ok so i got it to turn over but it wont run - JeepForum.com
post #1 of 12 Old 06-28-2006, 11:57 AM Thread Starter
bkeast17
OK, so we figured out why the solenoid was clicking and buzzing, battery was dead. We have it so the engine will turn over but it will not fire. Maybe it is a fuel problem?? How would I know if the fuel pump is not working right? I know that is a cheap fix. COuld it be something with the distributor? I posted before stating the PO put some new dist on and it only has one black wire coming out of it to the coil where it splits to a red wire going to the coil and another red going to ignition.
bkeast17 is offline
post #2 of 12 Old 06-28-2006, 01:42 PM
thebeast77
Well to see if you are getting fuel to the carb just unhook the line at the carb and wedge a soda bottle in there and put the line in there. Have someone turn the key while you look for steady adaquate flow. If that is good next I would look to do a compression test on the cylinders. Im not sure what the psi is suppose to be but mine was between 130 and 155 and it runs fine. If that is fine I would try to find somebody you know that knows how to work a timing light and make sure you timing is in check. If that checks out unplug a spark plug and pull back the boot. It is very important to hold the wire with insulated pliers when you do this. Once you have the metal contact exposed scratch a grounding spot some where like the grill supports that run though the engine compartment. Have some one crank the engine and see how far you can make the spark jump. You should get a nice pretty blue spark about a inch long. If you dont then you need to check you electrical conections if those are good the first thing i would replace is your spark plug wires. If that doesnt do it you need to look in to replacing the electronic ignition control box(thiswas the main culprit on mine). It is a little box mounted down on the passenger fender. Really simple to replace just one connector and 4 screws. I got mine from autozone but I forget how much. Now if that doesnt do the trick next would probly be the coil followed by the distributer cap and rotor.
Fellow jeepers this is what I did to get mine running but if it would make more sence to do it differntly please post but it makes logical sense to me.
Hope I was of some help and you can get her running. Once you get her back up and running she wont quit for a while. I got mine running about 1000 miles ago and I have a leaking rear seal and a crack flexplate and it still going strong although I need to get the flexplate replaced.
Good Luck
thebeast77 is offline
post #3 of 12 Old 06-28-2006, 07:34 PM Thread Starter
bkeast17
Well we got it to run after putting more gas in haha. But then it would not stay running unless you pumped the gas so we thought maybe fuel pump was bad. Replaced that and the fuel filter. Now it just turns over but will not fire!! Was thinking now maybe electrical. Maybe the ignition module is dead as it is pretty well corroded from road salt. Might just tow it over to the shop in front of my work to see what they think.
bkeast17 is offline
post #4 of 12 Old 06-28-2006, 09:03 PM
4XGore
2 chicks at the same time
4XGore's Avatar
1980 CJ7
If you have a tachometer, try unhooking it. I had a similar problem that kept me guessing for years. I replaced the starter lock, the ignition module, had the engine rebuilt, and finally when I changed my dash, I unhooked the tach and problem solved. If you have a tach, give it a try, it can't hurt.
4XGore is offline
post #5 of 12 Old 06-28-2006, 09:43 PM Thread Starter
bkeast17
There is an aftermarket tach attached to the steering column. Should I just unwire it from the green wire that goes to the coil??
bkeast17 is offline
post #6 of 12 Old 06-28-2006, 10:26 PM
4XGore
4XGore's Avatar
1980 CJ7
My tach was from the factory and was part of the wiring harness. If it's an aftermarket tach. I doubt that is the problem. I noticed that when my jeep was having troubles, my tach was acting funny. The factory wiring has a conection port for the tach.. I disconected my tach. and put in a toggle switch as a kill switch, but like I said if you have an aftermarket tach. I doubt that is your problem.
4XGore is offline
post #7 of 12 Old 06-28-2006, 10:50 PM
ClarkGriswold
ClarkGriswold's Avatar
I installed a factory tach and did enough research to know that most after market tach are not in series with the ignition. I'll agree with 4xgore. If it's a OEM you've got to be careful wiring it or it will allow the engine to crank but never start.
ClarkGriswold is offline
post #8 of 12 Old 06-29-2006, 10:15 AM
KrazyGimp
1982 CJ5
Have you checked to see if you have spark yet? If you do, then it must be a fuel problem. Someone else started a thread like this about a week ago. Mine was doing the same type of thing so I recommended taking the fuel line off of the carb. There should be a fitting that the line hooks into on the front of the carb. Take that fitting off of the carb carefully, and you should find a check valve in there. Clean that up and reassemble. This fixed mine totally, it runs like a champ now. Just and idea...
KrazyGimp is offline
post #9 of 12 Old 07-01-2006, 02:36 PM Thread Starter
bkeast17
Well I replaced the fuel pump and fuel filter, new ignition module and new plug wires. I put gasket cement on the carb gasket and cranked the bolts down to fix the leak there so now it does run when I turn the key but it will die out unless I keep tapping the gas. Now I am thinking more of a timing issue. I will tow it to a shop Monday to have them check the timing and what not as I do not know how to do it, nor have a timing gun.
bkeast17 is offline
post #10 of 12 Old 07-04-2006, 03:07 AM
Uncle Russ
Uncle Russ's Avatar
Hi, just curious, do you know if your carb is properly adjusted? Is it the original Carter, those are notorious for being finicky on adjustments.
My CJ has been in stasis for the past 5 years and my father-in-law is having a similar problem, the engine will turn over but it will not start. He believes there's no spark getting to the plugs. My initial thought was to replace the ignition control box and coil (the plug wires are fairly new but not top-of-the-line) then distributor cap/button if necessary, but I don't know if he's following my recommendations, it's been 3 months and the Jeep still won't start.
Oh, did I mention I need the Jeep running and in California (it's currently in MS) by August?
Russ
“When you're swervin' on life's highway, you're runnin' someone off the road."
-- Robert Earl Keen
Uncle Russ is offline
post #11 of 12 Old 07-04-2006, 06:35 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Hey, how's this go'n ?
If you haven't got it fixed, try looking for broken vacuum hoses around the Carb area; something sucking air, may not be a hose, intake gasket maybe.
Turn up the idle on the carb and see if the engine will run at a faster idle, if it does it sounds like a vacuum leak and you will have to find it before you can time the engine.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #12 of 12 Old 07-04-2006, 08:41 PM
thenubsterman
ya almost sounds like a carb problem to, probably shouldn't of reused the carb gasket. Maybe a vaccum leak, ya see if it will run at higher rpms,
thenubsterman is offline
Cj7 Wont Turn Over!!! Help Plz cgi2099 Jeep CJ Forum 29 07-21-2014 10:58 AM
85 CJ7 will crank but wont turn over? HRW85CJ7 Jeep CJ Forum 18 09-29-2009 04:42 PM
74 cj5 401 will crank but wont turn over sherman401 Jeep CJ Forum 6 06-03-2009 05:47 PM
Wont turn right ! help? jbeenz Jeep CJ Forum 15 12-22-2006 08:09 PM
jeep wont turn over Fuzz21 Jeep CJ Forum 6 12-27-2005 05:53 PM
