OIl type in my CJ7 - JeepForum.com
post #1 of 11 Old 11-06-2007, 04:43 PM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
OIl type in my CJ7
Hey everyone, I have an 86 CJ7, I just want to know the thickest oil you think I can put in there and still be safe. I live in Boston so the weather normally ranges between 20-95 degrees.
Thanks!
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 11 Old 11-06-2007, 04:54 PM
SuB8HaVeN
I would just run some good old 10W-30.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #3 of 11 Old 11-06-2007, 05:44 PM Thread Starter
mmerlina
mmerlina's Avatar
Well reason I ask about the thickest is because I have a very very very minor leak out of my new valve cover and I don't know which oil is in there now, but it looks very thin.
I wanted to go a little thicker to see if it would stop the leak.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #4 of 11 Old 11-06-2007, 05:49 PM
SuB8HaVeN
Running thicker oil doesn't necessarily stop leaks. If the leak is very, very minor I wouldn't worry about it. I have an aluminum valve cover on mine as well and it works great, but still leaks a very little bit; not enough to really notice it or make any difference in oil levels. If the oil seems thin I would just go ahead and replace it. I would say it's OK to run 15W-40 (that's what I run in mine), but never having lived in a cold climate (it's 60 down here in Florida and I'm freezing my a** off), I wouldn't know how the cold weather affects the oil.
post #5 of 11 Old 11-06-2007, 05:52 PM Thread Starter
mmerlina
mmerlina's Avatar
Well running thicker oil is the only solution I have left. I tried about 10 times to seat that valve cover so it doesn't leak, but I just gave up. This is the smallest it's been so I decided to just leave it alone.
I don't really much care about that it is leaking, what sucks is that it's leaking on the exhaust manifold side, so driving down the highway all I smell the entire time is a thick smog of burning oil inside the cabin.
The PO was the last one to do the oil so maybe he used some watered down crap for all I know. I'm going to see if I can find something a little better.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #6 of 11 Old 11-06-2007, 06:02 PM
kappa505
1980 CJ5
I use straigt 30w and I am in michigan. Its cold today.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #7 of 11 Old 11-06-2007, 06:54 PM
JeepHammer
Running On Empty...
1973 CJ5
15w40 in the spring, summer, and fall,
10w30 in the winter unless you do a lot of high speed driving, then use a 10w40 in the winter.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 11 Old 11-06-2007, 06:58 PM Thread Starter
mmerlina
mmerlina's Avatar
I'm not exactly clear which is the thicker oil? Which is thicker, 5w30 or 10w30?
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #9 of 11 Old 11-06-2007, 07:52 PM
kappa505
1980 CJ5
They are both multi viscosity oils. 5w has less viscosity than 10w when the oil is hot or any other temp for that matter.
According to haynes:
Multiviscosity Oil
Above 40 degrees F SAE 10W-30,40,50 or 20W-40,50
32 degrees F SAE 10W-30 or 10W-40
0 degrees F Same as above
Below 0 degrees F SAE 5W-20 or 5W-30
Single viscosity Oil
Above 40 SAE 30 or 40
32 SAE 20W-20
0 SAE 20
Below 0 SAE 10W
So as you can see, you can use pretty much anything.
kappa505 is offline
post #10 of 11 Old 11-07-2007, 06:55 PM
James04TJ
James04TJ's Avatar
Not exactly. The temperature at operating viscosity will be within the same range at operating temperature regardless of being a 5w, 10w, 15w, etc...
For example, I offer the following four group III oils:
AMSOIL XLM 5w-20
Kinematic Viscosity @ 100C, cSt (ASTM D-445) 8.5
Kinematic Viscosity @ 40C, cSt (ASTM D-445) 45.4
AMSOIL XLF 5w-30
Kinematic Viscosity @ 100C, cSt (ASTM D-445) 10.5
Kinematic Viscosity @ 40C, cSt (ASTM D-445) 58.2
AMSOIL XLT 10w-30
Kinematic Viscosity @ 40C, cSt (ASTM D-445) 63.6
AMSOIL XLO 10w-40
Kinematic Viscosity @ 100C, cSt (ASTM D-445) 15.7
Kinematic Viscosity @ 40C, cSt (ASTM D-445) 104.4
As you can see the difference when cold (40C) between a 5w-30 and 10w-30 can be seen. The voscosity at operating temperature (100C) is the same.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #11 of 11 Old 11-07-2007, 07:54 PM
kappa505
1980 CJ5
I can also split hairs.........but thanks for setting me smart.
kappa505 is offline
Transmission type? Mc83J10 Jeep CJ Forum 23 10-27-2008 08:57 AM
which type of welder? ohio77cj7 Jeep CJ Forum 9 08-01-2008 09:35 PM
holley type and dial type fuel press regulators ktm25089 Jeep CJ Forum 4 07-18-2008 05:47 PM
What type of CJ is this crosbike3688 Jeep CJ Forum 21 11-06-2006 10:22 PM
type of oil redcj576 Jeep CJ Forum 8 07-24-2006 04:13 PM
