One piece front end alignment - JeepForum.com
post #1 of 5 Old 09-25-2011, 01:29 AM Thread Starter
jeepsterdk
1978 CJ7
Hi all
I'm installing a one-piece front end on my 1978 CJ7. The tub is fiber as well. The little lip at the bottom of the fender, where it meets the tub is sticking out. See the pic for reference. Is this normal? Think it looks a little akward.
1978 CJ7 | 360 AMC | TH400 | AMC20 | YJ springs
jeepsterdk is offline
post #2 of 5 Old 09-25-2011, 05:25 AM
gojeepin
1983 CJ7
Are you talking alignment or fitment? Does it stick out the same amount on both sides?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 5 Old 09-25-2011, 09:02 AM Thread Starter
jeepsterdk
1978 CJ7
Yes, it does stick out the same amount on the other side
post #4 of 5 Old 09-25-2011, 09:14 AM
Cutlass327
1978 CJ5
That's how my 'glass fenders fit to my 'glass tub too.. it's not a 1-pc fromt end, but it makes it look like the tub is missing a body line or something..
Rick
Cutlass327 is offline
post #5 of 5 Old 09-25-2011, 10:01 AM
jeepwhore
That rib on the stock steel fenders does the same thing. If the edge of the FG was rounded a bit more like the steel fenders it wouldn't be as noticeable. I'd rather have it do that than try and make it flush. If the rib was flush with the tub then the fender above it would be in-set from the edge of the tub by that amount and would look far worse. Since it's a one pc you don't have much choice anyway as you can't adjust the pieces independent of each other.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
One Piece Front Clip MoC Jeep CJ Forum 60 06-06-2012 07:13 PM
One piece front end Totallymetal Jeep CJ Forum 3 01-09-2012 04:42 AM
CJ one piece fiberglass front end truckshop21 Jeep CJ Forum 15 04-23-2011 10:20 AM
One-piece front end - NEW IDEA maybe jeepsterdk Jeep CJ Forum 16 08-02-2008 08:34 PM
One Piece front end/Headlights blytle20 Jeep CJ Forum 3 07-05-2003 08:49 PM
