Original fog light switch location? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Original fog light switch location?
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
View Poll Results: Which location should be used for driving light overide switch
Location one using original Jeep Fog Light Switch and location 10 62.50%
Location two use winch switch location with a "Look alike" switch to overide driving lights 6 37.50%
Voters: 16. You may not vote on this poll
Unread 12-10-2013, 12:18 PM   #1
GlennLever
GlennLever's Avatar
How / where were the fog lights on original jeeps equipped with fog lights turned on and off
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 12:42 PM   #2
wm69
OEM switch.
wm69 is online now   Reply With Quote Quick reply to this message
Unread 12-10-2013, 01:01 PM   #3
GlennLever
GlennLever's Avatar
Originally Posted by wm69 View Post
OEM switch.
Is there an internal light that comes on when the fog lights are on?
Glenn R. Lever
Unread 12-10-2013, 01:24 PM   #4
GlennLever
GlennLever's Avatar
Vote on Driving light switch location
First off you probably have heard me talk about this being a survivor Jeep and not wanting to stray away from that. Keep that in mind when you vote.
I have installed a set of KC driving lights on this Jeep (period correct). They are currently hooked up (through a relay) so that when the high beams are on the driving lights come on.
I would like to be able to override that so that the high beams can be turned on without the driving lights coming on (basically if the covers are on the lights I would still like to be able to use the high beams)
I have two options I am considering.
One is to use an original Jeep Fog Light switch to control the driving lights. It looks kind of add onish and hangs below the dash (I'm a tall guy and need all the leg room I can get.)
Two is to use (what I am told) is the original location of the optional winch switch. The draw back is drilling a hole in the dash.
Glenn R. Lever
Unread 12-10-2013, 01:39 PM   #5
yellow85cj
Which, or what other, location is easier to find in the dark by feel (while keeping eyes on the road)? Does it really have to be on the dash?
Currently in pieces - all of them
yellow85cj is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 01:47 PM   #6
wm69
I believe so. I don't have one, but see them for sale from time to time.
Looking at this I would say there is a light.
http://www.ebay.com/itm/Jeep-CJ-CJ5-...#ht_642wt_1362
I see them for $50-75 most of the time.
Unread 12-10-2013, 01:49 PM   #7
wm69
Quit screwing around and just buy this....
http://www.ebay.com/itm/SEV-MARCHAL-...#ht_210wt_1362
Unread 12-10-2013, 01:50 PM   #8
WindKnot
1977 CJ7
I would say if you have no plans for a winch, go there.
I'd rather be lost on the trails than found at home!
[b]Phoenix Rising- A Flame Off Restoration?[/b] [url]http://www.jeepforum.com/forum/f8/phoenix-rising-flame-off-restoration-1807257/[/url]
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 01:54 PM   #9
GlennLever
GlennLever's Avatar
I was the purchaser on this (carshopowner)
If it had been available when I did the install of the KC lights I might have.
They are not true driving lights though and I like the KC lights better anyway.
Glenn R. Lever
Unread 12-10-2013, 01:57 PM   #10
GlennLever
GlennLever's Avatar
I thought about a hidden location for awhile, but want to be able to see an indicator that the lights are on (they could be on with the covers on the lights and that would not be good)
No plans for a winch.
Glenn R. Lever
Unread 12-10-2013, 02:28 PM   #11
Renegade82
Renegade82's Avatar
1982 CJ7
How about a wireless connection and program it to your wristwatch?
Personally, I'd put it under the dash but on the other side, ahead of the shifter. Then it's visible at a glance and it's away from your knees.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 05:11 PM   #12
lugnut28
lugnut28's Avatar
The switch has a green internal light
lugnut28 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 06:37 PM   #13
FLynes
FLynes's Avatar
1976 CJ5
Jumping Jesus on a pogo stick! $550????!!!!!! I could buy so many other things with that money.....oh wait, my '76 never had fog lights as an option.
Nevermind, carry on.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 07:14 PM   #14
yellow85cj
Didn't you set up a relay for them some posts back in your thread? If so, put a light on the dash and the switch somewhere else.
With your skills and backup team (put me on the list for one of your center cap jigs when you start selling them ) you could probably put a little light in the speedo and the switch somewhere else.
Although the speedo may not be the best place (I rarely look at or in the direction of mine, as in turn signal can be on for miles )
Here's an idea, put a light where the upshift light was on the 4 cyl CJ's of the time.
The light really doesn't need to be anywhere near the switch. The bright light indicator isn't anywhere near the switch. The switch just needs to be easy to find without looking or reaching IMHO.
Unread 12-10-2013, 07:20 PM   #15
GlennLever
GlennLever's Avatar
Yes, all the lights are on relays.
Good thoughts, I will probably do one of the switches though, I 'm leaning towards the winch switch idea, but have the original fog light switch coming to see what it looks like.
Glenn R. Lever
