Original fog light switch location? - Page 4 - JeepForum.com
View Poll Results: Which location should be used for driving light overide switch
Location one using original Jeep Fog Light Switch and location 10 62.50%
Location two use winch switch location with a "Look alike" switch to overide driving lights 6 37.50%
Voters: 16. You may not vote on this poll
post #46 of 90 Old 12-17-2013, 05:42 PM
keith460
Jeep. There's Only One
keith460's Avatar
Originally Posted by GlennLever View Post
Two is to use (what I am told) is the original location of the optional winch switch. The draw back is drilling a hole in the dash.
I just talked to my friend today who's dad use to own the 82 Jeep Jamboree and he said that the additional switch by the headlight switch was NOT for the winch. The winch had the standard corded remote like all others out there.
The additional switch was for the two windshield mounted off road lights the the Jeep Jamboree could be outfitted for, along with the optional fog lights that most other Jeeps could get. So, there was actually three (3) light switches all together on the Jamboree that could be optioned.
1) Standard Headlight switch
2) Factory Fog light switch (under dash)
3) Off Road lights switch (installed just below and to the right of the headlight switch)
1984 CJ-7 Renegade
keith460 is offline
post #47 of 90 Old 12-17-2013, 09:40 PM Thread Starter
GlennLever
GlennLever's Avatar
Boy I wounder what the chances are of finding one. I'll give it a try.
Thanks
Merry Christmas
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #48 of 90 Old 12-18-2013, 03:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I looked long and hard for a garage door that would open like that as I may want to put a lift in the garage at some point and did not want to waste all the space we created when we redid the garage. See below what it looked like before we started
I have a clock installed so there is not enough room
wow.....
what can I say that looks great.
Did you just double up on the joists?
John Strenk is offline
post #49 of 90 Old 12-18-2013, 06:05 AM
skizriz
1978 CJ7
Use the original cigerette lighter as a switch.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #50 of 90 Old 12-18-2013, 07:53 AM Thread Starter
GlennLever
GlennLever's Avatar
wow.....
The front roof rafters in the front were all doubled up, 2 x10 ties were installed on each rafter. The rafters in the rear were "converted" into upside down roof trusses. There is a three season pouch on the back side of the garage. the ceiling joists are one leg, the garage ceiling joist is another leg and the shed roof rafters are the third leg. we tied them all together to make triangles for strength. see below.
We did not use nails, but deck screws as fasteners. It is not coming apart or falling down. Have gone through four winters now with snow loads, right now there is ten inches of snow on it.
Please explain
Glenn R. Lever
My Web Site
post #51 of 90 Old 12-18-2013, 10:10 AM
skizriz
1978 CJ7
The cigerette lighter when pushed in will complete a circuit. Power wire coming in, wire going out to the relay. Push it in and lights come on.
Ive seen a few writeups where people do it for a hidden ignition power wire. No start unless the lighter is pushed in.
Or you could easily hide a small toggle under the dash to keep the original appearance.
skizriz is offline
post #52 of 90 Old 12-18-2013, 10:42 AM
WSS
WSS's Avatar
1972 CJ5
wireless keyfob?
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is online now
post #53 of 90 Old 12-18-2013, 10:50 AM Thread Starter
GlennLever
GlennLever's Avatar
Neat idea. I am still looking at the two original options.
Glenn R. Lever
My Web Site
post #54 of 90 Old 12-21-2013, 08:59 AM Thread Starter
GlennLever
GlennLever's Avatar
This is closer but no indicator light
Willys Kaiser Jeep CJ2A CJ3A CJ3B CJ5 Main Push Pull Light Switch U.S. Made
Glenn R. Lever
My Web Site
post #55 of 90 Old 12-21-2013, 02:01 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Looks like it even came with a 25A circuit breaker module.
***Chris***
chris87xj is offline
post #56 of 90 Old 12-21-2013, 02:29 PM Thread Starter
GlennLever
GlennLever's Avatar
I will not need it though as it will only be turning on and off the trigger circlet for the relay for the driving lights, if I use it still looking for a factory original driving light switch.
Glenn R. Lever
My Web Site
post #57 of 90 Old 12-21-2013, 05:59 PM Thread Starter
GlennLever
GlennLever's Avatar
I have an original rocker switch for Jeep fog lights.
Thought I would ask if anyone knows the wire codes.
The switch has four pins
The harness has three wires
red with white strip heave gauge, may be a 12 gauge (feed wire????)
Gray with a black strip light gauge (14 or 16 ground?)
blue or purple may be 12 , could be 14 (switched hot?)
If no one knows I will go play with it in the basement and let you know.
Glenn R. Lever
My Web Site
post #58 of 90 Old 12-21-2013, 06:00 PM Thread Starter
GlennLever
GlennLever's Avatar
Ok, this is what I found and it may not be correct for the original Jeep wiring.
My intention would be to use this switch to complete the circuit of the rely for my driving lights.
Jeep may have used it for the ground leg of the relay for the fog lights.
Red with the white strip is the ground
Blue is the switched hot
Gray with the black strip is the hot feed.
With it wired this way the indicator light comes on when the test light (driving lights (which are run with a rely (switch not carrying the load for the driving lights))) come on
and goes off when the test light is off.
Glenn R. Lever
My Web Site
post #59 of 90 Old 12-21-2013, 06:33 PM Thread Starter
GlennLever
GlennLever's Avatar
Ok, more information current poll has one more vote for the original fog light location than the other.
This is what the switch looks like mounted in the original holes. It is slightly offset below the headlight switch, and slightly proud of the dash.
It does not interfere with my legs so is a valid location.
Looking at this picture I have noticed that my Crown aftermarket clock as stop working again. I guess it is time to install the original clock I picked up awhile ago, and to think that I almost listed it on fee-bay two weeks ago
http://www.jeepforum.com/forum/f8/cj.../#post18110858
Glenn R. Lever
My Web Site
post #60 of 90 Old 12-21-2013, 06:38 PM Thread Starter
GlennLever
GlennLever's Avatar
See the above post so you do not miss before and after.
The switch can be snapped into the bracket two ways, any idea which was the original way, not that it makes much difference. The fog light pointing down with the beam crossed out might make some sense as that is the off position?
As this can be mounted and wired without effecting the second choice, leaving it open for investigation, I will do this first.
Glenn R. Lever
My Web Site
