Old Jeep-New Sound - JeepForum.com
post #1 of 10 Old 11-29-2008, 06:56 AM Thread Starter
newjeepowner
Old Jeep-New Sound
My 79 cj-7 suddenly began making a grinding type sound when I shift into 3rd gear. The sound is there before I disengage the clutch and sounds like it is coming from near the bottom of the stick (not deep in the bowels of the transmission)....I am not very mechanical but could this be loose linkage or something else not too complex? PLan on looking closer later today but wanted to get some sense fo what I might want to look for..
THe sound does not stop after releasing the clutch...more like chattering/grinding associated with the stick...thoughts?
newjeepowner is offline
post #2 of 10 Old 11-29-2008, 07:17 AM
2005BlackRubi
My new cj 5 also makes a grinding noise when shifting into 1st gear
National Topless Day 2-3-2009
2005BlackRubi is offline
post #3 of 10 Old 11-29-2008, 08:32 AM
CJhollic
1980 CJ7
Syncros in the transmission most likely.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #4 of 10 Old 11-29-2008, 09:29 AM Thread Starter
newjeepowner
thanks...any other thoughts? just to be clear, it only applies to third gear and sounds more like a bad chattering of something rubbing . No problems exist shifting into or out of the gears...
post #5 of 10 Old 11-29-2008, 06:09 PM
skidplate77
1977 CJ7
I know Chevy four speed can have the problem of when shifting into third, there is a fork bushing that wears out, making a chattering, grinding sound. May people have the habit of hanging onto the stick after shifting, and put extra stress on the fork bushing. which will do undo wear on the bushing. I'd also check the clutch fork and throw out bearing.
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock..
A new work in progress, and a new lease on life...
skidplate77 is offline
post #6 of 10 Old 11-29-2008, 06:11 PM
PILL
Sounds like the syncro is going bad. Have you tried double clutching?
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #7 of 10 Old 11-29-2008, 06:24 PM Thread Starter
newjeepowner
I'll try and look a bit tomm (might try moving it in and out of 4wd as well)...thanks for the ideas but i might need to enlist my more mechanical friends. Thanks to all for the leads though!
post #8 of 10 Old 11-30-2008, 09:26 AM Thread Starter
newjeepowner
Update
Hopefully this provides a bit more clarity to my recent issue.
First off, if it is the syncros, how bad a job is this to do (part/tools/effort/time)? and any direction on how to fix, where to get parts, etc. is appreciated. Again, I am fairly inept but I might be able to borrow tools/talent to help me.
The jeep runs fine in first, second and reverse (although I have to go slowly into reverse with low rpms or the stick 'chatters' just a littel a bit like something is spinning against the stick as it wants to go in gear.)
At a stop, i can shift into any gear easily, regardless of RPM's as long as the clutch is in. I also can shift into 4wd (high or low) without any offending noise.
When rolling (~30mph) and running in second, if i try and shift into third, the stick moves easily enough but as I begin to put it into gear (clutch in), the rattling comes in strong, like something not 'moving all the way out of the way' that would allow me to shift into third w/o the chattering. I can go into third but noise suggests it is a very poor idea to leave it in gear! As a result, i don't want to make a problem worse and keep it out of third.
Any help in confirming the diagnosis or fixing the problem is greatly appreciated. The sad part is winter is here and I just got my heater working
post #9 of 10 Old 11-30-2008, 03:41 PM
CJhollic
1980 CJ7
Still sounds like syncronizors to me. You probably dont want to attempt yourself given the way you described your mechanic skills. I wouldnt try it myself. You can take it to a machine shop and have it rebuilt for 400 bucks.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
CJhollic is offline
post #10 of 10 Old 11-30-2008, 05:34 PM Thread Starter
newjeepowner
ok thanks...is this something i could confirm by taking off the top of the transmission from the inside?
Time to call up a favor from a friend!
Jeep won't start - buzzing sound from dizzy/coil area danheit Jeep CJ Forum 3 05-24-2015 02:11 PM
Awful sound when turning jeep off Aduffy32 Jeep CJ Forum 9 10-30-2009 03:26 PM
Does this sound about right? SeaWulf Jeep CJ Forum 3 08-10-2009 06:54 AM
I want my Jeep to sound deeper. sundownbrown Jeep CJ Forum 11 07-05-2009 09:41 PM
Jeep making a funny sound NMPhi767 Jeep CJ Forum 2 10-16-2005 04:55 PM
