OK to run a power steering pump with no fluid? - JeepForum.com
post #1 of 7 Old 04-17-2013, 01:04 PM Thread Starter
Jeeprage
Jeeprage's Avatar
My steering is leaking pretty badly and I want to get the Jeep together before I tear into another project. The power steering pump is dry now. Is it OK to run the engine with it dry? How about drive? I don't want to damage the pump, but I also dont want to continually fill it while most of the time it is sitting still.
2015 JKU - 6m
Jeeprage is offline
post #2 of 7 Old 04-17-2013, 01:12 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by jeeprage
my steering is leaking pretty badly and i want to get the jeep together before i tear into another project. The power steering pump is dry now. Is it ok to run the engine with it dry? How about drive? I don't want to damage the pump, but i also dont want to continually fill it while most of the time it is sitting still.
do not run the pump without ps fluid!!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 7 Old 04-17-2013, 01:18 PM Thread Starter
Jeeprage
Jeeprage's Avatar
And THAT is why I post here.
Thank you.
2015 JKU - 6m
Jeeprage is offline
post #4 of 7 Old 04-17-2013, 01:20 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Is the pump itself leaking, or just one of the hoses?
Matt
Matt1981CJ7 is online now
post #5 of 7 Old 04-17-2013, 01:30 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Matt
I think it is the steering box. The lines don't look great, but appears to be leaking from the box itself. I haven't been able to drive the Jeep yet, although I was able to move it 20 feet in 1st and Reverse.
I do plan to eventually replace with H1 box if it is indeed toast, and install new lines, but I'm 8k into a non-assembled and unpainted Jeep. Need to draw a line.
2015 JKU - 6m
Jeeprage is offline
post #6 of 7 Old 04-17-2013, 02:03 PM
Matt1981CJ7
1981 CJ7
Well, if it's just the box leaking, and you can deal with no power steering, you can loop the high pressure line back to the return side of the pump, creating a closed loop at the pump. Then stick just enough fluid in the pump to keep it from burning up.
That's what I did when I dyno tested mine, since the dyno machine didn't have any provisions for the PS pump. I made the "loop" out of an old PS line I had laying around.
As for driving it this way, that's your call.
Good luck,
Matt
post #7 of 7 Old 04-17-2013, 02:07 PM
firemanjim7
1983 CJ7
Just take the belt off.
firemanjim7 is offline
