over heating problems. need help. - Page 2 - JeepForum.com
post #16 of 25 Old 05-20-2013, 12:46 PM Thread Starter
jesseg
The motor is timed correctly and the carb is tuned great. Runs great on the trail but as soon as I let it idle or start crawling the temp jumps extremely high.
Semper Fi
jesseg is offline
post #17 of 25 Old 05-20-2013, 12:49 PM Thread Starter
jesseg
Wellmax
Yes I custom fabricated a shroud it has no holes in it it completely covers the whole radiator
Semper Fi
jesseg is offline
post #18 of 25 Old 05-20-2013, 08:36 PM
82JeepCJ7
1982 CJ7
You need more low speed air flow. Get a shroud.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #19 of 25 Old 05-20-2013, 09:43 PM
lucdog
lucdog's Avatar
1980 CJ5
What exact fan are you using? If the blades flex to much they won't pull any air. As a test, run the engine at 1500 RPM's with the hood up. Use you hand on the carb to hold the RPM's, watch the fan blades , and feel for air flow with the other hand. If the air flow slows (decreases) from idle, a non Performance fan would be my next step.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #20 of 25 Old 05-21-2013, 12:03 AM Thread Starter
jesseg
I just bought a new fan that supposedly pulls more air at low rpm's. I'm going to see if that works.
Semper Fi
jesseg is offline
post #21 of 25 Old 05-21-2013, 09:44 AM
braguenavy
You could probably find a pusher fan to mount in front of your radiator, between the radiator and the grille.
braguenavy is offline
post #22 of 25 Old 05-21-2013, 07:57 PM
lonetrader
1975 CJ5
What temps do you consider too high. What is your normal operating temp? Your normal op temp should be around 190. 220 is acceptable when running slow. What about a solid 6 blade 17" fan.
lonetrader is offline
post #23 of 25 Old 05-21-2013, 10:40 PM Thread Starter
jesseg
At high rpm's the temp is at 215 at idle or a slow crawl it jumps to 250-260 almost instantly. And regarding the pusher fan I have almost no room in between the grill and radiator I have 1 and 3/4 inch and in between the fan and radiator I only have about an inch. I got a new low rpm fan and I bought some liquid for the radiator that supposedly drops temp by 20. I'm going to see if this works.
Semper Fi
jesseg is offline
post #24 of 25 Old 05-23-2013, 05:04 PM
lonetrader
1975 CJ5
How about a pic or 2 of fan shroud and fan, front of jeep. Your custom shroud could be the problem. Remove it and compare your temps. Do you have an automatic trans? If it connects to the radiator that could be a partial problem. Hook your trans up to a cooler direct bypassing the radiator. I am thinking your shroud is the problem.
post #25 of 25 Old 05-23-2013, 07:38 PM
LumpyGrits
You more than likely will need to put vents in the hood so the engine bay can 'dump' the hot air that is trapped with the larger engine.
How much room do you have in front of the rad for a 'pusher' fan?
LG
LumpyGrits is offline
cj-5 , overheating , problems
