One Piece Axle - JeepForum.com
post #1 of 15 Old 12-16-2001, 06:35 PM Thread Starter
diamatron
1978 CJ7
Post One Piece Axle
I am going to upgrade my Model-20 rear axle. How is the "Omix-Ada" Brand? I can find it for 229 while "Superior" would cost 299.
Anyone have any suggestions?
diamatron is offline
post #2 of 15 Old 12-16-2001, 08:57 PM
Darko
Post
Ive heard good things about moser. they run $299 never heard of omix brand
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #3 of 15 Old 12-17-2001, 05:09 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
I JUST PURCHASED ONE PIECE AXLE KIT FROM MORRIS4X4 IN FLORIDA FOR $ 189.00 + 18.00 FOR SHIPPING ! I BELIEVE IT IS A SUPERIOR KIT ? OR OMIX-ADA . THESE GUYS HAVE GREAT PRICES AND I CANT SEEM TO FIND ANYBODY THAT CAN BEAT THEM !!!!! WWW.JEEP4X4CENTER.COM
GOOD LUCK , JIM
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #4 of 15 Old 12-17-2001, 05:29 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
SORRY LET ME TRY THAT AGAIN MORRI4X4 GOOD LUCK , JIM
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
JIM79CJ7 is offline
post #5 of 15 Old 12-17-2001, 09:14 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Omix-Ada appears to be one of the largest suppliers of OEM CJ replacement parts, and one of the few that carries lots of stuff for flat fenders. Many companies sell unnammed parts that are, in fact, Omix-Ada. Particularly body parts. They are a leader in the industry.
However, a little informal poll of some people I consider more knowledgeble than myself tend to lean towards Superior for the one-piece axle kit. Rumor has it that they have very good customer support/service. Although there Moser is also considered quite good.
Just .02 for ya
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #6 of 15 Old 12-17-2001, 09:58 AM
rivertrout10
rivertrout10's Avatar
Post
I have a the Moser axle kit - no complaints. A buddy of mine runs Moser as well with no complaints. The benefit of the Moser kit is the wheel lug bolts are installed - I believe you have to put them in yourself on the Superior kit and also on the Omix-Ada. I have seen this done and it can be a pain in the butt.
Good luck,
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #7 of 15 Old 12-17-2001, 10:35 AM Thread Starter
diamatron
1978 CJ7
Post
I believe the Superior has threadedlug bolts so there shouldn't be a problem there. Superior and Moser are priced the same around 300 dollars. Moser is the better name from what people say.
Omix is the other option simply because they run at 200 dollars. One guy here says they worked fine. How were there lug bolts? DO all the axle kits have a shimless design?
post #8 of 15 Old 12-18-2001, 09:31 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Cool
Warn full floater! Although expensive, is hands-down the best AMC 20 upgrade around.
Steve
OldJeepguy is offline
post #9 of 15 Old 12-23-2001, 12:01 PM
Crash&Burn
Post
Just my $0.02 worth
Would not spend a cent on the AMC 20 if you are going to do some serious work with it.
The tiny axle tubes scare me to death, even with a truss. Put the $$ into something strong, this is really true if you are going to have it for a long time.
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #10 of 15 Old 12-25-2001, 07:57 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
Originally posted by Crash&Burn:
Just my $0.02 worth
Why not?? You have a 9" - not too much different from a well equipped AMC 20 IMO...
If someone opts to not spend the money on a 20, that's fine but at least do a REAL upgrade to a D/60 or a Corporate 14 bolt. I see people toss out their 20's all the time and go to a D/44 - this is not an upgrade folks - this axle has the same size tubes as an AMC 20 and a LOT smaller ring & pinion. A 9" is only a moderate upgrade so why not spend it on a real upgrade???
Just asking is all...I've seen the insides to all of them and am not just repeating what I've heard...
Steve
post #11 of 15 Old 12-25-2001, 10:53 PM
401cj5
401cj5's Avatar
Post
I am with you OldJeepGuy.
In the end it really depends on what you are going to do with your Jeep. There are situations where a Dana 70 is not enough, even with trusses on it. I say that because you can always go bigger and bader and still not bring enough to the table to get the job done.
The Model 20 is stronger that a Dana 44 when done right. I like the Moser axles but that is what I have and know. The others are probably fine maybe a little more headache but whatever.
Jason
78 CJ-5 - 401 with Holley Projection
T-18 with 6.32 1st gear+D300
D30 frt Model 20 rear
4" Lift and Locked; 33X12.5 on 15x10
78 Wag Ltd - 360
400 Trans+Quadra-Trac with MM O/D kit
D44's frt and rear
2.5" AAL's for lift: 30.5x9.5 on stock Aluminum
79 J20 - 360
T-18 with 6.32 1st gear+D20
D44HD frt D60 rear
3" RCLift Blocks for rear; 31.50x10.50 on 16x8
8400# weight truck
80 Chero - 360 with Holley Projection
727 Trans+ 208
D44 frt Model 20 rear
4" Lift; 35x12.5 on 15x10
401cj5 is offline
post #12 of 15 Old 12-26-2001, 09:29 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
I wheeled for 7 years on totally stock stuff including the two piece axles - this was doing moderately hard stuff in SoCal. I was told the axles would never hold up and planned on replacing them when the time came. Well a few months ago while wheeling a pretty rough local area I heard a loud BANG and assumed an axle had finally failed - here is what I found after getting the Jeep home:
This is a Trac-loc carrier sheared in half! The two piece axles were fine...
I replaced the carrier with an "open" one and added a PowerTrax no-slip locker and installed the Warn full-floating axle kit. I probably should have trussed the axle tubes as well. I have a spare AMC 20 housing that I'm planning to build if/when the need arises.
Keep in mind that this is on a trail Jeep, not an ARCA competitor! Bottom line is a D/44, Turd 9" and an AMC 20 will all give good service if setup right.
Steve
post #13 of 15 Old 12-27-2001, 08:55 PM
Crash&Burn
Post
Old Jeep Guy;
My main concern was the 2 1/2 tubes in the 20. I know the R&P size are almost the same. The 9 inch housing has got to be stronger because it is one piece, also the locker and R&P is cheaper is on the 9 inch so that helps offset the cost of having a custom housing made.
As I said it was just MY 2 cents worth!!!
post #14 of 15 Old 01-03-2002, 09:22 PM
JPCJ5
Post
I went with superior one piece axles and while I was at it I purchased the factory posi-trac For what I do it has worked out in the amc 20. A guy can always build a tougher
axle, however then something else will give out in the drive line. good luck.
JPCJ5 is offline
post #15 of 15 Old 01-09-2002, 05:50 PM
only in a jeep cj
Post
Anyone who did this swap have a good ( non spun) drivers wide track axle left over? Thanks
ED
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
2 piece to 1 piece AMC20 axle swap question Robb Kiker Jeep CJ Forum 11 11-17-2009 09:01 PM
Is this a one piece axle? Skotter Jeep CJ Forum 13 09-05-2009 08:41 PM
amc20 one piece axle turns axle to open diff? 84cj7jd Jeep CJ Forum 6 04-08-2009 10:23 AM
one piece axle kit need help bfuqua Jeep CJ Forum 7 09-09-2007 08:43 AM
one piece axle dtrimble Jeep CJ Forum 1 08-01-2004 07:35 PM
