Old Man EMU 2.5" YJ to CJ Suspension Install - Page 33 - JeepForum.com
 2Likes
post #481 of 1054 Old 01-12-2013, 04:47 PM
rispony
1981 CJ8
I tried piecing it together but ended up with a more costly setup. Anyways, If its just the front mounts that I'll have extra, i'm not too worried about it. After examing the warrior shackles, it realized it realy is a much sturdier design since they're welded together. Awesome point Renegade. So now I'm placing an order for 2 pairs (4) Rear CJ shackles from Warrior and I'll let you guys know how the final stages of the install turns out. I really cannot wait to share all of your enjoyment with OME, M.O.R.E., Warrior and the likes...
This is the part for anyone interested.
http://www.quadratec.com/products/16145_118X_PG.htm
Follow my 1981 Jeep CJ-8 Scrambler build!
www.JeepCJ8.blogspot.com
rispony is offline
post #482 of 1054 Old 01-12-2013, 06:05 PM
mvigo
mvigo's Avatar
Originally Posted by Renegade82 View Post
mvigo - While Jims hangers are top shelf, not everyone can utilize them do to certain situations. Jim and I tried to figure out a solution for mine because I don't use a stock bumper or one of stock width. Mine is wider and where he has a void on the top to slide over the bottom, mine needed a void on top so it slid under the bottom. It's hard to explain without pics.
So my next best solution was the MORE hangers and these fit the bill quite nicely due to using the same holes and are stretched for the longer yj spring. I don't have the benefit of a third bolt for mounting like Jims', but it's the situation I'm stuck with.
Thanks Renegade, you learn something new everyday. I spent a few hours taking apart my pals suspension to put the OME springs on. He is now cleaning, painting parts and we will put back together next weekend. The one issue we are having is trying to get the sway bar links out...they are being stubborn.
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #483 of 1054 Old 01-12-2013, 08:53 PM
Renegade82
1982 CJ7
rispony - Those include the bushings, sleeves, and greasable bolts, which you already have. Get the ones without and save yourself $110.
http://www.quadratec.com/products/36045_210X_PG.htm assuming you want a 1/2" of lift.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #484 of 1054 Old 01-12-2013, 09:57 PM
rispony
1981 CJ8
I love you.
rispony is offline
post #485 of 1054 Old 01-13-2013, 01:59 AM
Renegade82
1982 CJ7
Heyyy, lets not go gettin' all mushy now. I got a reputation to keep man!
post #486 of 1054 Old 01-13-2013, 07:40 AM
kmm
This may be a real dumb question which Im sure has been addresed and I just cant come across the answere. I know the front yj springs are wider in front wich require a wider shacle and bushings. What is done about the mount on the frame side. Any modifications there required?
Thank you,
kmm is offline
post #487 of 1054 Old 01-13-2013, 07:49 AM
waterdowg
Thank you,
You will need to replace the front shackle hanger with either a MORE or Crabtree shackle hanger. This will give you a 2 1/2" hanger.
There are other brands but these 2 are the easiest to install as they do not require drilling out the rivit in the frame.
waterdowg is offline
post #488 of 1054 Old 01-13-2013, 08:00 AM
kmm
Maybe I wasnt clear with my question. But what about where the springs mount on frame opposite from shackle side. Is there no modification needed there for the wider spings? Just different bushings?
Thanks again, just trying to understand
kmm is offline
post #489 of 1054 Old 01-13-2013, 08:08 AM
waterdowg
No those are already 2 1/2". Nothing needs to be done there. I never under stood why they made that 2 1/2" then used 2" springs.
post #490 of 1054 Old 01-13-2013, 08:10 AM
kmm
OK, thanks, exactly what I wanted to know. Yeah, it had me wondering same thing.
kmm is offline
post #491 of 1054 Old 01-13-2013, 08:54 AM
GlennLever
GlennLever's Avatar
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #492 of 1054 Old 01-13-2013, 09:10 AM
highred
1979 CJ7
Originally Posted by GlennLever View Post
The best way to remove shackle and or sway bar bushings is to drill out the rubber with a 1/4 drill bit. Go around the bushing in a circle until you turn it into swiss cheese. They usually fall right out.
highred is offline
post #493 of 1054 Old 01-13-2013, 05:14 PM
kmm
lol...burn them if all else faills
kmm is offline
post #494 of 1054 Old 01-13-2013, 11:19 PM
mvigo
mvigo's Avatar
thanks for the ideas!
mvigo is offline
post #495 of 1054 Old 01-14-2013, 12:08 AM
VooDoo2
1978 CJ7
OK... playing around with the rear OME springs today while i wait for the shackles to get here and found the OME bushes are different. The diameter is the same (measured) but the end of the bush is different (see pic)
Also OME only supply a metal sleeve for the the non-shackle end. Im pretty sure there is supposed to be one in the hanglers and shackle end of the spring too but the only referance is to a plastic sleeve.
Anyone know what the go is here?
VooDoo2 is offline
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 11:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 11:48 AM
