One Piece Front Clip - JeepForum.com
post #1 of 61 Old 10-22-2009, 02:55 PM Thread Starter
MoC
Does anyone have a one piece fiberglass front clip? (Where the hood, grill and fenders all fold up together.) Love it? hate it?
MoC is offline
post #2 of 61 Old 10-22-2009, 03:32 PM
Totallymetal
I love the access it allows you to work on the engine in the garage. I can sit on the tire and change plugs.
I don't like it when outdoors in the wind, it can get thrown around, kind of flimsy. Also hard to get open in an off camber situation, the inner fender hits the tire when opening and closing. Mine opens to the windshield.
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #3 of 61 Old 10-22-2009, 03:57 PM
78treehugger
1980 CJ7
My buddy has 1 on his CJ 5 and it definately makes it easy to work on the engine. He has never complained.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #4 of 61 Old 10-22-2009, 08:02 PM
rixcj
rixcj's Avatar
1979 CJ5
I have one, and love it. There's a lot of work going this route, though.
You have to mount the radiator to the frame.
Front lights have to be grounded to something.
Hood hold downs have to be modified.
Anything that was mounted to the inner fenders, may have to be relocated.
If you're going to run large tires, the nose may hit the tires.
I run 33's, and had to cut the nose, and fasten the cut parts permanently to the cowl.
Here are a few pics...
This shows the cut piece fastened to the cowl...
The hood hold down hardware...
Radiator support brackets...
To me, it's well worth the access it allows. Last spring I swapped engines just by lifting the nose back. That's pretty sweet!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is online now
post #5 of 61 Old 11-24-2011, 01:19 AM
TxJeeper20
1982 CJ5
I am seeing these different mounting ways I like the one with the regular hood hold down on the front but where do i get the bump stops and radiator support I am looking to do this without to much modifing
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #6 of 61 Old 11-24-2011, 02:28 AM
lucdog
lucdog's Avatar
1980 CJ5
On the one I have, the radiator supports are 1.5" angle welded to the frame. I drilled holes in the angle for the rods, and hood prop rod. The bushings, I didn't use any, but will on my YJ to CJ conversion. Rix's look like body mount bushings. You would also want pins on the bottom of the grill, to fit into the bushings.
On a stock CJ with 31's the bottom of the fenders rubbed the tires when opening. Rix's is cut higher than mine will be.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 61 Old 11-24-2011, 02:58 AM
TxJeeper20
1982 CJ5
Bill
Damn My Cj is stock height with 31s lol So how do Igot about fixin this problem?
I like the idea or angle Iron to the radiator and body mounts would be perfect just run a bolt thru the bottom to line up with the mounts and guide it in , see I can be taught lol
what about propping it up if I lean it back like a regular hood how to prop it I was thinking Hydrolic trunk shocks or sumthing
1989 Porsche 928 S4
2005 Infiniti G35
post #8 of 61 Old 11-24-2011, 05:09 AM
lucdog
lucdog's Avatar
1980 CJ5
It looks to me, Rixcj does what I do. Lay it against the windshield.
On mine there isn't much on the inside for strut mounting. If needed, something like a 2x2 could be glassed in.
Some of the things needing change. That's easy, everything mounted currently to your fenders.
Look how RixCJ trimed the lower fender area.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 61 Old 11-24-2011, 06:54 AM
TxJeeper20
1982 CJ5
Can I see Rixcj Jeep with the hood down , to mee it look kinda funky cut lik that ,just weighting my options I dont wanan buy a 300 dollar mounting kit lol
1989 Porsche 928 S4
2005 Infiniti G35
post #10 of 61 Old 11-24-2011, 07:22 AM
mopar346
Not sure if it works on a CJ but glass front ends on cars typically tilt forward (like a lawn mower). They are also a pain to remove when you are by yourself, even tilting a lightweigth one it difficult single handed. Here's one on a FJ.
Careful your character's showing
mopar346 is offline
post #11 of 61 Old 11-24-2011, 10:10 AM
rixcj
rixcj's Avatar
1979 CJ5
In my opinion, there's no advantage to having the nose tip forward. It's a lot more work to install, and the nose is in your way when doing anything to the front of your engine.
Plus, if you look at that Toyota, part of it's fender is mounted to the firewall (cowl), as well.
Rich
rixcj is online now
post #12 of 61 Old 11-24-2011, 10:34 AM
cdmiller2
1981 CJ5
rix how much lift and what size tires are on your five?
cdmiller2 is offline
post #13 of 61 Old 11-24-2011, 10:51 AM
mopar346
Rick, yours is very clean, how floppy is it? If it is a concern (again the ones I have dealt with are lightweight for racing) it could probably be sured up with some quick connects and re-enforcements.
mopar346 is offline
post #14 of 61 Old 11-24-2011, 11:03 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Cool thread. I was just gonna ask the same. Since mine was rolled, I grabbed a 1 pc w/a Kentol mount kit for $400.00. Solid 'glass. Seemed cheaper than new fenders & hood. Of course I still need a w-shield frame & glass. I'm gonna tilt FWD. No winch and afraid of the thing blowing open on the hi-way... towards me!
Thanx for the info rixcj!
hutch1200 is offline
post #15 of 61 Old 11-24-2011, 06:45 PM
rixcj
rixcj's Avatar
1979 CJ5
I'm not sure of the suspension lift, if any. It was on the jeep when I bought it. It may be stock, but there is about a 1.5" body lift. The tires are 33's.
The jeep had 32's on it when I bought it. When I put the 33's on it, I had to cut the fenders to clear the tires when tilting the nose back. The nose was OK, uncut, with the 32's.
It is not floppy at all...BUT...I have a very good 'glass tub and nose, as far as quality goes!! That's very important!! I have seen cheaper ones that were paper thin, and very flimsy. I can imagine that they would be very floppy.
If your 1-piece is good quality, you did good. New, a Kentrol nose, shipped to you, is about $1K.
I also just bought an uninstalled (used) Kentrol nose for $400.00 for the second jeep that I'm building. I was tickled pink to find it on ebay.
Rich
rixcj is online now
One piece front end clip - Latch? DocZ Jeep CJ Forum 1 09-24-2009 06:45 AM
CJ front clip on TJ ajeepman Jeep CJ Forum 4 09-03-2008 09:32 PM
front clip alignment nichols077 Jeep CJ Forum 2 06-25-2007 08:03 AM
CJ Front Clip KYgreenYJ Jeep CJ Forum 1 03-16-2002 10:58 AM
YJ front clip on 74 CJ5 newton Jeep CJ Forum 4 11-24-2001 03:04 PM
