Oil Pump replacement question? - JeepForum.com
post #1 of 12 Old 08-31-2009, 09:22 PM Thread Starter
ottovonmerz
1983 CJ5
Hey Everyone!
New to the forum, but not to CJs.
My 83 CJ5 got a rear main leak again. Last time i replaced the rear main was in 97' so it's been awhile. While I had everything apart to change the rear main, I figured I might as well change the timing chain while I was there (98,000 original miles, and slack). My question is this:
should I go ahead and change the oil pump while I'm under there? The jeep has always had low pressure showing on the electric gauge (sender has been replaced). I know that the 258 had big oil passages, and I'm tempted while I'm doing all this to just plumb in a mechanical oil pressure gauge as well.
If a new oil pump is the recommendation, should I go stock replacement, high volume?
Any info would be greatly appreciated.
ottovonmerz is offline
post #2 of 12 Old 09-01-2009, 02:42 PM
JimNut
I just finished installing a Melling High Volume oil pump in my 258 last night. I was replacing the RMS and since I lready had the oil pan off and the fact that I've had low oil pressure for sometime and figured it couldn't hurt. I know the engine is tired (all original with 180k) and I'm not ready to do a full rebuild yet. Hoping this might buy it some additional life. I'll post up the difference in oil pressure once I get the engine fired up again. Just dropped it back in the jeep last night.
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #3 of 12 Old 09-01-2009, 02:48 PM
DT5150
1983 CJ7
might as well while you're in there. they're not too expensive.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #4 of 12 Old 09-01-2009, 05:40 PM Thread Starter
ottovonmerz
1983 CJ5
jimnut...
i'm eager to know if that melling helps. let me know!
post #5 of 12 Old 09-01-2009, 07:49 PM
DUX4LIFE
1977 CJ7
Did you get the one for the 4.2 or the 4.0 that was talked about a while back? I ordered the one for a 4.0 for my 258. Should be in tomorrow and I'll see if I want to figure out how to make it work in my 258.
DUX4LIFE is offline
post #6 of 12 Old 09-01-2009, 11:04 PM
Rob55
I am running the Mellings High Volume (brand new rebuild, about 500 miles) and it seems great - pressure is about 30 at idle, no problems.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline
post #7 of 12 Old 09-02-2009, 01:33 AM
Bubba Ray
Jimnut, let us know how it turned out.
Bubba Ray is offline
post #8 of 12 Old 09-02-2009, 06:31 AM
JimNut
Hope to have the jeep fired up in the next couple days. I had the engine out for some other reasons so I still need to hook everything back up. Just dropped the engine in Monday night.
It lists that it is the correct one for a 4.2 however when I received the pump the pickup assembly that was supplied wouldn't clear my oil pan so I ended up using the original pickup. It was the correct depth but it would hit the front edge of the pan where it drops down. This is the pump that I ordered.
http://www.hdmaddog.com/AMC-Jeep-Hud...-p6843170.html
JimNut is offline
post #9 of 12 Old 09-02-2009, 08:25 PM Thread Starter
ottovonmerz
1983 CJ5
I went ahead and bit the bullet today and bought the melling high volume pump today. i figured better safe than sorry, and i sure as hell don't want to pull the pan down again. I'll keep everyone posted as to the results. Thanks to everyone for the input!
post #10 of 12 Old 09-08-2009, 10:42 AM
JimNut
I fired up the Jeep for the first time yesterday after installing the Melling high volume oil pump and WOW WHAT A DIFFERENCE! With the original oil pump after the engine was warmed up I would get around 7-10psi. With the Melling pump I'm at a constant 40-45psi @ idle and it jumps to around 60psi as soon as you touch the gas. Definitely worth the price in my book. Now if I could just get the oil pan/RMS to quit leaking
JimNut is offline
post #11 of 12 Old 09-08-2009, 11:42 AM
shank38242
And no one has issues with the high volume pump pumping the pan dry? I have heard on other applications that if you go with a high volume pump you need a bigger pan, is this not the case with the 258?
shank38242 is offline
post #12 of 12 Old 09-08-2009, 11:10 PM Thread Starter
ottovonmerz
1983 CJ5
jimnut...that's awesome! just what i wanted to hear. just got the timing chain on tonight, and brought everything to tdc. gonna press in the pickup on the new pump tomorrow. Hopefully i'll have time to get her all together in the next week or so.
It's funny before i had kids, this is was probably a 4-5 hour job....my jeep has been in pieces in the garage for over a month. Good Times!
Fuel Pump Replacement - Advice budacj7 Jeep CJ Forum 2 01-31-2010 05:27 AM
62 CJ5 fuel-vacum pump replacement??? 49ereric Jeep CJ Forum 3 10-28-2009 08:17 AM
Oil Pump replacement yellow85cj Jeep CJ Forum 10 08-28-2009 09:08 AM
Replacement 360 Has Air Pump 5555555 Jeep CJ Forum 2 01-09-2009 10:33 PM
Power Steering Pump Replacement jeepjamboree Jeep CJ Forum 4 06-20-2008 08:41 AM
