oil pressure sending unit question - JeepForum.com
post #1 of 14 Old 08-21-2013, 10:03 AM Thread Starter
wsmutch
I decided to try getting my oil pressure gauge going. I'm looking at the sending unit, and I see a 3 prong connector. I can't find the matching connector or wiring that might go to it. There is one to to top. I get nothing at the gauge, no movement at all.
wsmutch is offline
post #2 of 14 Old 08-21-2013, 10:29 AM
WindKnot
1977 CJ7
Look at my picture. The sender is the one on the left. There should be only one wire attached. For my year it is purple. On the right side is another sender dependent on oil pressure. For me it was an aftermarket electric fuel pump that will shut off the pump when the engine is stopped even though the ignition is still on. (Like for example if I ran into a tree or something.)
You have something similar but it's from the factory. Your Jeep is newer than mine. It maybe was a hookup for a computer or something emissions related, I don't know. But for the oil pressure gauge, you want to hook up to the sensor that looks like mine.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 14 Old 08-21-2013, 10:30 AM
gosupes
That's a pressure switch, used for idiot lights, manifold heaters among other things. Three terminals, likely common, normally open and normally closed. Your pressure sensor is the round can right above the switch behind that bundle of wires. I think the sensor just uses a wiper arm across a resistive element. You can try using an ohmmeter from the terminal to a good ground and see if it changes with pressure changes. Or just say the hell with it and plumb in a mechanical gauge.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #4 of 14 Old 08-21-2013, 10:34 AM
LumpyGrits
The sending unit(110%, OEM, POS)is on the left side of the pictures.
BTW, NEVER use Teflon tape on these, as they need a good ground(GND)for the electrical circuit.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 14 Old 08-21-2013, 10:45 AM
WindKnot
1977 CJ7
Mine works just fine with zero resistance. It was also just around one lap and not half the roll. the Teflon will tear if it's thin enough.
WindKnot is offline
post #6 of 14 Old 08-21-2013, 10:50 AM
LumpyGrits
When I used the brass pipe, it cracked in a yr of Jeep'n
Went to a steel pipe, and no issues.
LG
post #7 of 14 Old 08-21-2013, 11:20 AM Thread Starter
wsmutch
So, the wire on to goes to the gauge and the three prong is not necessary to get a reading at the dash?
wsmutch is offline
post #8 of 14 Old 08-21-2013, 11:35 AM
LumpyGrits
Correct
LG
post #9 of 14 Old 08-21-2013, 04:25 PM
86cj74.2L
86cj74.2L's Avatar
I put a mechanical Stewart Warner Gauge in the CJ when the sending unit died.
With the copper hook up kit I bought it will last forever.
86cj74.2L is online now
post #10 of 14 Old 08-21-2013, 06:09 PM
LumpyGrits
I did the same thing, after the second sending unit died while the Jeep was still in warranty.
LG
post #11 of 14 Old 08-21-2013, 06:35 PM
keith460
Jeep. There's Only One
keith460's Avatar
The three prong plug is for the Electric Choke Switch, but don't recall it being 3 prong as it is a more common 2 prong switch. It allows voltage to be applied for the coil of the Manifold Heater and carburetor Electric Choke.
If you are worried about what your actual oil pressure is and find that the OEM gauge is not accurate or functioning properly, do yourself a favor and add a small liquid filled pressure gauge to the side of the engine block so you can know at a glance whether oil pressure is present and at what the current pressure is at.
I used a small liquid filled pressure gauge that I bought from McMaster-Carr.com and added a 1/8 NPT thread to the existing pipe union for the Oil Pressure Sending Unit and Choke Switch.
The gauge in the picture is not liquid filled as it was changed out shortly after taken the photo.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 14 Old 08-21-2013, 06:59 PM
LumpyGrits
Hey Keith, nice idea!
BTW, why don't you run that battery gnd to the top mounting bolt of the starter. Nut'n but good when you do.
LG
post #13 of 14 Old 09-07-2013, 07:20 PM
70worm
1977 CJ5
Can someone tell me how the wires hook up on the back of the gauge?
70worm is offline
post #14 of 14 Old 09-07-2013, 08:39 PM
titomars
1981 CJ7
Red wire to positive terminal
Purple to neg or to sender
Orange for gauge light
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
