Old Man EMU 2.5" YJ to CJ Suspension Install - Page 43 - JeepForum.com
 3Likes
post #631 of 1057 Old 11-29-2013, 02:50 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
hold,
If I were to do it again, I'd piece my suspension together. My kit had a bunch of unnecessary extra pieces, and a few necessary ones that were missing.
Good luck,
Matt
Matt1981CJ7 is offline
post #632 of 1057 Old 11-30-2013, 12:23 PM
jetsnjeeps
1980 CJ5
I Bought mine from Rocky Road Outfitters. Very complete kit with good instructions. Get the heavy duty rears if you have a full size spare and/or hard top.
http://www.rocky-road.com/cj-ome.html
Cheers!
jetsnjeeps is offline
post #633 of 1057 Old 12-29-2013, 04:56 PM
locohosa
Wow, what a great read! Combine this with GoJeepin’s suspension basics (38 pages long) and I cant help but wonder what knowledge I have forced out of my head to make room for all this new CJ Knowledge.... Hopefully nothing important!
I am starting with the stock suspension on my 1984 CJ-7, that rides like a bucket of fail, and the previous owner put brand new 33 inch tires on to make it oh so much worse. They don’t rub badly unless I disconnect the sway and really flex it, so any amount of lift will make the difference. I also do not fear going to some bigger bump stops if necessary.
A few questions, I am sure they were answered, Im just clarifying.
• I was unable to find the OME shocks for the CJ still available anywhere. (Except for as part of the ok4wds Granite kit) Do you know if they still exist?
• My boss has a hook up with ARB, he asked for an ARB part number and said he can get me a deal, so I found this Kit: Part Number ARB7686XH Looks like bushings and required bolts/sleeves are included. Is this kit missing anything aside from the Shocks and Shackles?
o Any YJ shackles should work, yes?
• If he doesn’t come through for whatever reason, I am going to order one of these: OK4WD Granite Kit with OME Springs OR Rocky Road OME kit I have heard questionable things about Rocky-Road and them getting the right parts delivered to you in a timely manner.
o If I buy the Rocky-Road kit, I could get the shorter CJ Length shackles if I didn’t want as much lift, or get longer bolts for my existing shackles, correct?
• Im not sure if I will be using YJ or CJ shackles yet, if I use the CJ shackles, then I need a 4 degree shim. If I use YJ Shackles, then I most likely need a transfer case drop kit and 6 degree shims. Is this correct?
• Lastly, I am going to get some sway bar disconnects. I didn’t find any by ARB, so I am getting this kit: Rubicon Express Sway Bar Disconnect Set. Do you suggest any other good mods (Steering braces ect) while its apart?
Cheers!
Have you installed this kit? Were you satisfied with shipping and customer service?
locohosa is offline
post #634 of 1057 Old 12-31-2013, 12:31 PM
TrebleHook
1979 CJ7
I have the Heavy OME 2.5 springs with Currie YJ shackles and 4 degree shims...balls-on 6 degree castor.
1983 CJ8 Scrambler Laredo - 258 MOPAR MPFI/T-5/Dana 300 - 4.10 Dana 44 Rear/Dana 30 Front w/ ARB lockers front/rear - 4" BDS Suspension w/ Fox 2.0 Shocks - Ground Pounder Fab Front Shorty and Rear Spare Custom Bumpers - PSC Steering w/ Borgeson Shaft - 33x10.50 BFG KM2 on 15x8 Mickey Thompson Classic III - Work in progress.....
TrebleHook is offline
post #635 of 1057 Old 12-31-2013, 04:53 PM
vinnyabs
1983 CJ7
Hehe. Balls.
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #636 of 1057 Old 01-01-2014, 07:31 AM
GlennLever
GlennLever's Avatar
Cheers!
I have the heavy rears and lite fronts (no winch), I go topless in the summer, and have the space saver spare, hard top on the winter, but does not go out and play in the snow.
I have a slight body rake (rear higher that the front) Wish I had the lite rears.
Someday I will do one of the following. 1) take the lift back out, OME "kit" is great and it rides excellent, just would like a more stock appearance. 2) Take the rear springs off and get them re arched a 1/2 inch lower)
I'm not contradicting just supplying information
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #637 of 1057 Old 01-08-2014, 03:18 PM
sjc115
I just finished reading all 43 pages, and the pdf on suspension basics. That's a lot of info!! Thanks to all who took the time to take pictures and keep us up to date on how things worked.
One thing I still haven't figured out. Why use 4 rear heavy load springs, when they sell front heavy load springs for $25 less (http://www.quadratec.com/products/16090_5032.htm)? What is the difference between them?
sjc115 is offline
post #638 of 1057 Old 01-08-2014, 03:31 PM
GlennLever
GlennLever's Avatar
Big difference is ride quality and how you will use the Jeep.
I have no front winch to support. I was also told the light duty spring would allow the front axle to articulate better, I can not comment on that as I rarely go off road. I was told heave duty springs if you run a hard top and spare. I have light duty in the front and heave duty in the rear, there is a slight rake to the front and if I did it over would have light duty all the way around.
Again it is all about how you will use the Jeep.
Glenn R. Lever
My Web Site
post #639 of 1057 Old 01-08-2014, 03:43 PM
sjc115
Glenn: Did you use a light duty "front" spring, or a light duty "rear" spring? I'm pretty sure I have seen both front and rear springs in heavy, medium and light load options. My question is why use a rear spring when there are three options for front springs that can be had for less money? I feel like I missed something somewhere in the 43 pages of reading I did over the last two days.
sjc115 is offline
post #640 of 1057 Old 01-08-2014, 04:06 PM
GlennLever
GlennLever's Avatar
I have the light duty in the front and heavy duty in the rear.
I think the choice is really determined by how you use the Jeep. Daily transportation on highways without heavy bumpers and a which I would think the way to go would be light duty all the way around. That is what I would do if doing it over.
Glenn R. Lever
My Web Site
post #641 of 1057 Old 01-08-2014, 04:12 PM
BuckleshootCJ5
1973 CJ5
What we have here, is a failure to communicate...
The world would be a better place if being stupid hurt...
BuckleshootCJ5 is offline
post #642 of 1057 Old 01-08-2014, 04:15 PM
sjc115
I'm not doing a good job of explaining my question.
Why use (4) CS036R springs instead of: (2) CS014F's in the front and (2) CS036R's in the rear? Both part numbers are listed as being 'heavy duty'. The CS014F's are about $25 cheaper.
sjc115 is offline
post #643 of 1057 Old 01-08-2014, 04:54 PM Thread Starter
Matt1981CJ7
1981 CJ7
Because the CSO14F is a 1.75" lift and the CSO36R is a 2" lift. Using the 14Fs in front and the 36Rs in back will cause a noticeable rake, especially after the fronts sag a little.
Keep it simple and buy the 36Rs all the way around. That's my take.
Matt
post #644 of 1057 Old 01-08-2014, 06:09 PM
Kstein
I went with CS014F's in the front and CS037R's in the rear. This is a good setup for a lighter load (e.g. no winch or hardtop), plus I wanted to minimize the amount of lift.
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline
post #645 of 1057 Old 01-08-2014, 07:37 PM
waterdowg
Matt
Hmmmm..... I wonder if you could use CSO14F in all 4. This would give a little less of a lift but still get the ride. Any issues this that?
waterdowg is offline
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 11:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 11:48 AM
