Old Man EMU 2.5" YJ to CJ Suspension Install - Page 45 - JeepForum.com
 11Likes
post #661 of 1075 Old 04-20-2014, 10:36 PM
BuckleshootCJ5
1973 CJ5
Well, my conversion is all but done. Need to order longer fronts shocks, but other than that its done!!! Drives like a dream down the road and I can't believe how quite the suspension is over rough spots, not to mention smooooooooth...
Can't wait to get the shocks on and see how it wheels!!!
Here she is, even got her new shoes...
The world would be a better place if being stupid hurt...
BuckleshootCJ5 is offline
post #662 of 1075 Old 04-22-2014, 02:49 PM
Jeepit85
Originally Posted by Matt1981CJ7 View Post
Because the CSO14F is a 1.75" lift and the CSO36R is a 2" lift. Using the 14Fs in front and the 36Rs in back will cause a noticeable rake, especially after the fronts sag a little.
Keep it simple and buy the 36Rs all the way around. That's my take.
Matt
Do the 37Rs give more than 2" lift?
85 CJ7, Howell TBI, Twin Stick, 4:10's, 35" Pitbull Rockers, Clifford 6=8, Detroits, Matkins Level II, BDS 4", Summers Brothers. Skynyrd rocks.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #663 of 1075 Old 04-22-2014, 03:36 PM
Kstein
I went with the 37R(ears) and the 14F(ronts). No rake that I can notice. Added 6 degree shims to the front and castor came in around 6 to 7. (Would need to pull my alignment sheet for the exact numbers); 4" shackles (YJ length.)
I estimate 2.5" of lift on my light CJ7. No winch, no hard top.
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline
post #664 of 1075 Old 04-26-2014, 06:17 PM
FLCJ-8
Looks great, but........
HOLY WHEEL WEIGHTS BATMAN
FLCJ-8 is offline
post #665 of 1075 Old 04-27-2014, 08:18 PM
BuckleshootCJ5
1973 CJ5
Ya, that's what I said! I painted them black for now, but I'm gonna have a buddy spin the tires on the wheels and try to get them a little more naturally balanced. Try to get less than a pound a wheel...
post #666 of 1075 Old 04-27-2014, 10:38 PM
Deeznutz73
1973 CJ5
Did you guys run into any issues with unexpected height gain? I swapped in 4" lift YJ springs from zone (BDS stickers on them) for my supposed 4" CJ springs, and I gained 3". Now my drive shaft angle is sitting at 31*. Also, I used the RRO kit.
This shouldn't be too hard...........
Deeznutz73 is offline
post #667 of 1075 Old 04-28-2014, 04:13 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Have you driven it at all? New springs need to settle in some times.
How old were the old springs, maybe they were just sagging that much?
Rick
Cutlass327 is offline
post #668 of 1075 Old 04-28-2014, 04:23 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Deeznutz,
My 2.5" OME YJ springs gave the advertised lift, or within a 1/4". They've settled about 1/8" in 2 years.
Here's my measurements with 32" tires.
Matt
Matt1981CJ7 is online now
post #669 of 1075 Old 04-28-2014, 05:55 PM
Deeznutz73
1973 CJ5
I think the springs were pretty old. It's hard to say though.
I haven't driven it yet. The guys at RRO forgot the frame sleeves so I'm waiting on those. When I get it sitting back down on all fours, I'll compare measurements. As of right now, with 33's, I'm at 27" at the rear corner of where you measured Matt. Thanks for the measurements.
post #670 of 1075 Old 05-12-2014, 05:17 PM
Deeznutz73
1973 CJ5
Just bolted everything up. Measuring in the same places as Matt, my tires come in at 31 3/4" and 28 1/2" under the driver side door.
Drive shaft angle is 35.5*
Rear pinion is 17.5*
2* shims
Front driveshaft is 17.5*
Front pinion is 3.5*
No shims
Springs are 4" YJ Zone of road and I have YJ 1" lift shackles.....
post #671 of 1075 Old 05-16-2014, 05:43 PM
85Renegad3
You guys are awesome!
Originally Posted by ErikEastman View Post
Here's what I would order if I was starting from scratch. I had recently replaced some items (like my shackles) before I started, so I didn't need everything I have listed here. This should get you pointed in the right direction.
You need 4 OME springs,
http://www.quadratec.com/products/16090_5058.htm
4 OME shocks,
http://www.quadratec.com/products/16091_0171.htm
Front and rear YJ bushings(You need 4 of these kits, one for each spring)
http://www.quadratec.com/products/16090_700.htm
4-1.25" ID shackle hangers(CJ are 1"ID, YJ are 1.25"ID)
http://www.quadratec.com/products/12590_0006.htm
2 YJ front spring plates, left and right(or get some conversion spring plates. The CJ rear spring plates can be reused if you want)
http://www.quadratec.com/products/56008_05.htm
Longer shackle bolts(I would just get two sets of these or something similar without bushings and be done with it)
http://www.quadratec.com/products/16049_4011.htm
New ubolts(don't forget one needs to be the larger diameter for the front differential housing if you have a Dana 30)
http://www.quadratec.com/products/56009_01.htm
That's the basic parts list I came up with for my conversion(though I haven't done the shocks yet) If I've forgotten something let me know. I come up with about $1100 before shipping.
I hope this helps, it can be somewhat confusing. Sounds like even the guys selling the kits have trouble with it.
If you order from Quadratec, don't forget to call or email Joe and get yourself a forum member discount, and possibly free shipping.
This thread is awesome! Thanks for putting this all together. I'm about to treat my baby to a new lift and like all of you have decided on the OME 2.5" lift. I'll admit that I've only made it through about the first 20 pages of this thread. Way back in 2011 Eric was nice enough to post the above part list. Some of the stuff (like the shocks) are no longer in stock. Quadratec offers this kit http://www.quadratec.com/products/16090_00X_PG.htm which seems to have most of the same parts. If I go with the kit am I missing anything? Sorry if this has been covered before. With the length of this thread its a bit of information overload. Here is a pic of my rig pre-lift
85Renegad3 is offline
post #672 of 1075 Old 05-16-2014, 06:50 PM
Waldomas
Those seats look comfy.
Waldomas is offline
post #673 of 1075 Old 05-16-2014, 07:09 PM
85Renegad3
Seats are very comfy. However the driver's seat has seen better days. It has several tears and the seams are starting to pull apart. I would love to replace it but I can't find a matching seat. The dude I bought the jeep from a few years back said the seats were there when he bought it. I may just replace all the seats down the road after this lift. Right now my jeep fund can only support one project
post #674 of 1075 Old 05-17-2014, 07:51 AM
sully122
1983 CJ7
I have those seats in pretty good sharpe that are available for purchase..
sully122 is offline
post #675 of 1075 Old 05-17-2014, 08:01 AM
85Renegad3
This thread is long enough just talking about the OME lift. We should probably take the seat convo to PM. Shoot me a pic of your driver seat and how much you want for it.
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 07:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 10:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 06:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 10:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 10:48 AM
