins CJ-7 @ Lima Jambo jeepskate Jeep CJ Forum 13 05-30-2011 06:04 PM
Overhauling Rancho Leaf Springs - Tips Please salemjeep Jeep CJ Forum 7 02-01-2011 09:15 AM
cummins swap MooseMarine Jeep CJ Forum 6 01-21-2011 09:58 PM
Cummins Willys Radiator Issues 1952m38a1 Jeep CJ Forum 0 03-01-2009 05:32 PM
