"old school" conversion - JeepForum.com
post #1 of 15 Old 09-09-2013, 01:47 PM Thread Starter
84bluecj7
I just purchased an '84 cj7 with a 4.2 - 4 speed and I would like to modify it "old school" to eliminate all electronics. I know I will need to change to a standard carbeurator and change the distributor to points and condensor. Any other changes I will need to do to eliminate the ECU?
Any recommendations on what carb to install? What year did the CJ's go to electronic ignition?
I am an old gear head but do not know anything about jeeps. This is going to be a hobby rebuild but I want to do it right and make it a dependable ride.
thanks in advance for your input.
Jim
84bluecj7 is offline
post #2 of 15 Old 09-09-2013, 01:53 PM
jeepwhore
If you want simple just nutter it and put an HEI distributor in. Take you less time to swap in than converting back to points and give you a better ignition than what the old systems can provide. Coil and module in the cap, one wire hook up and remove all the wiring and vacuum lines associated with the old feed back carb. As for carbs, weber and MC2100 are the two most common swaps.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 15 Old 09-09-2013, 07:08 PM
superj
A good old holley is a good carb on a 4.2 also. I did the same style retro set up in my 87 yj. Tons of wires removed and old school carb and intake. Runs solidly and good power. I haven't had any trouble since I did the swap/ mod either
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 15 Old 09-09-2013, 07:40 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by jeepwhore View Post
If you want simple just nutter it and put an HEI distributor in..
But he said he wants to eliminate the electronics. Wouldn't an HEI add electronics?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #5 of 15 Old 09-09-2013, 07:49 PM
jeepwhore
It would replace complicated electronics with much simpler ones. Personally I think there's a reason points ignitions went the way of the dodo. You can get a much better ignition with improved reliability if you use quality parts. Considering the number of people that run electronic ignitions without issue I personally don't see going to points being a reliability thing. If its a matter of simplicity, an hei provides that in spades.
Bear in mind I'm only suggesting keeping the electronics because I've assumed the whole reason the OP is doing this is to eliminate the ECM as he eluded to.
post #6 of 15 Old 09-09-2013, 09:54 PM
BagusJeep
1981 CJ7
WTGR, the ECM is indeed wired into the Duraspark electronic ignition at the moment but does not have to be.
The Nutter bypass just cuts and twists the wires together to put the sensor back into direct communication with the Duraspark module without going through the ECM to be distorted. Simpler than buying a new ignition and distributor and wiring up a 12V source of sufficient amperage.
Putting points in is possible but will be a fair bit of work or require the purchase of a new distributor. I can recall points and they were a PITA in the day.
As to the carb, the old one can be made to work without its electronic leash. If it is in good condition, does not leak etc it could soldier on for years. P
Personally I would spend the cash and put a shiny Gucci Weber 38 under there, having struggled with a 30 year old Carter BBD for years. If I coudl I woud retain the TAC, there is an adapter plate for it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 15 Old 09-10-2013, 09:04 AM
WindKnot
1977 CJ7
I agree with everyone so far about the Nutter bypass and also agree with questioning going all the way back to the days of points and condensers.
If you're worried about an EMF nuclear blast, I wouldn't; round 2 would only be minutes away. Even if the Jeep survived, you won't. (nice thought, huh?)
You don't need a computer for electronic ignition and the benefits far outweigh any disadvantages that may come with it. Once they're in, (and they're painless to install) you're pretty much set except for the occasional spark plug change.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #8 of 15 Old 09-10-2013, 09:18 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by WindKnot View Post
If you're worried about an EMF nuclear blast..
I was wondering if this thread would turn to this topic. If EMP is the concern, you do have a couple of options:
  1. Install an HEI system and keep a stash of replacement parts in a highly shielded location for use in the future.
  2. Install an HEI system now, and gather all of the parts for a points system. Install it in the future if needed.
Either way, you get the advantage of a modern ignition system today and you have made some plans for the future. Personally, the real problem would be availability of fuel after such an attack. If there's no gas then it doesn't matter if the Jeep runs or not
Ken4444 is offline
post #9 of 15 Old 09-10-2013, 01:49 PM
jacques25150
1982 CJ7
or swap with a diesel engine old school!!! no electronics and no old electric system also!!!
: 2thumbsup:
jacques25150 is offline
post #10 of 15 Old 09-10-2013, 03:30 PM
Neuner-9R
: 2thumbsup:
X2! So far what I plan to do once my 258 conks out.
Neuner-9R is offline
post #11 of 15 Old 09-10-2013, 03:56 PM Thread Starter
84bluecj7
Thanks everyone for the replies. I don't mind the old points system. I ran them in my old corvettes for years with no issues, so I think I still want to go that way. What distributor should I be looking for as a complete replacement? I don't mind buying new but I don't know what fits. As far as the existing carb, it runs fine and does not leak. How do I make it work without the leash? I am adept at most any repairs and or mods, but I am confident that there are many on here that have already gone down these paths and I don't want to reinvent the wheel (or jeep in this case), so I really appreciate all the help and instruction.
Jim
post #12 of 15 Old 09-10-2013, 04:16 PM
WindKnot
1977 CJ7
Delco Remy made the distributor for the 1974 model year. That was the last year before electronics.
Going used? Gremlins, Hornets, Javelins and other AMCs used the same 258CID I-6 engine. So did IHC Scouts and full sized Jeeps. Same cam gear, all compatible.
WindKnot is offline
post #13 of 15 Old 09-12-2013, 11:05 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Don't forget to scavenge the ballast resistor as well......
jeepdaddy2000 is offline
post #14 of 15 Old 09-13-2013, 03:13 PM Thread Starter
84bluecj7
Thanks for the reminder. I would have forgotten to pick it up.
Anyone provide instructions on how to make the existing carb work without the ECM?
post #15 of 15 Old 09-13-2013, 03:55 PM
CSP
Go to Google and search on "Nutter conversion". I'd provide a link if I knew of one.
CSP is offline
