Old Man EMU 2.5" YJ to CJ Suspension Install - Page 35 - JeepForum.com
 2Likes
post #511 of 1054 Old 01-27-2013, 10:33 PM
mvigo
mvigo's Avatar
Matt,
I like the "Crabtree" art and welcome to his club!
My pal and I are waiting for our Crabtree shackles and hangers to finish up his OME 2.5" suspension swap. The install is super easy thanks in part to this thread.
I don't recall reading or seeing it anywhere but wanted folks to know that if they intend on installing sway bar quick disconnects they will need to take off the old sway bar links from the stock sway bar and those damn things are pressed on (think ball joints). We had a helluva time removing them from my pal's '86. For awhile I was thinking they were threaded in there but we ultimately took the sway bar off, clamped it in a vise and took a BFH to the end links until they finally popped out.
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #512 of 1054 Old 01-29-2013, 11:35 AM
Renegade82
1982 CJ7
Rispony - Here is the Warrior Products skid for the front, bought thru okay4wd. It's part of their Rock Granite conversion kit.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #513 of 1054 Old 01-29-2013, 11:48 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
mvigo,
Thanks. Jim does a great job with his shackles. They are incredibly stout compared to the factory. The Ol' Girl just feels safer with them. Well worth the premium price, IMO
Thanks for the tip on the sway bar links. Have you or anybody determined how much more flex these OME suspensions have without the sway bar connected?
Matt
Matt1981CJ7 is online now
post #514 of 1054 Old 02-04-2013, 01:30 PM
mvigo
mvigo's Avatar
Originally Posted by Matt1981CJ7
mvigo,
Matt
You have seen a picture of my CJ disconnected, it flexes quite a bit more. Once we get my pal's buttoned up I will try and remember to take some pictures with and without the sway bar connected.
mvigo is offline
post #515 of 1054 Old 02-13-2013, 07:42 PM
RedRaiderCJ7
I have a question for you guys. If you're piecing together your kit, do you buy cj u-bolts or yj u-bolts? Or does it matter?
Thanks
RedRaiderCJ7 is offline
post #516 of 1054 Old 02-13-2013, 08:41 PM
mooncruiser
Thanks
Same U-bolts as CJ. The front ubolt plates are your concern, you can use your existing rear plates, but will need to modify the front plates or buy YJ plates, due to the leafs being wider (2.5") in front than the CJ springs(2"). The rear springs on your CJ are already 2.5" wide.
** See Renegades post up above
I had my front plates modified for the wider springs.
mooncruiser is offline
post #517 of 1054 Old 02-14-2013, 09:01 AM
RedRaiderCJ7
Thanks mooncruiser!
post #518 of 1054 Old 02-14-2013, 01:33 PM
Renegade82
1982 CJ7
Thanks
I used the u bolt sets from Rancho. I think the numbers were something like 711 & 712 for about $30/axle. You can buy cheaper priced ones but these were gold zinc plated.
post #519 of 1054 Old 02-14-2013, 05:55 PM
waterdowg
Looks like its this kit Rancho kit RS712 http://www.summitracing.com/parts/ran-rs712
waterdowg is offline
post #520 of 1054 Old 02-14-2013, 10:02 PM
mooncruiser
I think those are the ones I used
post #521 of 1054 Old 02-15-2013, 09:35 AM
RedRaiderCJ7
Perfect, thanks guys
post #522 of 1054 Old 02-15-2013, 10:21 AM
Renegade82
1982 CJ7
Yes, thats them. They are both on sale now for $27.89/set at 4WD hardware inc. One of them came with alum. degree wedges too but throw them out and get some steel ones.
http://www.4wd.com/Jeep-Lift-Kits-Je...&t_pn=RANRS711
http://www.4wd.com/Jeep-Lift-Kits-Je...&t_pn=RANRS712
post #523 of 1054 Old 03-11-2013, 09:04 PM
arnold303
1981 CJ8
Can't wait to get my mind around doing this conversion. Just waiting on time and $$$. Great job all you guys who have contributed to this information.
arnold303 is offline
post #524 of 1054 Old 03-11-2013, 09:10 PM Thread Starter
Matt1981CJ7
1981 CJ7
Arnold,
I'm glad you found some useful info here.
Keep us posted on your progress.
Matt
post #525 of 1054 Old 03-12-2013, 01:09 AM
acgcoug
1979 CJ5
Well I think I made up my mind on getting this lift too. I will definitely be using all the great information that you guys have put forth in this thread. Thank you for that.
I will be working on my frame and axles very soon, and that means a rolling chassis with an OME lift to soon follow that.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 11:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 11:48 AM
