Oil pump fit - JeepForum.com
post #1 of 6 Old 10-12-2013, 01:46 PM Thread Starter
wsmutch
Oil pump fit
I need to replace a leaky oil pan gasket. I want to replace the oil pump while I'm in there. I want to put in a Melling high volume pump but after some research I'm concerned that it won't fit without modifying the oil pan. I think the regular Melling pump does not, but I'm concerned it won't help my low oil pressure issues. Modifying an oil pan is way beyond my skill level.
wsmutch is offline
post #2 of 6 Old 10-12-2013, 02:17 PM
capt205
1983 CJ7
It will fit if you change out the pickup.
Got my 4.0 HV pump and 4.2 pickup from O'Reilly's
capt205 is offline
post #3 of 6 Old 10-12-2013, 02:21 PM Thread Starter
wsmutch
What pick up should I get? part numbers please
wsmutch is offline
post #4 of 6 Old 10-12-2013, 03:33 PM
capt205
1983 CJ7
I'm away from the garage tonight...I'll see if I can find a number in the AM.
You can also reuse the old pickup if that helps.
capt205 is offline
post #5 of 6 Old 10-12-2013, 03:46 PM
skizriz
1978 CJ7
I used a 4.0 HV Melling, and just reused my pickup tube.
The one for the 4.0 is alot cheaper for some strange reason.
No pan mods necessary.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #6 of 6 Old 10-12-2013, 04:34 PM
hp_lovecraft
1981 CJ5
and you get "rent" a special tool from the parts places that helds installing the pickup.
hp_lovecraft is offline
