Our '72 CJ5 project "Karis" - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Our '72 CJ5 project "Karis"
Save at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer PurchaseFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 08-17-2013, 02:12 AM   #166
WSS
Ps:91
WSS's Avatar
1972 CJ5
Well, I'm back at it! Gonna drop some more dosh on the old girl. The carb seems to be hitting the "boiling" point due to the cramped space and some left over smog gear. I am putting on some headers that will block the exhaust crossover port, this should fix the over 350 degrees that is right under the carb. The headers were found locally on CL, brand new ceramic coated patriots, nice 16ga tubes and thick flanges, complete with collectors and copper gaskets. They are the center dump shorty style and should clear the over built motor mounts OK, if not it will be just a touch with the die grinder on the mount to get a little clearance. Next will be a beautiful Edelbrock (26014) airgap with the new edurashine finish, looks like a polished cloisenne button. Also got a nice fuel pressure reg and filter to drop the pressure a little. After all that, I figured why not get some polished, fabbed valve covers! I'll post up the project pics as I get started. Still waiting on some parts.
Oh ya, getting a 3hp hi-torque starter too. The old one is turning slow due to the flooded, hard starts. I think it has a short in it too, if I leave the master switch on for more than a day, the battery is dead.
Bought a front driveshaft from Tattons last week, look forward to getting that installed as the old 1.25 shaft has some up and down play in the slip joint. The new one will be 2" and .120 DOM with a longer slip joint. I've not had any trouble with the old DL yet, but know it is not too far out, I'll keep the old as a trail spare.
WSS
www.metaltechus.com
Our Yellow 72 CJ5 build thread
Yellow Jeep club member #73802
WSS is offline   Reply With Quote
Unread 08-17-2013, 05:42 AM   #167
skizriz
skizriz's Avatar
1978 CJ7
I had a problem with mine loading up while playing in the rocks a while back. It turned out the bouncing of the rocks, and a slight incline, was enough to bounce my choke flap about half way closed.
Made it a bear to start when warm.
A $.10 spring took care of the problem.
Sent from my HTC One SV using JeepForum
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is online now   Reply With Quote
Unread 08-17-2013, 11:24 AM   #168
WSS
Ps:91
WSS's Avatar
1972 CJ5
Same symptoms at first, just inclines and bouncing, then parking on flat ground to to get bean dip and cheetos. Annoying to get all happy to hit the trail and the thing takes 30 seconds to start and when it does the family is freaked cause they don't want to get stranded and it smells like straight gas or a "gross polluter".
WSS
www.metaltechus.com
Unread 08-17-2013, 02:04 PM   #169
WSS
Ps:91
WSS's Avatar
1972 CJ5
Just went out and pulled the air cleaner and found the choke will flop around when it is released and warm. I'll need to look further into it to see were to put a spring.
Thanks!
WSS
www.metaltechus.com
Unread 08-17-2013, 02:41 PM   #170
skizriz
skizriz's Avatar
1978 CJ7
Thanks!
WSS
Mines a MC2100 with a manual choke. Let me know If you need a Picture.
My spring Just puts slight tensión on the arm to keep the flap from closing, but Its weak enough for the choke to still be operational.
Unread 08-24-2013, 03:34 PM   #171
WSS
Ps:91
WSS's Avatar
1972 CJ5
Mine is electric with a stout pull on it. A weak spring should cure it as well. During the top end re-do, i'll get it squared away. The needle and seat on my carb is spring loaded as well. Must be the key to Jeeps that rock and sometimes roll LOL.
www.metaltechus.com
Unread 08-24-2013, 03:44 PM   #172
WSS
Ps:91
WSS's Avatar
1972 CJ5
I have managed to get all the hard goods together and some of the soft stuff (gaskets, fasteners, fittings) for the top end re-do. What i lack is time. I had intended to start yesterday and work through the weekend but Thursday night, the hydraulic pump hooked to our 100t press started making some scary noise and had to be addressed, simple bearings on the armature but set me back a day. Today I had to dig a hole to pour some concrete to secure my kids clubhouse from turning over due to the new zipline attached to it, couldn't wait, another day behind. So, I managed to get the new Tatton's Driveline installed, what a difference! The thing is huge plus I have a spare front now.
Patriot heades (ceramic coated!)
Edelbrock airgap w/endurashine OH YA!
fabbed/polished valve covers
3hp hi torque starter
Gaskets and stuff
Not top end stuff but, BTF diff cover
Tattons driveline
stock vs new HD DL
www.metaltechus.com
Unread 08-24-2013, 04:00 PM   #173
skizriz
skizriz's Avatar
1978 CJ7
Jeep porn!!!!
Unread 08-25-2013, 06:54 PM   #174
WSS
Ps:91
WSS's Avatar
1972 CJ5
Tore into it today. Ready for assembly sometime soon.
Before tearing:
After tear down and surface prep:
www.metaltechus.com
Unread 08-25-2013, 06:59 PM   #175
WSS
Ps:91
WSS's Avatar
1972 CJ5
Everything looks like a go. The Patriot headers fit without any mods or dimples. Nice when it works that way. I will still need an exhaust shop to tie in, but that was expected. I am using some layered copper/carbon gaskets for the header to head seal, they are supposed to be leak free and for troublesome headers. The valve cover gaskets are steel reinforced silicone and fairly thick, they should be leak free too. I watched some you tube vids for leak free intake install and think I got a grasp of it.
www.metaltechus.com
Unread 08-27-2013, 11:03 PM   #176
WSS
Ps:91
WSS's Avatar
1972 CJ5
Spent a few hours this evening and got the intake bolted down and torqued and one header up and torqued. Set the valve covers on to get a glimpse of what it will look like. I will be able to spend the afternoon Wed working on it, maybe get the starter on and wired as well as the distributer.
www.metaltechus.com
Unread 08-28-2013, 05:51 AM   #177
roboto65
roboto65's Avatar
1976 CJ5
Good God someone get my sunglasses That looks great .
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote
Unread 08-28-2013, 09:07 PM   #178
boarderofsnow
boarderofsnow's Avatar
1979 CJ5
Hey brother. Just a word of advice on those chromo valve covers. Make sure you sand down the finish where the gaskets mount up. The finish will often keep those valve covers from sealing properly which lead to leaks. Other than that man looking good! Bet your happy, happy, happy to get those upgrades installed. Good luck!
J.P.
President / Co-Founder
4 Wheel to Heal
john.purser@4w2h.org
www.4WheeltoHeal.org
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal http://www.jeepforum.com/forum/f304/...-heal-1338074/
Build Thread http://www.jeepforum.com/forum/f8/19...iller-1194117/
Facebook https://www.facebook.com/#!/boarderofsnow
boarderofsnow is offline   Reply With Quote
Unread 08-28-2013, 11:44 PM   #179
WSS
Ps:91
WSS's Avatar
1972 CJ5
Thanks, you can start a fire if you leave it in the sun and hold some kindling over it LOL
Yes very happy indeed. It may be over the top but it sure feels good to do it.
The valve covers are fabbed aluminum and have a billet/welded rail that is 1/4" thick, but I laid them on the kitchen table and noticed they both rocked a little (table is glass), so I tweaked em a bit by hand and then decked em flat on my belt grinder with a 220 grit belt, they have a nice grippy surface now. Thanks for the info, the ones I removed had the smooth chrome finish and ALWAYS leaked, no matter how hard you tightened them. The new gaskets are 3/16"" thick and steel cored silicone! No more leaky-leaky I hope.
A bit of a problem cropped up when I noticed a large "C" shaped ring laying close to the rear oil return hole in the head, appears to be a valve stem seal clip that broke off and on a closer look, the valve retainer clips are gone BUT the valve has not dropped, so a piece must still be holding it up. I'll pull the retainer a.m. and see what the damage totals. I'll get a set of seals for sure, maybe not change them all but be ready incase it looks like dryed, hard stem seals everywhere.
www.metaltechus.com
Unread 08-29-2013, 11:36 AM   #180
WSS
Ps:91
WSS's Avatar
1972 CJ5
Ok, I turned the motor to get the valve up and can now clearly see both retainer clips still intact. So were good there, no gotta do's. I talked with my local speed shop guy and he thinks the seal clip was a left over from a seal change sometime ago, this seems right because the engine is not smoking and I cannot see how one could slip out and not look deformed. The plugs look wet but I know it is running rich from the carb flooding. So it is either a left over or it JUST happened, like last time I was out. I'll put it back together and run it for now.
I get to spend the rest of the day on it!
WSS
www.metaltechus.com
