oiling question - JeepForum.com
post #1 of 7 Old 05-02-2010, 07:25 PM Thread Starter
JohnnyRotten
1978 CJ5
oiling question
Getting ready to start my new 360 in my CJJ5. When I went to prime the oil system I had 3 rockers that no oil came out of. I primed the system with a drill with the vlve covers off and noticed 3 rockers on the drivers side didnt have any oil coming out of them. I know the pushrods are clean.What is the problem or is this normal till the engine actually rotates. Thanks
JohnnyRotten is offline
post #2 of 7 Old 05-02-2010, 09:57 PM Thread Starter
JohnnyRotten
1978 CJ5
bump...just to maybe get some input
post #3 of 7 Old 05-03-2010, 04:20 AM
gmakra
Normal till it rotates.
gmakra is offline
post #4 of 7 Old 05-03-2010, 07:07 AM
halpeters
1978 CJ7
The compression of the lifter when the cam pushes up on the cam follower (bottom of the lifter) to "open" the valve pushes oil up the pushrod. When the lifter "closes" the valve, the lifter fills up with oil and start the whole process over...
So, the engine must be running to push oil up to the rockers....
Hal
1978 CJ-7
halpeters is offline
post #5 of 7 Old 05-03-2010, 12:27 PM Thread Starter
JohnnyRotten
1978 CJ5
Well I can tell you the engine doesnt have to be running to get oil to the rockers. They are all oiling now. Rotated crank a 1/4 turn and those 3 started and 2 of the others quit....lol.
post #6 of 7 Old 05-03-2010, 12:38 PM
Marctwayne
No difference between an engine rotating because of combustion or an electric drill. System functions the same. Rotate it though slowly till you see every thing working the way you want.
-- Marc Wilson -- 85 CJ7 Called Buster, Why? The wife likes to yell out the door "Are you done fix'en buster's bits yet"?
Originally Posted by my-jeep-earl View Post
It does look alot better when the Jeep is "ugly side up" though! :hahaha::teehee:
Marctwayne is offline
post #7 of 7 Old 05-03-2010, 12:39 PM
Marctwayne
to slow looks like you got it.
AMC 360 oiling mod (JunkYard Genious help needed) twmattox Jeep CJ Forum 18 11-04-2013 04:48 PM
Cam gear oiling olaf-inge Jeep CJ Forum 6 07-08-2009 04:27 PM
Finally found the info - AMC V8 oiling kit Bockwinkle Jeep CJ Forum 3 09-17-2007 04:56 PM
AMC 360 Oiling problems spk454 Jeep CJ Forum 1 08-27-2007 11:45 AM
AMC V-8 cam and gear oiling fuzz401 Jeep CJ Forum 2 02-19-2004 07:04 AM
