The old "How should I build it?" thread again...
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
My CJ is going to be my winter project. I've got a Star-Jones-butt-load of questions for y'all. I'll post as they come to me.
(Yes, I used the search function...so don't send me there. I've searched my little heart out.) #1) I am considering a coil-sprung setup. Any good build links or advice of how to do this? #2) Axles: I know everyone has different opinions about this, but what would you guys recommend if I'm using a 360 or 401 (or maybe a SBC) with 35"-40" tires? #3) Roll cage: I've searched and searched...what is the best solution for me if I want a family-style (full cage) that retains the four-person seatability I have now? Do they exist? #4) Frame: Do I need to reinforce that mother? It's rust-free, but is it strong enough in stock form? (More questions to come...) Thanks! - Tyler
- Red '84 CJ-7 - I'll build it someday! I have the parts, but no shop and no time! :( - Black '78 J-10 - rollin' on 37s and SOA with front/rear Detroits, high-steer, etc. - Green '93 ZJ - Crusty old PARTS-GIVER TO THE CJ! "Six in a row makes it go" ...and a driveway full of Subarus... |
#2 |
Frame should be fine. Having a roll cage custom built and tied into the frame would be your best option. Also have the seats mounted to the frame as part of the desing.
For 40" tires I'd go with Dana 60s or 14 bolt set up. Whether or not you will need to narrow them will depend on the laws in your state. Coil springs would be a total custom set up of course. The Pirate board would be your best bet for information. If you Google it, that's probably where you'll be sent. Why not keep it simpler and go with a sprung over set up?
What's left of a '79 CJ5 3 - 4" total lift 4.88 gears in a Dana 30 and off center ff Dana 44 with disc brakes 258 with TFI /T18 /D18 drive train with Saturn O.D. 33 x 12 DC Mud Country Radials |
#3 | |
).Any other input on the coil vs. SOA issue?
#4 |
IF you've searched, you've seen all the answers. 2+2 always equals 4 no matter how many people ask. What new info specifically are you looking for?
Never underestimate the power of stupid. |
#5 | |
Any help?
#6 |
CJ OWNER FOR LIFE
Heres just some ideas to cut out a lot of headaches...but it cost..
Throttle Down Kustoms CJ frame with TJ style coil mounts (galvanized as an option) Rubicon Dana 44 axles to get lockers and straight bolt in. 4 inch coil lift 35s of your choice and I'd give up the 360 to have a MPFI 4.0 or add a Howell FI kit to the 360 or 401. Use a late YJ cage and add to it OR a poison spyder cage Then I would add Poison Spyder crusher corners and sliders and tube fenders w/3 inch tube flair. All the rest would be CJ (hood/grill/dash/tailgate) I personally like the CJ cage better as a triangle is harder to fold flat than a box....meaning 3 pivot points vs 4.
Ed 1975 CJ-6 304 T15 Dana20 30/44 3.73 1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade 1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31 1986 TJ-7 Trail Jeep project in the works 2003 Inca Gold TJ Rubicon |
#7 |
I've seen YJ bars crush too easily. You can get a good cage built for a fair price.
#8 |
what I would do..
1..research the heck outa coils Vrs. soa..I would most likely go soa cuz theres alot of info out there and people have been doing it correctly for quite a while 2.what ever you can afford. 3 custom cage..tied into the frame at all points and possibly twp legs through the fire wall out to the front of the frame 4.go over the frame with a fine tooth comb..get it blasted and go over all the welds..tying in the cage to the frame makes it very ridged..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#9 |
GROUND POUNDER
Since there's really no low budget way to accomplish this let me help you spend your money..
I'd go coilovers. Compact, infinately adjustable, ride well (if setup properly) and super bling factor. Do a dual triangulated 4 link out back and either a single triangulated 4 link or a 3 link/panhard up front. This lets you adjust your wheelbase wherever you want it. Run a couple of Dana 60s with alloy shafts and 4 wheel disks. 1350 or 1410 driveshafts with at least 3/16" wall thickness (I fold up .120" wall like their drinking straws). Big rubber needs hydro assist. Avoid full hydro for a street driven rig. Invest in a bender/die and bend the cage up yourself. It'll just about pay for itself in that one project alone. Do a friend's rig and you'll be making money off it already.Now, once you get all that stuff done, buy a trailer and haul it around. Driving a 40" tired Jeep on the street is a PITA.. trust me.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#10 |
WTF is that?
More cage options than you could ever dream of
http://www.jeepforum.com/forum/f37/official-cage-idea-pic-discussion-thread-128237/
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#11 | |||||
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers. '83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff. http://www.jeepskate.net |
#12 |
I'd go SOA and use the M.O.R.E. traction bar and use Toyota 4runner OME (Old Man Emu) front springs with YJ shackles and hangers with a M.O.R.E. shackle reversal kit.. I say the toyota OME springs because the 4runners came with SOA setup stock, so they'll be a bit stiffer. The traction bar will take care of a rear pinon wrap issue. I haven't had much of a problem with wheel hop on the front end of my CJ. I have all this minus the traction bar now, but I need it.
As for axles, D60s for that big rubber you are after. As for cage, custom is the way to go and you'll be dollars ahead on a bender that way as Besrk stated. I like the poison spyder setup, but the shop I use occasionally voted against it because that's a lot of metal up high as the owner put it. You don't want to raise that center of gravity too much, that's just silly in a jeep. Frame probably fine unless you have cracks in it. I'd recommend M.O.R.E. again for their frame plates to keep the budget lower and keep from purchasing an entirely new frame. I suggest a new tranny cross member that can slide over the rocks instead of that rock snagging stock stuff too. You'll want something stiffer to attach that torsion bar too anyway in my opinion. |
#13 |
I'm thinking SOA is how I will roll. I don't have the experience/skills to take on a four-link project.
For the tires, I was thinking 37" Iroks, so from now on, let's assume this project is based on a pepped-up 401 and 37" ires. I've heard you can get Toyota axles to nearly D60-level strength. Is this true, and if so, is it a viable option?
#14 |
Since you are leaning toward coils and want a cage to protect 4 and a mountain motor.
Build frame up. I saw an article where a guy did just that. If that looks too time consuming and difficult, start with a TJ or go SOA.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word." Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7 |
#15 |
37's are a 'cusp' tire size...right on the top edge for Dana 44's and bottom edge for Dana 60's & 14-bolts. With the V8, I'd probably opt for a 60/60 or 60/14 combo. Can't really advise you on the Toy axles...not a real common swap and they have their own issues. The key is to research the costs of the upgrades. Alot of the time upgrading a lesser axle to the strength of a bigger axle costs more than just buying the bigger axle. It's one thing if you already have, say, a Dana 44 with all the trimmings running 36's and then upsize to 38's and spend the coin for alloy shafts and hi-zoot u-joints, it's a whole nother thing to have nothing with the intention of running 38's and go out and buy a Dana 44, then proceed to buy gears, locker, hi-steer, alloys, etc to get it up to Dana 60 strength...just buy the Dana 60, it'll be cheaper and still have the headroom to be made even stronger if need be. Kinda like the guys with the 'Fast & Furious' cars who drop big money on performance parts so they can beat a Mustang when they could've just bought the Mustang and still have the headroom to make it even faster with the same types of parts.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
