Hello,
I'd like to know from anyone with experience with this if the omix ada or the crown heavy duty (u joints on both ends) steering shafts will be a worthy upgrade over the oem shaft. my stock shaft is worn and Id like to replace it, just dont know if my situation requires a $260.00 Borgeson shaft. 1" body lift and a 2.5" shackle/spring lift with 32" tires on a 79 cj-7.
Ive installed two of them. Both in trail Jeeps. Easy install and no complaints. Works great.
Installed a Flaming River one many years ago. Its still fine too
I bought one and it seems to be pretty good quality, but i havent used it yet. Still need to get the jeep back together first. I think its worth it thought to get rid of the original bell fitting at the steering box end.
Thanks everyone!
It came, and Its on. $103.00
It's a little short with the 1" body lift. it seems safe, it fit the grooves.
I really like the improvement.
Thanks everyone!
Did you completely extend it first? Mine has a 1" body lift, and my steering box is moved 1.5" forward, and I had plenty to reach.
I completely extended mine and lubed it up before installation. It was a little stiff at first. Once lubed, and worked in and out, it could easily be completely compressed and extended by hand.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
