Is it okay to use 2wd low when offroad? - JeepForum.com
post #1 of 17 Old 09-29-2009, 12:54 PM Thread Starter
mm1582
1977 CJ7
I have spent the last week running my Dana 20 TC in (what seems to be 2wd low). Although not marked on the shifter, I am able to utilize the lower gearing by shifting my TC between "N" and "4L" without engaging my hubs. It is not the same engagement as pulling the shifter all the way down to "4L" and I am assuming it is okay to run it without locking the hubs. Am I gonna burn something up? I did not need 4wd, but did need the lower gearing thanks to the tall 1st gear in the t-150 3spd. Thanks
mm1582 is offline
post #2 of 17 Old 09-29-2009, 01:05 PM
Dmonkey
1976 CJ5
I'm interested in this as well, mine has no labeling for 2Lo , it goes 4H 2H N 4L but i have 2 distinct positions after N, both engage low range gears. I have the dana 20 as well.
Dmonkey is offline
post #3 of 17 Old 09-29-2009, 01:08 PM
Jeepican
1976 CJ5
Why not just use the 4low? Your already there....
Jeepican is offline
post #4 of 17 Old 09-29-2009, 01:09 PM
73jeep
1973 CJ5
yes it is... i use 2low all the time till i need 4lo, helps with steering and preventing driveline binding. also handy for moving trailers around.
73jeep is offline
post #5 of 17 Old 09-29-2009, 01:11 PM
Dmonkey
1976 CJ5
Ok so it is there then? I've used mine to pull out some small bushes and straighten the front bumper on my grandfathers truck after it was in an accident. its like having a tractor haha
Dmonkey is offline
post #6 of 17 Old 09-29-2009, 01:11 PM
CSP
Absolutely use it if you need it. Just be careful with the throttle as you're sending 2x the torque to just the rear axle.
CSP is offline
post #7 of 17 Old 09-29-2009, 01:27 PM
alex211
1995 XJ Cherokee
No problem with leaving it in 4low and the front hubs unlocked.
95 xj bone stock for now
alex211 is offline
post #8 of 17 Old 09-29-2009, 01:28 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
sometimes i need a little help thru a gully or, like another posted, to move a trailer around. So 2low w/ the rear ARB engaged = fast, easy traction. then kill ARB and go back to 2 hi.
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #9 of 17 Old 09-29-2009, 01:32 PM
adamsclarke
Twin stick the 20, and the leave the front in neutral and rear in low.
When wheeling, you don;t want to be out locking hubs every 20 seconds.
It'll also allow to to unlock a locked front for better turning and unlock the rear for front digs etc...
adamsclarke is offline
post #10 of 17 Old 09-29-2009, 01:45 PM
JeepHammer
Running On Empty...
1973 CJ5
I often shift into '2 wheel low' just to make mine steer better on trails when I don't want much speed...
You can make it an 'Official' detent in the linkage if you ever rebuild simply by grinding/drilling the selector arms when they are out of the case.
Nothing 'Wrong' with it, but if you hit something that makes the jeep jump, you may wind up in Neutral ... That's the only draw back.
It won't hurt anything in the case or your drivetrain if that is what you are asking...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #11 of 17 Old 09-29-2009, 01:58 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
x2 on JH's post-- sometimes i need low range traction for just a minute-- and rather than get out to twist the hubs, i just drop the single stick D300 into low range, hit the rear locker and its good to go.
wheel-on brothers!
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #12 of 17 Old 09-29-2009, 01:58 PM Thread Starter
mm1582
1977 CJ7
thanks for the feedback, nice to know I wasnt destroying something else! I am curious about the mention of the twin sticking, is there an existing string to address this or details available?
mm1582 is offline
post #13 of 17 Old 09-29-2009, 02:32 PM
CSP
This is what you have already with the shifter in the "ghost" 2Lo position.
It's the result of slop in the tcase linkage that allows the rear output shifter rod to engage low range before the front output shifter rod has moved out of neutral. If there wasn't slop in the linkage both rods would leave neutral and engage low at the same time. That's why it isn't marked on the shift knob as it wasn't intended to be there.
CSP is offline
post #14 of 17 Old 09-29-2009, 07:39 PM
adamsclarke
The twin stick mod allows you to control the front axle and rear axle independently of each other. Check out JB fabrication, they make a nice stainless twin stick set up. It's a bolt on deal and very easy and useful.
if you look at the dana 20, you'll see 2 shift rails. The stock shifter controls both of them at the same time. The twin stick puts a lever for each shift rail, so you can have independent control.
IMO a must for every xfer case, especially when you have a front locker.
post #15 of 17 Old 09-29-2009, 11:34 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Using lo in two wheel drive is a common tactic for owners with three speed transmissions. Before my tranny swap I used it constantly on such things a steep boat ramps, ,moving trailers around the property, fence repairs, etc... If your not in need of the front axle at all, simply drop the t case in 4 low and you won't have to monkey around finding the "sweet spot". While twin sticking is good for the hard rock crawler with a locker in front, it probably isn't necessary for the average wheeler and the cost in time and money to install it may not pay off.
jeepdaddy2000 is offline
Edelbrock offroad kit? mxracer919 Jeep CJ Forum 4 02-08-2010 08:46 AM
CJ5 vs CJ7 offroad IDK Jeep CJ Forum 18 09-23-2009 04:01 AM
offroad lights? myzoo Jeep CJ Forum 15 06-10-2009 03:45 AM
OffRoad Carb liljeeplover Jeep CJ Forum 24 01-14-2009 05:22 AM
Cj Offroad Pics jeepnut00 Jeep CJ Forum 27 07-27-2005 11:04 AM
