Is this an old motor mount? Doing v8 swap, and it's in my way
#1 | |
So I'm lowering my 350 into my frame, ready to mock up the Novak motor mounts for welding, and I see this. It looks like an old motor mount, or something. But it doesn't, and hasn't had anything hooked up to it. It is welded to the frame, so I can't exactly unbolt it. It appears to be pretty much exactly where I'm gonna need to put the left motor mount. My question is what is it? And how do I get it off? Maybe the jeep came with a v8 and the previous owner put in the 258???!?!? I'm not sure why anyone would do that, but right now, I'm totally stumped, and I have the welder coming over in a bit.
HELP? ![]() Pete
2/3 of the earth is covered in water the other 1/3 is covered by Champ Bailey |
#2 |
It's a bump stop mount. You'll need to make provisions for an alternate bumpstop if you remove it.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#3 |
what's a bump stop? Does it keep my axle from hitting my engine? or engine from going down into my axle when I hit a bump? Or something else?
#4 |
It keeps your tires from tucking too far up into the fender preventing damage done to the tire or vehicle.
#5 |
ahh, any recommendations on where to replace it? Or is it even needed? Not like I do crazy rock crawling or anything. I do have fat 33" tires though. 4" lift
#6 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That is pretty much what it does as well as keep the fenders attached still.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#7 |
Off Road Forever
Can you not just build your mount on top of it? As long as the bolt is accessible for the bumper, it could maybe stay.
#8 |
question. Why does only the left side (passenger side) of the jeep have it? It is it crucial, wouldn't both sides have it?
#9 | |
I'll check real quick. be back in a few.
#10 |
Off Road Forever
The other side does have one I believe, right on the frame I think, so do the back axles.
#11 |
I might be able to put the mount behind it, but I need to angle my engine a whole hell of a lot more level to slide it in than I am. The problem with doing this is that I"m gonna have to unbolt the motor mount, cause I can't put it in level, and the distributor is hitting the firewall at the angle that I have it. So I'm thinking that if I get it in there level, then naturally, it'll free up a few inches from the angle alone. That might provide me with the clearance.
#12 |
There are also small bump stops on the frame rails directly above the axle tubes. You can see the bracket for it in the picture he has posted. The bump stop on the bracket you are asking about makes contact with the flat flanged portion on the axle right next to the pinion.
Mike My build thread 1979 CJ7, FI 5.0L Ford, NP435, D300, Full floated D44 Detroit, D30 Detroit EZ Locker. |
#13 | |
Vendor
Don't put your mount on top of it, you need to cut it off the frame. I'm not sure you even need it if you've got a lift on your jeep. Mine is long gone and no problems.
Aftermarket Jeep Parts www.crabtreetool.com NRA LIFE MEMBER GOD BLESS AMERICA! Please "Let every man be swift to hear, slow to speak, slow to wrath." Jim's 85 CJ7 rebuild |
#14 |
Off Road Forever
He is missing the rubbers from the axle bumpstop by the looks of it.
#15 |
I would just cut if off and make new ones later. Be sure to set the engine in correctly its supposed to be slanting a couple degrees back. Id be interested in seeing a bunch of pics when you get the mounts welded in, I bought the same motor mounts and will be doing mine real soon.
1989 Jeep Comanche MJ: 2WD, 4.0L, BA-10, D30, D35, 4" IRO Front, SOA Rear, Winch Bumper, Trimmed Fenders/ Bed. Working on 2wd->4x4 Conversation. My Build: http://www.jeepforum.com/forum/f22/my-slow-build-89-jeep-mj-off-road-hunting-rig-pic-heavy-1268973/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
