Our '72 CJ5 project "Karis" - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Our '72 CJ5 project "Karis"
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-19-2013, 06:50 PM   #106
skizriz
skizriz's Avatar
1978 CJ7
Originally Posted by WSS View Post
Where were you yesterday when I needed advice? Oh man. Too simple. I could've made it slotted and then I would have retained my adjustable goal.
Throw that out there as a "TOW BAR UPDATE".
Dang, I welded that puppy solid too.
Thanks, I had my head shoved deep in that box. I was in the "get it done so I can wheel" mode.
Now you will have a broken down buddy offering a case of Sam Adams if you can come and give him a tow home.
Guess somebody else with an adjustable bar will get to enjoy the cold brews...
I don't know if it would work or not. It the jumbled up mess I call my mind, it seems like it would.
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is offline   Reply With Quote
Unread 04-19-2013, 06:59 PM   #107
WSS
Ps:91
WSS's Avatar
1972 CJ5
Without question it would work. My old one was a triangle with ears. Probably put the brace closer to the shackle mounts and have one end fixed and the other slotted with a big bolt (5/8 or even 1/2) to tighten when properly adjusted.
Yep, this may be a call back to the drawing board, I don't wanna miss any gratuity
www.metaltechus.com
Our Yellow 72 CJ5 build thread
Yellow Jeep club member #73802
WSS is offline   Reply With Quote
Unread 04-19-2013, 09:23 PM   #108
WSS
Ps:91
WSS's Avatar
1972 CJ5
Skiz, I put the pics on your build thread. Let me know if it's what your looking to see.
WSS
www.metaltechus.com
Unread 04-19-2013, 09:51 PM   #109
skizriz
skizriz's Avatar
1978 CJ7
WSS
I think ya got the wrong person.
Sent from my iPod touch using JeepForum
Unread 04-19-2013, 10:05 PM   #110
WSS
Ps:91
WSS's Avatar
1972 CJ5
DUH! Sorry to cloud your thread! I just deletd it over there
www.metaltechus.com
Unread 04-19-2013, 10:11 PM   #111
WSS
Ps:91
WSS's Avatar
1972 CJ5
Originally Posted by ASteve View Post
On another note could you possibly take a photo of your power steering hose where it connects to your steering box. I just want to see how much room you have between the radiator and the hard lines.
SC
OK, back on track.........
I got ahead of myself here.
SC, here are the pics! LOL Let me know if it shows what your looking for.
Cheers!
I'm going wheeelin manana!
www.metaltechus.com
Unread 04-19-2013, 10:18 PM   #112
Jr76
Junior Member
1976 CJ7
Well it looks like you should start over... I will be down in the am to pick up the "scrap" tow bar.
PS can you weld on some mounts for me?
Jr76 is offline   Reply With Quote
Unread 04-20-2013, 12:24 AM   #113
8pitcher
bad*** jeeper
8pitcher's Avatar
WSS I got your stuff in the mail thank you a lot! I will send the money when I get money but right now I gotta fix the death wobble on my Jk and that will be over $300 so as soon as I can ill get that big chunk o'change out to ya. And thanks again everything looks great
Built Not Bought #640[/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote
Unread 04-20-2013, 06:04 PM   #114
ASteve
ASteve's Avatar
1972 CJ5
WSS.
Thanks a TON!
Perfect.
SC
http://www.astevecali.com
ASteve is offline   Reply With Quote
Unread 04-20-2013, 09:25 PM   #115
EgulAye
EgulAye's Avatar
1980 CJ5
Nice thread WSS.
btw, that wiring braid you are using cleans up real nice on the ends by folding it in. You just tuck the end down into itself and presto.
1980 CJ5, w/ a 232 and Carter YF
Do you give the Jeep wave at night when they can't see you?
EgulAye is offline   Reply With Quote
Unread 04-20-2013, 09:55 PM   #116
WSS
Ps:91
WSS's Avatar
1972 CJ5
LOL, ya drive down, I'll fit you up. It towed perfectly today. i stayed under 60 just cause. But it really pulled nice
No worries, Consider it a early Xmas present. Glad someone could use the stuff.
WSS.
Thanks a TON!
Perfect.
SC
Excellent, not much room I see. Had never really noticed. I have a three core but would like to put in a 4 core someday.
Originally Posted by EgulAye View Post
Nice thread WSS.
That stuff is cool, Thanks for the tip. I'll try it . Weird how it tightens up on itself. reminds me of those straw finger cuffs you would get at fairs and pizza places.
Cheers!
www.metaltechus.com
Unread 04-26-2013, 12:32 PM   #117
WSS
Ps:91
WSS's Avatar
1972 CJ5
We took her to silverwood last weekend! Had a blast. Love the open feeling of the Jeep compared to the Scout. Drove nice only had one problem that slowed us down, that was the nylon tube I used to plumb in the OBA was not heat resistant enough and popped two times. I had extra tube with me, so I was able to air up for the tow home. I went to my local hose guy (US Hose) and he fit me up with some teflon inner SS braid for the main output of the compressor to the manifold and some DOT air line to replace the "not as temp resistant" tube I had used. I probably won't be able to test until on the trail and crawling at 2mph (no cool air flowing) and then trying to air up.
I am tearing into the dash this weekend. I have most of what is needed to get er done.
Also sorted out the belt situation. The PO had them routed wrong (or just not the way I liked em LOL). I now have NO pump squeal. changed the config from one belt at about 70% contact to two belts at about 105% contact and fill the groove better, not sitting so deep. Once I was happy with the belts and lengths, I made a sticker for under the hood to remind me if I lose or it is too shredded to read.
Everyone have a great weekend and hope y'all enjoyed the FULL MOON!
WSS
www.metaltechus.com
Unread 04-27-2013, 06:27 PM   #118
WSS
Ps:91
WSS's Avatar
1972 CJ5
Dash start........
Decided to pull the whole dash out to cut it on the CNC table. It makes better cuts than my sawzall. The cage was a little bit of a problem around the glove box area but just a few bends and out it came. Easy enough to straighten when back in and anyway, the door covers it LOL.
Laid out all the parts I have been collecting over the last few months. Did about three hours of drawing to get it right. Still need to actually cut, maybe later today.
WSS
www.metaltechus.com
Unread 04-27-2013, 09:03 PM   #119
WSS
Ps:91
WSS's Avatar
1972 CJ5
Got some of the cutting done. Still need to get the actual switch panel done. It will be brushed aluminum with 10 switches and two 12v plugs. Went well. Most of the stuff fit good, maybe a touch with the grinder or die grinder to knock off slag and clean up. The aluminum is 5052 instead of 6061,it was cheaper but cuts different. more of a rounded bevel rather than tapered.
To cut the dash, I covered the parts that were to be left with masking tape, not the best thing but kept the smoke and dingle berries off of the paint. I have a lot of details keft to go but the main outline is done.
www.metaltechus.com
Unread 04-27-2013, 09:11 PM   #120
skizriz
skizriz's Avatar
1978 CJ7
Pure Jeep porn.
