Oil spraying out of line.that goes.to charcoil canister - JeepForum.com
post #1 of 12 Old 08-29-2011, 07:33 AM Thread Starter
truckshop21
1981 CJ5
Oil is squirting out of where my.finger is.pointing, only when motor is running... HELP.
truckshop21 is offline
post #2 of 12 Old 08-29-2011, 08:05 AM Thread Starter
truckshop21
1981 CJ5
its the line right next to the fuel line... i have a 81 cj5 with the 151ci gm 4cyl if that helps.
post #3 of 12 Old 08-29-2011, 01:35 PM Thread Starter
truckshop21
1981 CJ5
Help!!!!!!!!!!
post #4 of 12 Old 08-29-2011, 05:53 PM Thread Starter
truckshop21
1981 CJ5
Anyone?
post #5 of 12 Old 08-29-2011, 06:11 PM
Bakunin
Bakunin's Avatar
hmm
Are you sure that's where it's leaking? I'd be more apt to guess that it's from your gauge sender which is right in that area and is showing up on that line. That line you're pointing to doesn't carry oil AFAIK.
Bakunin is offline
post #6 of 12 Old 08-29-2011, 06:47 PM
walkerhoundvm
1981 CJ8
^^ This ^^
If you've got oil in that line you've got more problems than you think!
walkerhoundvm is offline
post #7 of 12 Old 08-29-2011, 06:52 PM
adman02
1979 CJ7
Originally Posted by walkerhoundvm View Post
^^ This ^^
X3
If it's the original plastic/nylon line, they are known to get holes in them. Replaced mine with a copper line when oil started spraying all over the inside of my engine compartment. Problem went away immediately.
adman02 is offline
post #8 of 12 Old 08-29-2011, 06:53 PM Thread Starter
truckshop21
1981 CJ5
I saw the fluid not sure if oil.or what but its coming from a crack.in that line
post #9 of 12 Old 08-29-2011, 06:54 PM Thread Starter
truckshop21
1981 CJ5
Its a steel line
post #10 of 12 Old 08-29-2011, 07:49 PM
walkerhoundvm
1981 CJ8
Not familiar with the 4cyl, but if it's a steel line, chances are that's gasoline. Hopefully someone with a 4cyl will have some info...
Either way, that steel line isn't too expensive to come by, and with a bender you can get for a deposit at the parts store, you can replace it yourself if you're handy.
post #11 of 12 Old 08-29-2011, 08:34 PM
Brodie14
I have the a similar issue. Mine sprays out gas every once in a while and it'll come through one of the holes in the tub and hit my boots.
Brodie14 is offline
post #12 of 12 Old 08-29-2011, 08:35 PM Thread Starter
truckshop21
1981 CJ5
Ok im in idiot it is the plastic line going to my oil pressure gauge. When I looked last night it was dark lol
