Old Man EMU 2.5" YJ to CJ Suspension Install - Page 21 - JeepForum.com
 6Likes
post #301 of 1075 Old 01-01-2012, 06:35 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by mtrdud View Post
Well I got everything mounted up and I noticed my front shackles were "flexed" way forward. I used the stock mounting holes and after looking back at some other posts I realized the hangers should be moved more forward. My question which holes? Do I use the front ones where the rivets are? Matt, your pics are good but I couldn't exactly tell which holes you used?
Thanks
Yes, you have to move the front shackle mounts forward about an inch. You'll have to grind the frame rivet closest to the current mounting position.
This picture should tell the story.
Matt
Matt1981CJ7 is offline
post #302 of 1075 Old 01-01-2012, 06:36 PM
mtrdud
1984 CJ8
Which Holes - Hangers
Treblehook,
So you used the one that the rivet is in as your "forward most" hole and still have the front bumper mount hole right?
mtrdud is offline
post #303 of 1075 Old 01-01-2012, 06:38 PM
mtrdud
1984 CJ8
OK, Same question Matt. You use the "rivet" hole and the one behind it right? You still have a bumper mounting hole left correct?
mtrdud is offline
post #304 of 1075 Old 01-01-2012, 06:41 PM
mtrdud
1984 CJ8
Hangers
So you used the rivet hole and one of the stock mounting holes?? Do you know what size bolt you guys used for the forward rivet hole?
mtrdud is offline
post #305 of 1075 Old 01-01-2012, 06:46 PM Thread Starter
Matt1981CJ7
1981 CJ7
Yes.
I don't recall the bolt size, but it was similar size to the others.
Matt
post #306 of 1075 Old 01-01-2012, 06:53 PM
mtrdud
1984 CJ8
Front Hangers
OK, Thanks. I knew something didn't look quite right!
mtrdud is offline
post #307 of 1075 Old 01-08-2012, 06:50 AM
mtrdud
1984 CJ8
Front Bumper
OK, got the front hangers moved forward last night and yes that looks more like it. I have a stock front bumper and sat it up on the frame mounting area and I see that some grinding will need to be done to use this bumper. How much did you guys remove ? Also, did you just end up with top mounts?
Thanks
mtrdud is offline
post #308 of 1075 Old 01-08-2012, 07:02 AM Thread Starter
Matt1981CJ7
1981 CJ7
mtrdud,
We're starting to cover the same material twice on this thread. I know, it's getting a little long to scoll thru the pages.
Anyway, the bumper grind is pretty simple, you don't have to take much to make everything fit. Here's a pic. Alternatively, you could have cut the shim, under the shackle bracket, a little shorter.
Hope this helps,
Matt
post #309 of 1075 Old 01-08-2012, 07:09 AM
mtrdud
1984 CJ8
Front Bumper
Matt,
Yeah I know this has probably been covered and your picture is about what I had figured I would do. I will hopefully have some pics coming soon. This seems to be a nice lift and from what I have seen so far and it tries to keep the other wheels "on the ground" when flexed. Does that make sense??
I don't know if anybody has this lift on a Scrambler but it looks dang good on my CJ8.
I will be bleeding the brakes this morning and hopefully posting some pics soon.
Thanks for all the help guys.
mtrdud is offline
post #310 of 1075 Old 01-08-2012, 07:21 AM Thread Starter
Matt1981CJ7
1981 CJ7
No problem. FYI, the bumper notch and rivet grind was covered back on Page #4.
You did install the shims for the front shackle brackets, correct? Those are intended to create enough room for the bumper to fit without modification. Unfortunately, my shims were a little long, so I had to grind my bumper anyway.
I can't wait for you to take her for a spin. I bet the springs are going to make your longer CJ8 ride smoooooth!. The little bit of lift is going to look good, too.
Matt
post #311 of 1075 Old 01-08-2012, 07:29 AM
mtrdud
1984 CJ8
Shims
Well my kit didn't come with any shims but after looking at yours it does make sense. I'm gonna go take a look and decide. I have some flat stock at about that size and I can cut and make some if I see that it will help the situation.
mtrdud is offline
post #312 of 1075 Old 01-08-2012, 07:37 AM
mtrdud
1984 CJ8
Shims
Well I guess either way you won't have a lower bumper bolt so I guess with a shim = less grinding. No shim = more grinding. We will see.
mtrdud is offline
post #313 of 1075 Old 01-08-2012, 07:54 AM Thread Starter
Matt1981CJ7
1981 CJ7
Yeah, I believe the shims are just 3/16" or 1/4" stock with the necessary holes drilled in them.
I think a little shorter bolt may work for the lower bumper connection.
Matt
post #314 of 1075 Old 01-08-2012, 04:27 PM
mtrdud
1984 CJ8
OME Lift
Well I ended up fabricating some shims and I'm glad I did. I was also able to get the bottom bumper bolts in as I put all back together. I was able to get it all back together and take it for a spin. I was pleased with the ride but my steering has a bit of "wander" in it but I had some before the lift so I'm not sure if that had anything to do with it.
I also feel I need an alignment too as soon as I sort out the steering.
All in all I am pleased. I know once I work out the kinks it will be a good addition to the Scrambler.
mtrdud is offline
post #315 of 1075 Old 01-08-2012, 04:38 PM Thread Starter
Matt1981CJ7
1981 CJ7
Have you measured your caster? I had to remove the OME factory shims and install 4 degree shims to get within spec.
Matt
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 07:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 10:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 06:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 10:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 10:48 AM
