Opinions Wanted: Stroked 258 I6 vs. 283 - JeepForum.com
post #1 of 35 Old 08-02-2010, 06:35 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Ok, my current 83 has an Iron Duke mated to a (GM bolt pattern) T176/Dana 300 combo. My 80 (getting torn down for rebuild) has a 258 mated to the same (AMC bolt pattern) T176/Dana 300 combo. The Iron Duke just isn't going to cut it for my needs (I-75 driving 70/80 MPH) and some mild to medium trails. I looking for opinions from you guys who have a stroked 258 or a 283. I'm interested in the power, MPG, torque, etc! Which would you guys reccommend?
Thanks for your opinions
Rick
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #2 of 35 Old 08-02-2010, 06:56 PM
bruteboy
if the only choice is between a stroked 258 or a 283,I would say stroked 258.
bruteboy is offline
post #3 of 35 Old 08-02-2010, 07:25 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
What are your gears? A stroked 258 will not live long at high RPM on highway.
The 283 will rev higher and live longer at those rpm.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #4 of 35 Old 08-02-2010, 07:25 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Forgot to ask about reliability and are you Carb'ed or FI'ed. Thanks again!
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 35 Old 08-02-2010, 10:26 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I'd go for the SBC. V-8 is going to beat that one, probably in both power and cost.
Plus, once it's in, you're set up to drop a bigger SBC in whenever the mood (or money) allows.
Look at the TRUE cost of making any power with a stroked 258. Those "crate" stroker 4.6's claim 260hp.
A 283 stock is already going to likely have that much, and even more if it's even mildly modified. It's going to bolt right up to your bell housing, too.
I'm just not a big fan of the stroked 258's.....to me, it's a lot of money for how much power you ultimately make. Even if you miraculously managed to have one make 300hp, (unlikely) you could kill that figure for less money with a small block.
Now, if you lived somewhere that it was illegal to swap in an SBC, I might change my tune, but otherwise, go for the V-8.
Pacfanweb is offline
post #6 of 35 Old 08-02-2010, 10:32 PM Thread Starter
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Even though you are a Pac fan, thank for your input.
HEELS RULE
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #7 of 35 Old 08-02-2010, 11:34 PM
jp360cj
1977 CJ7
Originally Posted by SlikRic View Post
HEELS RULE
As much much as I hate to say it, I have to agree with Pac fan. Best mod i've done to mine was the V8 swap. Especially since your transmission will bolt up. Only question is...any particular reason you're wanting to go with a 283?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 35 Old 08-03-2010, 12:17 AM
Comanche_
I would go with the a bigger motor, Imo, the 283 is a good motor, but it's not a low down torque motor, it's small so it has to rev up to make much. IIrc, they are from the 50's/60's, so any that you find will not have valves and valve seats that will live long with modern unleaded.
I would look for a 350 or other larger SBC motor, unless you have or can get the 283 in good shape cheap.
Originally Posted by Z0NAJEEP View Post
With more stupid comments? Two retards don't make a right.
Comanche_ is offline
post #9 of 35 Old 08-03-2010, 06:04 AM
Pathkiller
1974 CJ5
How do you stroke a 258? Or are you talking about a 4.0L-based stroker? I have a 4.6L stroker in my Scrambler and love it. The 283 Chevy is as good as any other SBC (why not a 350? the block is the same size, if you're going to swap why not go with bigger displacement??), but is a whole different animal than an inline 6. Not a torque motor at all. High reving little screamer than makes HP at high rpm. Not a good Jeep engine. And to whoever said above that a 283 makes 260hp stock, I laugh. Stock ratings were in the 160hp-185hp range.
Pathkiller is offline
post #10 of 35 Old 08-03-2010, 07:17 AM
gmakra
Here are my thoughts on this the small block is a good little engine on the other hand its a higher reving engine here are the specs for the 283.
Model Designation: 150, 210 & Bel Air (all engines available) Wheel base: 117-1/2 Valve Location: In head Bore and Stroke: 3.875 x 3.000 Piston displacement, Cubic Inches: 283 Compression ratio: 8.50 Maximum Brake Horsepower: w/2-barrel carb: 185 @ 4600 RPM; w/4-barrel carb: 230 @ 4800 RPM Maximum Torque Lbs.Ft. @ RPM: w/2-barrel carb: 275 @ 2400 RPM; w/4-barrel carb: 300 @ 3000 RPM Normal Oil Pressure Pounds: 35
Now have a 4.7 stroker in my 85 Jeep and for the most part I really like it. The only area that has given me any headaches are the fuel delivery I tried the Howell TBI setup and it just did not work well. The Howell TBI is somewhat programmable but it really is very limited. The major problem is the very unequal length of the intake runners, which cause's more fuel to be delivered to the shorter runners and less to the longer runners.
I over came this with a Weber Redline TBI system which works very well. But I think I will go to a Weber Redline MPI setup.
Horse power numbers are are over rated its torque that moves you down the road. And a stroker has a lot of torque. Here is a picture of my 4.7 with the Howell adapter.
And here is a friends 4.9 stroker that he built for Bonneville for his World Fastest Jeep Comanche it puts out over 400 HP and over 400 Ft Lbs of Torque it was tested at the Hesco Dyno so its not a theoretical build.
Now you can go either way and both have their advantages and disadvantages. Building a Stroker has a very " HIGH GEE WHIZ FACTOR" and you can go from mild to wild but its more of a old school hot rodder thing where you have to experiment to get that right combination to make it work. A SBC has all kinds of stuff off the shelf so it more an assembly type build.
And what ever you do dont buy a pre manufactured stroker every one of them is garbage. Mine started out as a Golen and lasted less than 5000 miles (poor assembly) My current version is 10,000 and still going strong and it will last a really long time.
gmakra is offline
post #11 of 35 Old 08-03-2010, 09:04 AM
Pathkiller
1974 CJ5
Everyone quoting HP numbers on 283s needs to take a lesson on the difference between gross and net HP ratings. After 1971 all HP numbers are net ratings, which are 25-30% lower than gross ratings. So take your 185hp (gross) 283 and subtract 25% and it puts out a whopping 139hp (net). Even a stock 4.0L was 180hp (net). No comparison. Sure, the fuel injected high-zoot version of the 283 put out 283 hp (gross, only 212 net), but try finding one of those nowadays. Even a modestly built 4.XL stroker will put out 240hp (net) with ease, and up close to 300 lb/ft of torque. A stock 2bbl 283 only put out 275 lb/ft at 2,400rpm.
Here's a good discussion on the comparison between a 4.XL stroker and any small block V8. Jeep Strokers • Stroker Horsepower & Torque Numbers VS. Small Block V8's
post #12 of 35 Old 08-03-2010, 10:10 AM
1986cj
I vote for the SBC. You would have a great, dependable motor, with parts available on any parts house shelf, and the best assortment of aftermarket parts available for half the price of a good stroker.
1986cj is offline
post #13 of 35 Old 08-03-2010, 11:05 AM
swatson454
1983 CJ7
Strokers are all well and good but you can build a 400Hp 350 standing on your head.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #14 of 35 Old 08-03-2010, 11:59 AM
243
1978 FSJ Cherokee
I say go with the 283 and get it on the road and have fun; then, follow it up with a SBC 383 STROKER in your spare time and then your smile will really kiss your ears
Dave's 78 Build
243 is offline
post #15 of 35 Old 08-03-2010, 12:06 PM
Pathkiller
1974 CJ5
Which would be fine if the OP had asked about building 400hp 350's. He didn't, he specifically asked for pros and cons of an inline stroker vs. a 283.
chevy , engine swap , iron duke , sbc
wanted opinions on 1981 CJ7 benullman Jeep CJ Forum 2 05-23-2010 01:19 PM
Engine opinions wanted! pawillys Jeep CJ Forum 5 12-16-2009 08:24 PM
opinions wanted Por15 this? rays84cj7 Jeep CJ Forum 4 02-23-2008 06:44 AM
Your opinions wanted on this CJ somewherre Jeep CJ Forum 7 03-24-2007 11:16 AM
Opinions wanted Pick01 Jeep CJ Forum 7 11-02-2006 06:03 PM
