Ok...trans swap question. - JeepForum.com
post #1 of 4 Old 07-29-2011, 06:00 PM Thread Starter
sprbeast
1983 CJ7
Ok, I currently have an '83 CJ7 that the trans blew on me twice in the last year and a half now. The only thing that wasn't replaced when the shop built it was the case and the shifter (supposedly).
Anyway, my questions are as follows. I came across a '79 with the I6 and a four speed (assuming the T18 which were the option), how hard would it be to just remove the trans and t-case from the one and swap?
The other reason I am even entertaining this is because I can use a bunch of parts off of the donor Jeep for my CJ5 project I have going on.
Thanks in advance for help guys.
sprbeast is offline
post #2 of 4 Old 07-29-2011, 07:02 PM
Tigerjeep79
1979 CJ7
You'll love the T-18. It shifts like a truck (it's a truck transmssion), but that granny low 1st gear is really nice, and you'll never break it with a 258. Mine is out of a J-truck and it's a beautiful thing. The downside for you would be swapping in a Dana 20 transfer case in lieu of your Dana 300. You could adapt the 300 to the T-18 with a little research and money. The D20 is not a bad transfer case, but your 300 is better. Driveshaft lengths may have to be adjusted.
Tigerjeep79 is offline
post #3 of 4 Old 07-29-2011, 07:08 PM Thread Starter
sprbeast
1983 CJ7
I'm not against swapping the t-case I have now seeing as it doesn't work. I am probably the only person with a one wheel drive Jeep when I have it in four low.
sprbeast is offline
post #4 of 4 Old 07-29-2011, 07:27 PM
BlueRubiconrich
No so fast you can run a 1980 Scout Dana 300. The Only Dana 300 that bolts up to a T18. You will need the bull gear from a T19
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
cj7 trans swap question afgd1 Jeep CJ Forum 4 06-04-2011 07:43 PM
Trans swap question jerkbait Jeep CJ Forum 2 12-30-2010 08:22 PM
trans and TC swap ? jm708 Jeep CJ Forum 5 02-10-2010 05:04 PM
Trans swap question dragracer1199 Jeep CJ Forum 5 05-06-2009 08:11 PM
Trans. swap? BOSSMAN Jeep CJ Forum 5 03-09-2003 06:16 AM
