Old Man EMU 2.5" YJ to CJ Suspension Install - Page 44 - JeepForum.com
 3Likes
post #646 of 1057 Old 01-08-2014, 07:42 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by waterdowg View Post
Hmmmm..... I wonder if you could use CSO14F in all 4. This would give a little less of a lift but still get the ride. Any issues this that?
I'm not sure why anyone would want a softer ride than the 36Rs provide. Compared to the stock springs, they ride like a Cadillac.
That said, I have no experience with the softer 14F springs, so take my advice for what it's worth.
Matt
Matt1981CJ7 is offline
post #647 of 1057 Old 01-08-2014, 07:46 PM
waterdowg
Matt
Thanks Matt. I value your advice. I was just wondering.
waterdowg is offline
post #648 of 1057 Old 01-09-2014, 06:18 AM
sjc115
Matt: Thanks for the input. Makes sense now.
sjc115 is offline
post #649 of 1057 Old 01-09-2014, 12:53 PM
sjc115
FWIW...
I ended up taking this one step further and wanted to share what I found. Quadratec sells the CS014F as a 2.5" Lift spring (http://www.quadratec.com/products/16090_5032.htm) which got me wondering if there was more info to be had. So, I emailed ARB and asked for specs. I got a very prompt reply with some good info. Here is what I got:
Hi Steve-
The springs you are inquiring about are Jeep Wrangler YJ application. We have 3 springs available. CS036R, CS037R, and CS014F. Technically the 36R and 37R are rear spring applications and the 14F is the front, but plenty of people use them on all 4 corners. The rates, leaf count and arch are as follows.
CS036R- Rate- 188 lbf/in, 5 leaf, 205mm free camber.
CS037R- 188 ,5 leaf, 185mm free camber.
CS014F 148 , 4 leaf, 210mm free camber.
Best Regards,
ARB Technical Support Team
Air Locker, Inc.
425-264-1391
720 SW 34th St.
Renton, WA 98057
Tech@arbusa.com
www.arbusa.com
So basically the only difference between the 36R and the 14F is the spring rate (presumably because it has one less leaf, which also explains the cost difference). That would make the CS014F sag a little more making it seem like there was less lift. Which would result in the 'rake' that Glenn mentioned.
In a follow up question I was also told that the 'F' springs do not come with the caster correcting wedge. Not a big deal if anyone chooses to use the 14F since that gets replaced anyway.
sjc115 is offline
post #650 of 1057 Old 01-09-2014, 02:55 PM
Renegade82
1982 CJ7
anyone know what "free camber" is?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #651 of 1057 Old 01-09-2014, 02:57 PM
sjc115
It is basically the height of the arch in the spring.
sjc115 is offline
post #652 of 1057 Old 03-19-2014, 11:11 AM
nacheswheelin
While were on the subject of free camber the 36r is 205mm which converts to 8.07 inches. Bds 3.5 inch springs state there 8 inches freestanding. How much lift should a guy expect from them in comparison? Why do the ome springs have more camber and less lift are they softer so they will compress more?
Who ever said less is more never owned a jeep.
nacheswheelin is offline
post #653 of 1057 Old 03-19-2014, 11:26 AM Thread Starter
Matt1981CJ7
1981 CJ7
I suspect the OME springs are softer. They are known for their comfortable ride qualities, and flex. I can certainly attest to that.
Matt
post #654 of 1057 Old 03-19-2014, 11:51 AM
nacheswheelin
Its just wierd that they have more camber than a one inch taller spring
post #655 of 1057 Old 03-19-2014, 11:57 AM
Spieg8
1984 CJ8
Spieg8 is offline
post #656 of 1057 Old 03-19-2014, 12:13 PM
sjc115
It is also possible that the BDS 'freestanding' measurement is a different measurement than 'free camber'. See link for the possible difference in measurements: http://mgaguru.com/mgtech/suspensn/rs105.htm
sjc115 is offline
post #657 of 1057 Old 03-19-2014, 12:48 PM
nacheswheelin
Based on the pictures then the free camber is basically half of the free standing height. Since the two measurements (from bds, ome) are both close to eight inches that would make the ome spring twice the height. When I called bds they gave me a free standing measurement of 8 inches the ome spring has a camber of 8 inches. Technically it would be larger than the bds spring. None of this makes any sense to me the measurements have to be taken from the same place. I imagine the guy at bds gave me the wrong measurement. I am going to call bds and ask for the camber measurement then I will post it up.
Edit-
I just got off of the phone with bds and they told me their camber is measured at 7 1/2 inches so with ome being 8.07 inches technically out of the box they are a taller spring.
post #658 of 1057 Old 04-09-2014, 05:11 PM
BuckleshootCJ5
1973 CJ5
Anyone know if the 4 degree shims would be needed for a '73 CJ5, or...?
Just ordered all my stuff and there are quite a few differences in the "intermediate" kit from the stuff here. It hasn't arrived yet, so maybe the instructions will tell me this, but if anyone knows I'd like to order the shims now...
Any other tips from the intermediate crowd that have done this would be greatly appreciated!
And BTW, doing the Rocky Road SUA kit with the heavy rear 2 1/2 OME YJ springs all around. Still haven't decided on shocks...
The world would be a better place if being stupid hurt...
BuckleshootCJ5 is offline
post #659 of 1057 Old 04-09-2014, 06:42 PM Thread Starter
Matt1981CJ7
1981 CJ7
Originally Posted by BuckleshootCJ5 View Post
Anyone know if the 4 degree shims would be needed for a '73 CJ5, or if the stock shims need reversing, or the shims stay the stock way?
The heavy rear OME springs will have a 2 degree shim that will be backwards for the fronts, unless the supplier reverses them.
The safe bet is to install the springs with the provided shim (reversed on the fronts), have the alignment professionally checked, then make any necessary adjustments.
Matt
post #660 of 1057 Old 04-09-2014, 07:34 PM
BuckleshootCJ5
1973 CJ5
OK, I'll give that a shot. Thanks!
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 11:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 11:48 AM
