Old Man EMU 2.5" YJ to CJ Suspension Install - Page 18 - JeepForum.com
 2Likes
post #256 of 1054 Old 09-28-2011, 04:32 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Nice!! Not having to cut and punch the rivets is definitely a plus.
I can't wait to see the rest of it installed.
Matt
Matt1981CJ7 is offline
post #257 of 1054 Old 10-28-2011, 04:48 PM
David2012
Originally Posted by ErikEastman View Post
Thanks, looks a little different now, I put family style bars on it and a safari top.
great conversion. did mine that way too and i love it. have any pics of your?
Electrical gremlins will be the death of me... 85 cj7
David2012 is offline
post #258 of 1054 Old 10-29-2011, 08:36 AM Thread Starter
Matt1981CJ7
1981 CJ7
Wow, this has turned into a nice thread!! I'm glad you guys are finding it useful. I wanted to update you on my suspension now that I've ran with it for a few months.
The exceptional ride quality hasn't changed, if anything it's gotten smoother as the springs and bushings have worked in a bit.
As for settling, there hasn't been any. The ground to top of wheel-well measurements remain exactly same as they were shortly after the install. There is absolutely no signs of the dreaded "Jeep Lean".
That's the peaches, here's the pits. The individual leafs on 3 of 4 of my springs shifted around slightly, causing them to have a slight vertical stagger, instead of stacking straight up and down. Although I had torqued the u-bolts to spec, upon inspection I found they had loosened considerably. So I straightened the leafs and re-torqued the u-bolts. One of the springs still wants to shift a little, but the other 3 are staying straight. I think this is a minor issue, but worth keeping an eye on.
Secondly, after putting about 3K miles on the current alignment, I decided I could use a little more caster in the steering. If you recall, my caster was 5 degrees positive after reversing the shims on the OME springs, which is at the low end of spec. The Jeep handled fine at this angle, but it returned to center a little slow for my tastes.
So, I replaced the OME shims with a set of Warrior 4 degree shims (the OME shims are 1.5-2 degrees) just a few days ago. BINGO!! Now, finally, I can honestly say the Ol' Girl rides and steers better than new. I can now casually drape one hand over the wheel and completely forget that I'm driving and just enjoy the ride.
Anyway, I still recommend this suspension whole-heartedly for any of you hoping to upgrade. It's my favorite mod to date on mine.
Matt
post #259 of 1054 Old 10-29-2011, 08:56 AM
gpower77
Matt,
Good read, good job with lots of info and pictures. Ive got a CJ7 with a 4" superlift, rides like a tank! Bought it this way, so I am wanting to get rid of the 35's and just have a 2.5 lift, and go with 32's. SOOOOO seein your not that far from me, ill just bring the jeep over and leave it a few days, and maybe your jeep and mine will swap parts real quick! Just wanted to say thanks for the info, I have been looking at the BDS setup, but after reading this I am seriously considering this route.
Garry
gpower77 is offline
post #260 of 1054 Old 10-29-2011, 09:05 AM Thread Starter
Matt1981CJ7
1981 CJ7
Garry,
Thanks. The BDS also gets good reviews. I don't think you can go wrong with either.
As for swapping parts, you'll have to wrestle me for them, because none of these parts are going anywhere without a fight!
I'll be happy to help you in any way I can, neighbor.
Matt
post #261 of 1054 Old 11-12-2011, 07:18 PM
lavern23
I did this swap to my scrambler about 8 years ago and used the BDS yj 3.5 springs an a MORE shackle reversal and used confer shackles. I am running 33x12.50 on a 15x9 rim. It still rides great and handles great as well. Glad you all have had the same luck.
lavern23 is offline
post #262 of 1054 Old 11-12-2011, 08:26 PM
1986cj
Great info Matt. My wife thinks my 86 Cj needs new shocks. It is not to great on the washboard roads any more or maybe it is we are just getting older. I have been thinking about swapping in wrangler springs for a while now. Maybe I can talk her into new springs too. Were you in Victor in October this year? I sure saw a Cj like yours at the turn off to phantom canyon as we were up there checking out the Aspen trees changing. Bob
1986cj is offline
post #263 of 1054 Old 11-12-2011, 09:42 PM Thread Starter
Matt1981CJ7
1981 CJ7
Bob,
Thanks, I'm glad you find the thread helpful.
It wasn't me in Victor, though that's certainly the type area you're likely to find me.
Matt
post #264 of 1054 Old 11-12-2011, 10:25 PM
85LaredoCJ7
Matt, how close are you to Durango or Valecito?
85LaredoCJ7 is offline
post #265 of 1054 Old 11-13-2011, 05:08 AM Thread Starter
Matt1981CJ7
1981 CJ7
Not very, about 6-7 hours. Those places are in southwest Colorado, I'm central.
Matt
post #266 of 1054 Old 11-13-2011, 07:29 AM
85LaredoCJ7
Wow...farther than I thought.
post #267 of 1054 Old 11-20-2011, 03:12 PM
peterbilt1
1979 CJ7
ok guys this thread has been amazing, I am doing the yj conversion to my 1979 vj7 golden eagle. Thank you guys for taking the time and posting all this information. It has made my yj conversion experience a walk in the park.
I will post some pics and information on my experience, but i do believe you guys covered everything.
peterbilt1 is offline
post #268 of 1054 Old 11-20-2011, 03:34 PM Thread Starter
Matt1981CJ7
1981 CJ7
peterbilt1,
I'm very pleased this thread has been helpful to you, and I can't wait to see your rig with it's new legs!!
My suspension has just gotten better and better as it breaks in a little. What's interesting is I haven't realized the slightest bit of settling or sag, even though the ride has gotten smoother. As stated, I have had to straighten a slight stagger in the leafs, and re-torque the U-bolts, after about 3K miles, but they haven't moved since.
Matt
post #269 of 1054 Old 12-14-2011, 03:35 PM
maloneyb
1979 CJ7
Old Man Emu Shocks
Hope it hasn't been addressed before...
Just got an OME YJ to CJ suspension conversion kit for my 1979 CJ7 that's supposed to provide 2.5" - 3.0" of lift. The kit did not include shocks. I was planning on going with OME shocks. My question is with the model number for the shocks. I need heavy duty shocks due to hard top on back and V8 and winch up front. Do I need the N42 (front) and N56 (back) shocks?
Thank you!
maloneyb is offline
post #270 of 1054 Old 12-14-2011, 08:18 PM
mtrdud
1984 CJ8
YJ to CJ Kit
Well according to UPS tracking my stuff should be here tomorrow. Going with the OME Heavy kit from QUADRATEC and OME shocks. I also ordered shackles from Crabtree. My son should be here for Christmas next week and we are going to put it all on my Scrambler. Can't wait to see how much this improves the ride and stance. I have been a long time Landcruiser guy and OME is condiered top notch with Landcruiser enthusiasts. I will take some pics and post them up.
STEERING DAMPER - This is the only part I haven't figured out yet. Since OME doesn't make one for a CJ, what do you guys suggest? I hate to mix all that OME Yellow with something else.
mtrdud is offline
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Trapshooter's BDS 2.5" Suspension Install Thread - Photo Heavy Trapshooter Jeep CJ Forum 122 06-19-2014 11:32 AM
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 11:40 PM
CJ5 With 33's on 4" Suspension and 1" Body Jeff5886 Jeep CJ Forum 11 07-02-2007 11:48 AM
