Opinions on this 80 CJ7 - JeepForum.com
post #1 of 6 Old 09-14-2012, 05:55 AM Thread Starter
jdtopgun71
I am a newbie to Jeeps and really want a CJ7. I found this one online and wanted opinions. The guy said it is a straight 6 and 4 speed. Is the straight six the 258? Also which transmission might this be for that year? Any thoughts on the price?
http://eastnc.craigslist.org/cto/3214447947.html
jdtopgun71 is offline
post #2 of 6 Old 09-14-2012, 05:59 AM
daltonw
1981 CJ7
yes 258
daltonw is offline
post #3 of 6 Old 09-14-2012, 07:22 AM
Manhattan
1981 CJ8
That's a damn good looking CJ. If it's as clean as it appears, I'd jump on it before someone else does... now that you've broadcast the ad nationally ;-) Seriously though, if the rust has been removed properly (cut out, new metal welded in) and it's not loaded with Bondo, hidden rust, etc., it could really be a great Jeep.
I'd have guessed that to be a T-150 3-speed in that Jeep from the factory. Otherwise, it should be a T-176 - an option in 1980.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #4 of 6 Old 09-14-2012, 08:01 AM Thread Starter
jdtopgun71
Thanks for the info. I wanted to get some opinions from people on here with experience.
post #5 of 6 Old 09-14-2012, 08:18 AM
Greenedoggie
Looks like a nice CJ, but the devil is in the details. Make sure you crawl under it and check for rust in the frame, particularly in the rear sections. If you find a rusty frame, be prepared for a lot of work. Rust under forward roll bar mounts is also very common and a PITA to fix. Rusty floorboards is also frequent. Check the engine and trans for leaks. All CJ's like to mark their territory in some way, but you want to make sure there's nothing major happening. I also would check for prior owner stupidity - some of the backyard fixes I've seen are really unbelievable - and unsafe.
Having said this, if the underside checks out as well as the shiny parts, that price is pretty good.
Greenedoggie is offline
post #6 of 6 Old 09-14-2012, 09:10 AM
wkp
1980 CJ7
Good chance an 80 258 is an SR4 tranny. If reverse is left and up , its an SR4. If reverse is Right and down, its probably a T176.
wkp is offline
304 Cam Opinions? 79jeepincj7 Jeep CJ Forum 18 03-01-2011 10:04 AM
opinions on a cj-5 psbeaman Jeep CJ Forum 4 06-13-2009 08:37 PM
I could use some opinions. Tangible Demise Jeep CJ Forum 3 01-29-2008 04:44 PM
Need your opinions 81CJUSMC Jeep CJ Forum 12 01-13-2008 03:22 PM
cj or yj i need help, not opinions krayniac Jeep CJ Forum 6 01-13-2006 01:57 PM
