I have searched and found some really good enough but I am stumped on my issue
I replaced my headlight switch as the old one was broke and also my dimmer switch which fixed my bright lights!!
I still do not have dash lights. I pulled the fuse (3amp) and I have no power to the acc light spot? Why wouldn't I have power? Where do I check from here? Thanks for your help
John yes sir. I had the same issue in my 79 GE. My jeep had the switch with the jumper. I made sure I got the right one. All lights work. Just no dash lights
Thanks for posting that John, as it'd been many a moon since I had 'Black Betty' running until the other week I was dismayed that upon startup I had a headlight failure which I thought may have been the switch but I lacked a diagram. As it turned out the secondary battery was low that I have the headlight circuit running through.
Early on I had a similar issue with 'BB' it turned out that I had grounding issues from the Speedomter Housing to the Dash, in turn to the Body Tub. Once I established ground straps fromthe motor block and body tub to the Negative battery terminal everthing began working properly.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
