Old Man EMU 2.5" YJ to CJ Suspension Install - Page 38 - JeepForum.com
 4Likes
post #556 of 1072 Old 03-27-2013, 04:44 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm not defensive, just still wondering what info was wrong on my install?
Regardless, I'm glad you corrected it.
Good luck, and post up some pics when you get it installed
Matt
Matt1981CJ7 is online now
post #557 of 1072 Old 04-08-2013, 11:11 PM
mvigo
mvigo's Avatar
We were finally able to finish the install of the Old Man Emu lift on my pal's '86. We followed Matt's advice and stayed clear of his obstacles due to him reporting them here first, so a big thanks to Matt for making our install go smooth! We bought the kit from OK4WD and even had them pre-install the 4* shims for the front axle which brought the caster numbers right into spec the first time. She sits on 31" BF Goodrich AT's:
My pal is very pleased with the ride and I must say it drives nicer then my Rubicon Express springs. Hopefully, this Summer, we will put her to test on the Rubicon and really say how flexy she gets.
Again, thanks Matt, this thread proved to be invaluable with all the information in it...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #558 of 1072 Old 04-10-2013, 01:34 PM
rispony
1981 CJ8
The ride looks great, but are you sure it's only 2.5" of lift? Looks more like 4/4.5! What leafs did you use? I went with CS036R's and mine looks much lower.
Follow my 1981 Jeep CJ-8 Scrambler build!
www.JeepCJ8.blogspot.com
rispony is offline
post #559 of 1072 Old 04-11-2013, 12:10 AM
mvigo
mvigo's Avatar
we used the heavy duty springs on all 4 corners. Keep in mind that the springs will settle some and he has no hard top or winch to weigh them down.
mvigo is offline
post #560 of 1072 Old 04-11-2013, 06:10 AM Thread Starter
Matt1981CJ7
1981 CJ7
I think the relatively small tires exaggerates how much lift he has. Mine looked the same way with 31"s.
Mvigo, nice job on the install, and I'm glad this thread was useful. Your buddy is going to love that suspension.
Don't forget to have him check all the u-bolts after about 100 miles.
Matt
post #561 of 1072 Old 04-24-2013, 02:05 PM
rispony
1981 CJ8
Guys, this thread has provided me with so much invaluable information and it's my turn to contribute. I had a revelation one night and came up with a much simpler steering stabilizer mount. Although I initally used Matt's great idea, it took a little effort finding the right parts and fabbing the part. What I did instead is take a grade 8 seatbelt bracket and just put a bolt through each hole, one for the stabilizer, one for the bracket. Although it's only one sided, i don't think it's an issue because it's just for the steering stabilizer so it won't get stressed much at all, plus it's grade 8! Super simple, and no drilling or cutting. The part is $1.49 on Quadratec so you just can't go wrong. Let me know what you guys think, and look at the pictures for better clarification.
Here's the part:
http://www.quadratec.com/products/24247_901.htm
rispony is offline
post #562 of 1072 Old 04-24-2013, 02:14 PM Thread Starter
Matt1981CJ7
1981 CJ7
Strong work, rispony!! Your idea is much more simple than mine.
Are the seat belt brackets a common auto parts store item? Or did you go to the junkyard for one?
Matt
post #563 of 1072 Old 04-24-2013, 05:58 PM
rispony
1981 CJ8
Matt
Thanks Matt. I put the quadratec link in the post above. Scroll up and check again
rispony is offline
post #564 of 1072 Old 04-24-2013, 11:20 PM
TrebleHook
1979 CJ7
Nice work on the steering stabilizer...I did something similar - but yours is more "elegant" as the mathematicians would say!
"Make things as simple as possible, but not simpler" - Albert Einstein
1983 CJ8 Scrambler Laredo - 258 MOPAR MPFI/T-5/Dana 300 - 4.10 Dana 44 Rear/Dana 30 Front w/ ARB lockers front/rear - 4" BDS Suspension w/ Fox 2.0 Shocks - Ground Pounder Fab Front Shorty and Rear Spare Custom Bumpers - PSC Steering w/ Borgeson Shaft - 33x10.50 BFG KM2 on 15x8 Mickey Thompson Classic III - Work in progress.....
TrebleHook is offline
post #565 of 1072 Old 04-29-2013, 12:58 AM
cabbage23
Hi all, great thread with a lot of great info. Its helped me a lot thank you!
Ive pretty much finished (kinda) the OME upgrade to my 81 CJ7. I used heavy duty rears on all four corners and basically parted it all out seperately (thats prob why its taken me 3 years ). I did not move the front spring hanger forward. I used YJ shackles and 2.5" Rock Equipment shackle hangers for the conversion. The front has lifted at least 1" more than the rear but im hoping this will settle somewhat due to the extra weight up front.
The shackle hangers are a true 2.5" but it seems the springs are actually only 2.25" wide. So my shackles are at what looks like an unhealthy angle \ /. Has anyone else found this to be a problem? Did I buy the wrong hangers?
cabbage23 is offline
post #566 of 1072 Old 04-29-2013, 01:51 AM
VooDoo2
1978 CJ7
The OME bushes are smaller in the shackle hangers and larger in the springs which fix the issue you have. I have a pic in this thread somewhere. You may not have noticed and put them in the wrong way around. Aftermarket bushes may not have this feature.
Edit: found it
VooDoo2 is offline
post #567 of 1072 Old 04-29-2013, 02:10 AM
cabbage23
Ahhhhh thanks VooDoo2 im sure thats it. Ill check it out this weekend. Appreciate your help
post #568 of 1072 Old 04-29-2013, 11:03 AM
Renegade82
1982 CJ7
There are small part numbers on their sides too.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #569 of 1072 Old 04-30-2013, 05:02 PM
JPurcell
1981 CJ7
Shocks for OME 2.5 conversion
OK i installed my 2.5 spring coversion back in 2009. I did got the conversion from Rocky Road Outfitters (springs, frount shakles, shock mounts front and rear and stabilizer mount (front). It has been awesome! A huge improvment over stock on and off road performance.
Currently I am running some Tuff Country shocks that I had on my prior suspension but I think that my ride could be further improved by changing out to some other shocks with more travel. Any member recommendations (OME, Bilsteins)?
JPurcell is offline
post #570 of 1072 Old 04-30-2013, 05:40 PM Thread Starter
Matt1981CJ7
1981 CJ7
I've liked my OMEs, but I haven't been impressed with the durability of the finish on them. Small rocks chip the paint easily, exposing bare metal, and leading to early rust.
When I buy a new set, I will probably go Bilstein, because I know their finish lasts a lot longer.
Matt
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 07:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 10:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 06:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 10:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 10:48 AM
