Out of the box weber carb adjustments - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Out of the box weber carb adjustments
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 06-05-2013, 06:16 PM   #1
Mlaughlin8
1980 CJ5
I know nothing about carbs, but I know I have a worn out weber that needs a rebuild, so I want to get a new weber 38 from Quadratec. Will it be adjusted correctly out of the box? Or will I have to play with it some?
Mlaughlin8 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:23 PM   #2
swatson454
swatson454's Avatar
1983 CJ7
I think I'd hold off on a Q-Trac "Weber". See if you can get ahold of Tom at Redline (800-733-2277 #7345) and he'll fix you up with exactly what you need and it'll be a genuine, made in Spain Weber. Not that knock-off junk.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:55 PM   #3
Mlaughlin8
1980 CJ5
Why do you say " knock off"? Are they not redline webers? What are they then?
Unread 06-05-2013, 07:07 PM   #4
almostdonecj
Fairly certain you will need to play with it some. FWIW, I have a weber 38 on my CJ and I don't like it at all. I have followed the adjustment/set up instructions to the letter, and it still runs rich, gets crappy mileage and has a really sensitive throttle response that sucks offroad.
I have a MC2100 in my garage waiting to be swapped in.
almostdonecj is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 07:08 PM   #5
uptillnow
uptillnow's Avatar
Just a heads up...
A Weber from Spain that has "Weber" cast into the body is a Genuine Weber.
If the other guys carburetor has a RED "W" sticker and does not have Weber cast into the body, you probably have a carburetor that is a copied made in China.
My upset is they are calling it a real Weber and it is not, it is a Chinese copy.
Playing some licensing game. At your expense.
Buyer be aware.
UPTILLNOW
uptillnow is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 07:11 PM   #6
swatson454
swatson454's Avatar
1983 CJ7
Have you noticed in all the ad pictures, they have the carb spun around so you can't see the sticker
Shawn
Unread 06-05-2013, 07:11 PM   #7
uptillnow
uptillnow's Avatar
If you would like to try to tune this thing before you change it out call Tom at REDLINE 800-733-2277 ext 7345. Tell him about this forum and you bought one of REDLINE's weber conversions and see what he has to say.
There are many threads with some real tuning on this forum as well.
UPTILNOW
Unread 06-05-2013, 07:15 PM   #8
uptillnow
uptillnow's Avatar
Shawn
Anything but the truth.
It is a Chinese copy made and copied in China.
UPTILLNOW
Unread 06-05-2013, 07:16 PM   #9
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think I'd hold off on a Q-Trac "Weber". See if you can get ahold of Tom at Redline (800-733-2277 #7345) and he'll fix you up with exactly what you need and it'll be a genuine, made in Spain Weber. Not that knock-off junk.Shawn
I second this advice. If you sweet talk Tom, he may even throw in the correct jets, emulsion tubes, and air correctors for your specific application.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 09:26 PM   #10
Mlaughlin8
1980 CJ5
Thanks for the advice, I guess I'm going to try to rebuilt my current weber before I drop the coins for a new one.
Unread 06-06-2013, 02:02 AM   #11
BagusJeep
BagusJeep's Avatar
1981 CJ7
The 38DGMS etc. will run well out of the box and you can get them up and running in a few hours and wonder why you persevered for so many years with the old BBD. Genuine Weber is the only Weber to go for, so look at your old one and decide what you have. Genuine Webers are quality products, very rebuildable, very tunable and easy to work on.
However as said you can adjust the jet sizes etc to better suit your application, elevation etc.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 07:15 PM   #12
Mlaughlin8
1980 CJ5
Alright!!! Positive feedback.
