one piece shaft hole in hub - JeepForum.com
post #1 of 18 Old 05-15-2011, 09:40 PM Thread Starter
ms198
i got my one piece shafts installed and the realized that they came with a hole in the hub. wth is that hole for and how do i seal it up. all it will do is let mud into the drum brakes i just sank over 100 bucks into
ms198 is offline
post #2 of 18 Old 05-15-2011, 09:46 PM
only in a jeep cj
If the hole is about 5/8 or so big, its for a deep well socket to line up with the 4 backing plate bolts. No need to seal it
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 18 Old 05-15-2011, 09:49 PM Thread Starter
ms198
trust me there is a need to seal it. if i am not on the road i am in the mud, and i don't want my brakes packed with mud. i can rech the backing plate bolts with a wrench.
ms198 is offline
post #4 of 18 Old 05-15-2011, 09:57 PM
dtcohen
1980 CJ7
If it really bothers you that much then I would just find a rubber plug that will fit in the hole
dtcohen is offline
post #5 of 18 Old 05-15-2011, 10:00 PM Thread Starter
ms198
its not a perfect circle though.
ms198 is offline
post #6 of 18 Old 05-15-2011, 10:28 PM
bruteboy
rubber plug
bruteboy is offline
post #7 of 18 Old 05-15-2011, 10:39 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Home-Depot has all different sizes of rubber plugs.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #8 of 18 Old 05-15-2011, 10:49 PM
Ronzi
1983 CJ8
Its sealed when you slide the brake drum over it.
Ronzi is offline
post #9 of 18 Old 05-15-2011, 10:55 PM
dtcohen
1980 CJ7
that's what I thought
dtcohen is offline
post #10 of 18 Old 05-16-2011, 02:18 AM
80cj
80cj's Avatar
1980 CJ5
Wonder if there's a freeze plug that will fit.
80cj is offline
post #11 of 18 Old 05-16-2011, 06:40 AM
mcmud
1983 CJ8
It reads as though this hole may be in or near the center of the hub, not the one that we might expect to see on the wheel stud flange.
I say pics are in order.
mcmud is offline
post #12 of 18 Old 05-16-2011, 06:47 AM
lucdog
lucdog's Avatar
1980 CJ5
Another vote for a picture.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 18 Old 05-16-2011, 06:59 AM
cj5752
1975 CJ5
Don't worry about the hole. Mud is going to get into the the drums from the back anyway. The hole is a great place to stick a water hose when you get out of the mud to clean out the drums.
cj5752 is offline
post #14 of 18 Old 05-16-2011, 03:26 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
or as sealed as its going to be......
If it is the superoir type axle they came with a hole to get a socket through as stated. Mosers did not.
if it does not line up with the 4 backing bolts when rotated the pictures are a must...
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #15 of 18 Old 05-16-2011, 08:55 PM Thread Starter
ms198
it is in the part of the hub that isn't covered by the brake drum. its probably for the backing plate bolts but i can reach them with a wrench..
ms198 is offline
one piece shaft bearing questions ms198 Jeep CJ Forum 14 05-14-2011 04:30 PM
Pics of Two Piece front drive shaft jrussell Jeep CJ Forum 2 10-28-2010 09:29 PM
End play on 1 piece Model 20 axle shaft Boomer Jeep CJ Forum 1 02-25-2010 07:26 PM
2 piece to 1 piece AMC20 axle swap question Robb Kiker Jeep CJ Forum 11 11-17-2009 08:01 PM
One piece shaft install question MR.CJ-7 Jeep CJ Forum 15 08-17-2005 05:12 AM
