Ordered 3.73 but got 3.54 - keep, or return? - JeepForum.com
post #1 of 25 Old 07-10-2013, 02:41 PM Thread Starter
Colt44
1983 CJ7
I have a 1983 CJ-7, straight-six 258 with an automatic, AMC 20 rear end and running 31" tires.
My Jeep is driven mostly on the road, with a few excursions into light off-roading during hunting season and at a few other times.
I wanted to re-gear from 2.73 and ordered 3.73 (that selection was based on opinions from this forum and elsewhere), but due to an error I received a 3.54 ring & pinion instead.
The question: Is the 3.54 close enough, or should I go to the trouble and expense of returning it and getting the 3.73 as originally intended?
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #2 of 25 Old 07-10-2013, 03:19 PM
JustDandee
1983 CJ7
I think if you step back, that you are asking the same question again. Which is the best gear 3:54 or 3:73? If you made your decision already, feel comfortable with it and get the gear ratio you really want. We would all with just inject another round of opinions to filter through
Know what-a-I- mean?
JustDandee is offline
post #3 of 25 Old 07-10-2013, 03:34 PM
jp360cj
1977 CJ7
Carrier split for the Dana 30 is 3.54/3.73.. Do you have a 3.73 carrier? If not you'll need one.
not a lot of difference between the two, but if you ever go up to 33s the 3.73 perform better
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 25 Old 07-10-2013, 03:44 PM
Always2L8
1982 CJ8
There is a 5% difference between 3.54 and 3.73 gears (3.54/3.73 = 0.95). If you planned on 2000 rpm @ X mph with the 3.73, then you will be doing .95*2000 @ X mph with the 3.54. Only about about 100 rpm less. Not that big a difference IMO. If you keep the 3.54's you don't need a new carrier in the D30. The AMC20 is a wash as you need a new carrier.
Good Luck
Always2L8 is offline
post #5 of 25 Old 07-10-2013, 03:47 PM
Tigerjeep79
1979 CJ7
I'm running 32" tires and am happy with the 3:50 gearing I've got (9" Ford diff won't go 3:54). At 65 MPH on the highway, the 258 spins at 2500 RPM. I don't really want to rev it higher than that for long stretches, and with 3:73 gearing it would certainly have to rev higher.
Tigerjeep79 is offline
post #6 of 25 Old 07-10-2013, 03:49 PM
Balvar24
1979 CJ7
If you wanted 3.73, why not get 3.73?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #7 of 25 Old 07-10-2013, 04:09 PM
robs7
1983 CJ7
If you yourself decided on 3.73 then send your 3.54's back and get the right ones. Don't let someone else's mistake dictate your decision. Send them back. Been there, done that, and regretted it. Not with axles though. Just my two cents. Rob
robs7 is offline
post #8 of 25 Old 07-10-2013, 04:18 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
hey I have a set of 3.54's with only about 60,000 on them ... no broken teeth etc.... if you want shoot me a PM and lets talk...
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #9 of 25 Old 07-10-2013, 05:18 PM Thread Starter
Colt44
1983 CJ7
Good Luck
To recap from the first go-round, there's nothing hard and fast about the 3.73 gearing, and I was anything but dead-set on that particular ratio. Really, it's more a matter of getting away from the 2.73 now that I've got the 31" tires. I can't really see myself going to 33" because this is essentially a daily driver and I'm not going to be loading it up with performance parts. Really, the 3.73 was almost an arbitrary compromise between what I have and things that start with a 4.
However, I missed that I'd need a new carrier for the Dana 30 up front if I go with the 3.73 - if the 3.54 is that close and won't need a carrier change-out then it would seem to make sense to go with the 3.54 and move on.
(I already have a new carrier for the AMC 20, BTW.)
Colt44 is offline
post #10 of 25 Old 07-10-2013, 07:12 PM
Jeeper44mag
1978 CJ7
Personally, I think the 3.54 is a better choice if you are going to spend most of your time on the road.
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #11 of 25 Old 07-10-2013, 07:25 PM
only in a jeep cj
I second that for 31's, Id go 3.54. but that's just me
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #12 of 25 Old 07-10-2013, 10:36 PM
fourbtgait
1930 MK Patriot
I have 3.54's, 31" tires, T5 tranny.
Yes, it runs good on the highway, easily does 65-70 if I want, average 15 mpg at 60 mph.
I would rather have 3.73, but since 3.54 is so close, it's not worth changing out.
If I had a lower ratio like you, I would go 3.73. But whats your tranny? Overdrive helps a lot for me.
fourbtgait is offline
post #13 of 25 Old 07-11-2013, 01:53 AM
80cj
80cj's Avatar
1980 CJ5
I ran 31's with 3.54's in my 80 CJ-5 with T-176. It was an excellent combination.
80cj is offline
post #14 of 25 Old 07-11-2013, 08:50 AM Thread Starter
Colt44
1983 CJ7
Re-read the first post - Mine's an automatic.
Colt44 is offline
post #15 of 25 Old 07-11-2013, 09:07 AM
WindKnot
1977 CJ7
I also run 3.54 with 31s, but it's YOUR Jeep! Just make sure the axle ratios MATCH!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
